 Post subject: WD400 - Platter swap or head transplant?
PostPosted: October 23rd, 2009, 10:35
I have a WD400BB-60DAG0 with bad heads. Am I more likely to have better success wih swapping the platter into a good donor or swapping heads? I'd appreciate some opinions from some of you seasoned techs. In fact, in general, is head transplant prferrable to platter swap on single platter drives? On multi platter drives?
Thanks for your opinions,
Gordon
Thanks,
GB
 Post subject: Re: WD400 - Platter swap or head transplant?
PostPosted: October 23rd, 2009, 10:37
Its always preferable to do a head swap (except maxtors N40P and alikes).
Platter swap can give a lot of problems (alignment, eccentricity etc ...) and should always be used as a last resort.
Dobre
Murphy was an optimist
PostPosted: October 23rd, 2009, 10:58
I agree...don't risk the moving the platters when not needed. If you have the right donor drive and tools, this is a fairly easy drive for moving the heads.
PostPosted: October 23rd, 2009, 13:35
if you drop the heads the data wont be lost. If you drop the platters, who knows!
PostPosted: October 23rd, 2009, 16:53
agree with HDD Spaz
PostPosted: October 23rd, 2009, 17:05
agree with above friends opinions. just take less time & easy way to do it right. 8)
data recovery service[/b]
PostPosted: October 23rd, 2009, 17:10
in the front of your destination just take 5 Min. why you had to waste more and more time walk around the earth go there?
Users browsing this forum: Google [Bot], jabuzzard and 212 guests
