 Post subject: What kind of HD is this?
PostPosted: December 11th, 2009, 20:05
Hi all,
Could you please help me with this:
[Picture removed]
What kind of a HD is this? IDE OR SATA?
I cant boot windows anymore so im trying to attach it as a secondary disk and get my data back this way.
Could i use the following cables to connect it from IDE/SATA to USB?
https://www.yagoda.nl/sata-kabel-conver ... 994aeaa712
Could i use these cables to connect the HD to USB?
Please help, this is an HD Futusij, hp laptop Dv9000.
Regards,
Alan.
 Post subject: Re: What kind of HD is this?
PostPosted: December 13th, 2009, 8:20
Alan,
This is a 2.5" SATA Hard Drive. The drive has an adapter connected (which connects to your motherboard in your laptop).
Remove the hard drive from the caddy and then remove this adapter and you will see that it is a regular SATA connector.
/ck/
Data Recovery Ireland
PostPosted: December 13th, 2009, 10:14
Hallo CK and thank you so much for your help! I was well confused cuz the IDE kabels wouldnt fit and it was no SATA connector so ?
But thank, i got it now!
Regards,
Alan.
PostPosted: December 15th, 2009, 10:39
CK,
You got any idea how to remove this thing? Any manuals or anything?
Regards,
Alan.
PostPosted: December 15th, 2009, 11:36
picture removed m8 so i cant see what are u talking about. However if its what i think it is - u just inscrew the hdd from a caddy if its screwed , and pull on the adaptor to disconect it.
PostPosted: December 15th, 2009, 12:13
Hallo Alexii and thank you for the kind reply.
Here is the pic: Image
I just need to screw off the left screw right and then just pull it off?
Regards,
Alan.
PostPosted: December 15th, 2009, 17:37
Dear Alexii, Thanks alot for the reply mate!
This is the HD:
The only thing here; is removing the screw on the left and then pulling back right?
Regards,
Alan.
PostPosted: December 15th, 2009, 18:41
Alan, looks like there are some screws along the side of the actual drive. Remove these and then pull the drive away from the metal caddy. Then remove the adapter.
If this doesn't work, post some pictures of the drive from the side/bottom
PostPosted: December 15th, 2009, 18:46
is possible to tell us the model of HDD i can tell you if is PATA or SATA.
ZeBong
" Россия еще раз"
PostPosted: December 15th, 2009, 19:12
zebong, look at the photo....it's SATA
PostPosted: December 15th, 2009, 19:14
yes you are right :D
ZeBong
" Россия еще раз"
PostPosted: December 16th, 2009, 10:05
Heya Alan. Sry mate not the best angle for a pic =)) Anyway , its just like CK said =) Its safe to remove all the screws u see on that HDD with the exeption of TORX screws =) oh , and dont remove the screws on the green board. They hold PCB and have nothing to do with ur conector.
PostPosted: December 20th, 2009, 6:12
Hey folks!
Thank you for all the help Alexii, CK and Zebong! I got fixed thanks to you folks and got my data back!
Really appreciate it.
[part of this message was removed by moderator]
Regards,
Alan.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 179 guests
