Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: February 13th, 2010, 2:34
It appears to me that the user and master passwords each occupy a block of 32 bytes.
The password string appears to be terminated in a NUL byte (00).
The header consists of three bytes, 01 07 00.
The master password is 31 bytes long and consists of "WDC" repeated ad infinitum.
The user password appears to be ...
3E A8 00 42 DC 3E 24 F5 C5 6A 45 69 01 E6 0D 78 08 C9 86 F2 00 00 ...
If the NUL byte is indeed the delimiter, then the password is Alt-062 Alt-168.
OTOH, if NULs are part of the string, then there is no way to enter them via the keyboard, at least not in DOS. Furthermore, there is a 0D character which corresponds to a carriage return. This character will itself terminate keyboard input. Therefore such characters would need to be piped via file input rather than ordinary keyboard input.
PostPosted: February 14th, 2010, 3:26
Hello all,
I want to thank you in advance if you can help me resolve my issue.
I have Acer laptop 5515 with SATA HD 120G. I setup a password for my HD and I forgot the password, therefore I am unable to use the laptop anymore. Each time I boot up the laptop is asking me the password.
Please someone help me to get my password back.
many thanks.
L.A :roll:
PostPosted: February 14th, 2010, 4:08
Your HDD details ( model.... etc ) ?
PostPosted: February 14th, 2010, 4:31
The model is Hitachi HTS543216L9A300 and the laptop is Acer 5515.
As soon I boot up the laptop I am getting the following error message.
Enter SATA Port 0 HDD User Password.
I hope that helps.
PostPosted: February 14th, 2010, 5:16
Unfortunately, you will need a special tools (hardware/software) to unlock your drive. ( specially Hitachi will be more complex than other brands to unlock ).
Seek for a PRO near you in this forum to fix your drive, he will fix it with reasonable price.
Good luck
PostPosted: February 14th, 2010, 5:49
Any further help Please.
PostPosted: February 14th, 2010, 6:32
There is no further help for Hitachi, you DO need pro tools for this case. There is no freebie solution for Hitachi.
PostPosted: February 14th, 2010, 10:58
You can try to unlock it using HDD Erase, you must pay and normally HDD will be erase but you can use it again. With this method i rescue a WD HDD...
PostPosted: February 16th, 2010, 9:17
Would somebody please help me to recover the password of my harddisk?
Its a Western Digital WD400BD 40GB.
I think I just need a push in the right direction. Where to start?
I have read the whole topic and downloaded MHDD, but what to do with it?
Thanks in advance!
PostPosted: February 16th, 2010, 9:24
This topic is already your right direction, you can start from page 1.
Good luck
PostPosted: February 17th, 2010, 4:48
When I type .read (read is the name of my script) in MHDD I get: Divice not ready, aborting...
What to do?
PostPosted: February 17th, 2010, 6:35
I figured it out!
Would somebody help me locate the password?
PostPosted: February 17th, 2010, 7:21
BendeBoy, i'm not sure but plug your HDD as primary master and try again...
PostPosted: February 17th, 2010, 8:35
I got this :D
Where can I now find the password?
I have run dump en dump2 with mhdd 4.5
PostPosted: February 17th, 2010, 8:36
I got this :D
imgdumper.nl/uploads2/4b7bc6e7a999c/4b7bc6e7a0d02-pass.png
It seems that my post have to be approved by a moderator when I post urls and imgs. So i masked the link. :oops:
PostPosted: February 17th, 2010, 15:58
my name is Markus and i´m from Germany. First, I apologize for my bad english. I found this forum and this post when i was looking for an solution about a locked Acer Aspire Hard Drive. I read the whole post and with the post from M0RBI0US and MHDD and the 22.bin i could unlock it because the user Password was plain text.
But now i have anather problem. I have an Humax Satelite Reciever with HDD built in. I know that the Reciever set the HDD to high security and set a user and a master Password. I try to built in an WD2500AAJB. Before i built it in i had set an Master password with ATAPWD that i can erase the HDD when im gona use it again in the PC. I read id out whit MHDD and the master PW was there as plain text. So i built it in and the receiver had to Format the HDD. And now there is nothing as plain text anymore. I had attached the 22.bin as an .jpg that i read out.
When i understand the post from fzabkar right, the Password starts after the 01 07 00. but there are more than 32 Signs included and i dont know where it starts and where it´s ending.
Could somebody help me whit that problem?
PostPosted: February 21st, 2010, 8:10
Hi Guys,
could anybody tell me if it works also for Samsung HDDs?
I have a problem with a locked MP0804H and couldn't manage to unlock it yet nor to erase it with hdderase.
And buying a new device is not an option since I'm a student with a rather small budget.
maybe there are only other regs?
I'll keep playing around with MHDD but i'd be grateful for any suggestion.
PostPosted: March 2nd, 2010, 11:18
Nirvanowiec wrote:
but no one is prohibited to do the same in MHDD
;script name: read md
;reads md 02 on WD marwell drives
; end
512 byte cs.bin
0x000  08 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00   ..................................................................................................
0x1f0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
cs.bin and mhdd.exe have to be in the same directory
Password we can read without problems from 22.BIN
This script does not work with WD5000AVVS drive. It finishes with:
LINE 8: SECTORFROM - CS.BIN
ERROR: drive reports error
Does the WHDD support this drive?
PostPosted: March 2nd, 2010, 12:37
I have too locked 500GB HDD WD and script does not works.
Have someone other script that works fine?
I think that WD drives have more type of chips (Marwell...) and script work only for some types.
PostPosted: March 8th, 2010, 14:15
Hello Nirvanowiec,
Any chance for help concerning the WD5000AVVS drive?
I need to find out its master password.
Best regards,
jaro
Users browsing this forum: No registered users and 69 guests
