 Post subject: Maxtor 6E020L0 need help!
PostPosted: October 3rd, 2009, 1:38
Maxtor 6E020L0 - NAR61590, client has droped and motor's stuck, need help to recovery data. I's swapped motor, can run with ldr created by the HDD but client do "something" on platter and they make some scratch. It can get ready so fast if run loader without "Initialize HDD" and then also with "SA testing and recovery" and "SA surface verification". Can not run SA verification with "Reassign BAD sector writing" SA test tell that 22, 1D, 1B, 5E have badsector and all other OK. Can not run "Sector edit" so DE can not read to make clone HDD. Someone help?
SA surface verification.rar [2.98 KiB]
Downloaded 338 times
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
 Post subject: Re: Maxtor 6E020L0 need help!
PostPosted: October 3rd, 2009, 4:47
Hotswap, rebuild translator on donor first.
PostPosted: October 3rd, 2009, 4:53
Hotswap is not a good solution, but anyway, it is risky but sometimes helps in this level too.
Better if you do some steps before to protect the SA from more damage....
Janos
PostPosted: October 3rd, 2009, 6:36
Thanks @HDD Spaz and @N.C.
I'll try to find donnor but, what a hard, 6E020L0 - Date: 30APR2003 - 4265 - KMGA was very old. I have only 2E46 - KGGA and 059D - KMBA. Do you think the head's weak so its can read only and can not write?
PostPosted: October 3rd, 2009, 6:44
In this old drive, can be anything...
I can imagine light-bad spindle, vibrating platter, dirty head (caused by vibration), overheated head, and so on...
For donor, you can use any drive, like this:
6E0x0LxMMxxxx (MM should match with your patient drive, x are not important.)
K,x,xA
Janos
PostPosted: October 3rd, 2009, 6:55
Thanks @N.C. I'll give a try.
PostPosted: October 5th, 2009, 1:39
All data was recovered.
Thanks for your help!
PostPosted: October 5th, 2009, 2:58
K,x,xA
Janos
Why K,x,x,A? What does A represent? Always thought first 2 are important, head and preamp type.
PostPosted: October 5th, 2009, 3:52
In this drive the A is the preamp code, trust me. ;)
Users browsing this forum: Google [Bot] and 220 guests
