 Post subject: Looking for PCB board for WD2500KS
PostPosted: February 28th, 2010, 17:31
i am looking for a PCB board for a Western Digital WD2500KS
MDL:WDS2500KS-00MJB0
DCM:DSCANTJAA
Board:2061-701335-C00
i will take any board that will make this drive work. i am trying to recover data. if you have a board that will work, please provide location of proof, so that i may confirm.
 Post subject: Re: Looking for PCB board for WD2500KS
PostPosted: February 28th, 2010, 19:30
hi,
i have this PCB in stock. please contact me by MSN or email. thanks.
data recovery service[/b]
PostPosted: February 28th, 2010, 22:54
Can you upload a detailed photo of the component side?
What is the failure symptom?
PostPosted: March 1st, 2010, 11:20
not detected in bios. no sound of drive spinning up.
PostPosted: March 1st, 2010, 19:45
take off PCB and have a look. SMOOTH chip may burned already. 8)
PostPosted: March 2nd, 2010, 21:46
here is a pic of the board and the top of the drive.
the full number on the bottom of the drive is
2061- 701335-C00 AG XC 2W130N8S B 0004400 6404
File comment: board is burned bottom left
File comment: top of drive
PostPosted: March 2nd, 2010, 22:16
Your motor controller chip is damaged.
You will probably need to transplant the 8-pin serial EEPROM chip at location U12 from patient to donor. This is because it stores unique drive calibration data.
PostPosted: March 3rd, 2010, 0:50
wont i be able to just swap in a new board?
PostPosted: March 3rd, 2010, 4:18
No, you need to transfer U12 also.
Users browsing this forum: sixsweets and 92 guests
