 Post subject: problems with my Maxtor 120 GB
PostPosted: August 28th, 2009, 7:11
Hello, first of all i'm sorry for my english, i'm from Spain.
I 've a Maxtor 120 Gb model 6Y120L0 firmware YAR41VW0.
I had problems with the disc, there wasn't power in the hdd and i changed the PCB. I bought it in www.onepcbsolution.com and i think the PCB is ok and now the hdd is running but the hdd doesn't work, the PC doesn't recognize the hdd. I think i 've to change the head ¿?.
Now i'm looking for to buy a new hdd for change the head just in case this is the problem.
My quiestion is:
If i buy a Maxtor with the same model 6Y120L0 but the firmware is YAR41BW0 the head's are the same and the hdd will run ok or i 've to buy exactly the hdd with the firmware YAR41VW0.
 Post subject: Re: problems with my Maxtor 120 GB
PostPosted: August 28th, 2009, 7:54
hi,
would you like to post PCB images here? it may be no head problem.
data recovery service[/b]
PostPosted: August 28th, 2009, 8:53
Ok, this afternoon i will take a photo of the PCB and i will send you.
PostPosted: August 28th, 2009, 8:57
Are you sure new board is correct one?
www.datarecoveryne.com
PostPosted: August 28th, 2009, 9:08
PCB is not identical or also SA problem; then head change wont work.
dobre
Murphy was an optimist
PostPosted: August 29th, 2009, 5:21
what are the symptoms after pcb swap?
PostPosted: August 30th, 2009, 16:26
i don't know how i can add the photos in the message but I think is the same PCB, is for the same model, firmware and the chip of the PCB is the same. In the web they ask me every data about the PCB. The PCB is exactly the same.
Please help me.
PostPosted: August 30th, 2009, 16:29
i'm sorry pepe the symptoms are :
The disc is running but the PC doesn't detect the hdd.
Before to change the PCB the disc didn't run.
i think the problem started when the power fault.
PostPosted: August 30th, 2009, 22:21
Disk might have internal problems as it has a lot of internal "programs" which could have been corrupted due to PCB failure or some other factors.
PostPosted: September 1st, 2009, 4:50
Ok, and how can i repare those internals problems in the disc.
PostPosted: September 1st, 2009, 6:57
Buy a PC3000 and pay someone to explain you how firmware works, if it is the firmware.
Users browsing this forum: No registered users and 158 guests
