 Post subject: Unlocking ATA Password for Western Digital wd800bb-22ghco
PostPosted: September 16th, 2009, 10:41
hello everybody
I have my hard drive locked by ATA password
and I need the master password for unlocking it by mhdd program
and I need It quickly
 Post subject: Re: Unlocking ATA Password for Western Digital wd800bb-22ghco
PostPosted: September 16th, 2009, 11:11
Then you better read quickly and use the search function as all the relevent information is in one or two threads. :lol:
PostPosted: September 18th, 2009, 17:51
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: September 24th, 2009, 13:56
hi i was stuck with the same problem which i solve on a WDC250bevt
just a quick list of master pwd i found on my travels
WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCW <----THIS ONE WORKED FOR ME
WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
&'()*.WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
h2oinsyde <-----for acer drive(but not mine)
if none of the above work then the fun begins
first download MHDD boot disk (google for it)
copy the file i put up on to a usb stick and plug in
remove all drives except locked one
boot the cd and press F5 (safe mode)
type 'c:' to get to the contents of usb drive
then type MHDD to run the program on the usb not the cd as that is wrong version
in MHDD (select drive this might take a little bit of getting use to!)
run the script by typing .dump
the script will run and return "DONE"
remove the usb and look at the 22.bin file with a hex editor
also for a little more understanding read
unlocking-ata-password-for-western-digital-t8374.html
like i did
hope this helps
MHDD.zip [127.51 KiB]
Downloaded 800 times
which one of my personality do you want to talk too
Users browsing this forum: No registered users and 264 guests
