Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: ATA Terminal
PostPosted: January 13th, 2010, 1:37
It am reading it to say (for the commands that support it) that bit 6 should be on. LBA28 Bits 24-26 are bits 0-3, using "Read Sectors" as an example.
PostPosted: January 13th, 2010, 15:56
While this is on the second page, hopefully most will read this. I have no intention of giving the software out. Some of the regulars maybe. I have learned from this project, that if you don't have the discipline to build this yourself you can only do more harm than good.
PostPosted: January 19th, 2010, 2:21
Anyone care to shed some light on WD smart log? I have started looking into it and I am trying to narrow down the meaning of the highlighted hex values.
I am thinking of attacking this programatically, writing the buffer out to file while DRQ after each request. I would then check for error and recalibrate the drive, re-enable writing to the log, then incrementing the value. If nothing else, I will end up with a lot of random junk that I can then begin to decipher. I am not looking for exact values or anything like that, I want to figure it out for myself. Just looking for any possible problems with my approach.
Shawn
PostPosted: January 19th, 2010, 2:57
A good example is 08 00 01 00 04 returns:
PostPosted: January 19th, 2010, 3:52
Nevermind.. I was able to search the output of several runs and found the information I was looking for.
Users browsing this forum: Google [Bot] and 138 guests
