 Post subject: PCB BAD WD1200UE-00KVT0. OTHER TVS PROBLEM?
PostPosted: September 15th, 2009, 9:59
When i connect the disc in PC-3000 not spin up. TVS problem? See pictures... where are the tvs in this picture?
thank,
Carlos
 Post subject: Re: PCB BAD WD1200UE-00KVT0. OTHER TVS PROBLEM?
PostPosted: September 15th, 2009, 12:43
More likely:
1. Heads stuck on platter or in ramp;
2. Smooth IC bad
3. Fuse open
http://www.datasaversllc.com
PostPosted: September 15th, 2009, 16:07
Test diodes D3, D4 with Digital Multimeter
PostPosted: September 24th, 2009, 21:51
Diodes D3=1.3 (200 k) D4=1.3 (over 200 k)
PostPosted: September 25th, 2009, 0:43
try to power up the drive and listen to it carefully.
I agree with jono maybe the heads stuck on platters or in ramp.
good luck
PostPosted: September 25th, 2009, 12:06
In case the heads stick to the disc that would have to do I?
Thank
PostPosted: September 26th, 2009, 20:26
Something looks very wrong to me.
The manufacturing date on the label is 26 July 2007.
However, the date code on the PCB suggests week 37 of 2006 (3706).
The MCU's date code is week 31 of 2006 (0631).
The RAM is 622B and the motor controller is 636.
PostPosted: September 28th, 2009, 9:56
mmm.. its not PCB for this HDD?
Users browsing this forum: Google [Bot] and 217 guests
