 Post subject: Seagate ST3120023A - PCB / Firmware / Power Problems
PostPosted: October 16th, 2009, 10:46
Seagate ST3120023A P/N:9w4001-301 firmware 3.33
The drive will not spin up (something on the PCB is bad - I know this because I put a different PCB on the drive and it spins)
However - I could not find an exact match on the PCB so I bought one that was close - it's from the following drive
Seagate ST3120023A P/N:9w4001-001 firmware 3.30
Put the new PCB on the drive - it spins up - but nothing is recognized -
There was a western digital in the same pc that experienced the same issue - I switched the PCB and all the data was recoverable...
I'm guessing there is something I can do to fix the power interruption issue with the existing PCB or a way to make the firmware (or whatever it is) the same on the functioning pcb.
I really don't know crap about the workings of a hard drive - but I can solder and operate a pc...
Please Help
 Post subject: Re: Seagate ST3120023A - PCB / Firmware / Power Problems
PostPosted: October 16th, 2009, 14:44
1. get a pcb with the same FW.
2. replace ROM from bad PCB to the good ( if there is one)
3. repair the bad PCB.
4. if neither works for you, or u are not confident in doing the above, get it to a pro
PostPosted: October 16th, 2009, 15:18
Post a pic of the PCB and we'l show you which chip to change over.
PostPosted: October 16th, 2009, 19:50
hi,
here is ref pic. your PCB may be shape close as this one. and ROM chip model most is:25XXXX
data recovery service[/b]
PostPosted: October 17th, 2009, 3:49
The man is right, that's the chip.
If the PCB has the same main chip and you move the ROM over, then the PCB will work.
Assuming the PCB is the only problem, of course.
PostPosted: October 18th, 2009, 11:33
Here is a pic of the BadPCB - it's a little different than the one posted....
File comment: Bad PCB
PostPosted: October 18th, 2009, 12:08
In your photo why is the component close to the left hand top corner out of position? What has been going on?
Also you don't need 2 threads on the same topic so you could post a message in the other and direct peeps to this one.
PostPosted: October 18th, 2009, 12:28
1 item in the picture looks funny... Did you try to remove it on your own?????
PostPosted: October 21st, 2009, 21:18
nope - I have not attempted to do any work on the PCB - I see what you mean - that one chip is crooked
PostPosted: December 17th, 2009, 11:56
anybody have any thoughts on this....
Can I fix the bad board or does anybody know where I can buy a new PCB for this?
PostPosted: December 17th, 2009, 23:12
I see the diode that is crooked and I think the factory's QA would have let this out. (It is a Seagate after all)
The ROM is probably the 8 pin chip "southwest" of the crooked diode. Can't read the marks in the photo, so double check. The other 8 pin chip - on the right - is obviously not a ROM.
PostPosted: December 19th, 2009, 3:25
hi,
here you are.
Users browsing this forum: No registered users and 254 guests
