 Post subject: SEAGATE 7200.7 80GB
PostPosted: December 17th, 2009, 17:55
Hi to all,
Have this Seagate disk that give this in terminal them GET ready DRD DSC
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk S.15 02-08-03 15:03
Buzz - Head Mask 0000 - Head Mask 0000 - Switch to full int.
Spin Ready
3.06 08-08-03 14:05
(P)PATA Reset
$NIWOT TIME OSwitch to full int.
UT
AM Reacquired
Master
$Switch to full int.
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
$(S)PATA Reset
Switch to full int.
AM Reacquired
Master
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AT Er 00 Nwt Er 37 RdWr 0029.00.0001
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 0000fedc ff 0000fedc.0.000 00db 0000 e0e8 0001
AutoRd Err 43 at 000029.01.01ef
SCAN Error
AT Er 00 Nwt Er 43 RdWr 0029.00.0001
AutoRd Err 43 at 000029.01.01f2
CE Log EC=43 Rtype=25 OV=0 STStatus0
SCAN Error
AutoRd Err 43 at 000029.01.020f
SCAN Error
AT Er 00 Nwt Er 47 RdWr 0029.00.0001
AutoRd Err 47 at 000029.01.0210
CE Log EC=47 Rtype=25 OV=0 STStatus0
UT
AM Reacquired
SCAN Error
AM Reacquired
AutoRd Err 47 at 000029.01.028a
SCAN Error
CE Log EC=43 Rtype=24 OV=0 STStatus0
AutoRd Err 43 at 000029.01.02a1
AM Reacquired
SCAN Error
When i edit sectors e can get it OK, but some sectors i can not read.
Change heads and happen the same.
This CE Log error can i use SD Seagate to remove it ? anyone have try this ?
ZeBong
" Россия еще раз"
 Post subject: Re: SEAGATE 7200.7 80GB
PostPosted: December 17th, 2009, 17:59
I have used SD Seagate to fix this error and so far it's worked every time, but I don't remember the "AM reacquired" or the "$" in my cases.
PostPosted: December 17th, 2009, 18:42
this is head problem
PostPosted: December 17th, 2009, 19:39
Yes it was that i think on the first time, so i change heads and the LOG is the same.
Some sectors i can read it well "green" 50 to 90 sectors them "1" i can not read it, them i can read more 100 and "1" i can not read it, and is doing this all the disk.
I am thinking that maybe it have a scrtach, but if it was a scratch i should have BAD more them "1" sector.
ZeBong
" Россия еще раз"
PostPosted: December 17th, 2009, 21:51
Is this through microsoft terminal or pc3000?
PostPosted: December 17th, 2009, 22:50
Can also be problems with platter wobble, alignment, eccentricity, etc
PostPosted: December 18th, 2009, 6:03
has this disk had a platter swap?
PostPosted: December 18th, 2009, 6:05
no did not, it had inside a computer, and it was not a external disk.
ZeBong
" Россия еще раз"
PostPosted: December 18th, 2009, 9:51
I think that this most probably is a head issue. Have you created a head map? This is a two head drive ? Right? Test copying from one head at the time. (Test from different places on disk) If this works, pay closely attention to the terminal window and notify when and where the $Switch to full int. AM Reacquired messages is displayed.
PostPosted: December 19th, 2009, 6:07
most is head have problem :D
data recovery service[/b]
