 Post subject: FOR MAXTOR GURU
PostPosted: December 20th, 2009, 15:50
LOADER WANTED FOR DIAMONDMAX PLUS 8
SN:EI0ED22E K,G,G,A
6E030L0510201 NAR61590 B6FEP1
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: FOR MAXTOR GURU
PostPosted: December 20th, 2009, 18:50
http://files.hddguru.com/download/PC-30 ... r/Loaders/
You can use any size drive
There is couple available.
www.datarecoveryne.com
PostPosted: December 21st, 2009, 3:59
Thanks Hardddddd!!!!
XRONIS
PostPosted: December 21st, 2009, 11:07
how do the loaders work?
PostPosted: December 21st, 2009, 11:50
loader is a "microcode/s" which is loaded into a drive in order to access Service Area.
Then you go into SA and check for damaged modules "programs" if any.
It also allows to figure out the cause of the drive failure.
You will need special equipment and knowledge to do that.
Users browsing this forum: No registered users and 222 guests
