Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: January 26th, 2007, 5:17
Hi
Ok, sorry i forgot to tell you this info.Here it is:
Interface task reset1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz -
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
3.06 10-21-03 15:53
(P)PATA Reset
Failed sys sect. write
Slave(
T>
I want to tell you that i did NOT write anything on the hdd ....i know that writing in the fw. area is very dangerous for the hdd if u don't know what u are doing (mainly for seagate hdd), so i didn't write anything to it.
PostPosted: January 29th, 2007, 9:49
please send u e-mail
PostPosted: January 30th, 2007, 3:24
Hi
My Email: freecmp@yahoo.com
 Post subject: seagate 320 GB ATA
PostPosted: February 8th, 2007, 12:11
I also have problems with Seagate's HDD (Barracuda 320 GB, ATA). Recently my HDD started with strange behavior. The computer started to run slowly and were crashing down without any special reason. I tried scandisk and it found no problems. When I rebooted the next time the BIOS could not recognize the HDD anymore.
Do you have any idea how to bring the HDD to life and to get the data from this disk...
Best regards,
Robert
PostPosted: February 16th, 2007, 5:18
Hi all
I've managed to get an working drive with the same model ST340014A fw. 3.06. Does this help to repair the defect drive with "failed sys sector write" in any way?.....I mean can I do something like copy some modules from the good drive and write them to the defect drive?.....or something else?
Rgds
PostPosted: February 21st, 2007, 4:02
Nobody knows?????? :cry:
 Post subject: Re: Failed Sys sector wirte
PostPosted: February 21st, 2007, 22:15
Alef wrote:
to fix"Failed sys sector write
Rewrite Ata #1 Module
to fix Hdd Seagate very good Salvationdata Seagate Firmware Pro
I have tried rewrite Ata #1 module but problem is same,
I know the problem is caused track 0 bad,
How do to repair this ?
PostPosted: February 24th, 2007, 11:23
I need help to unlock a seagate ST3160021A drive.
I've tried MHDD with master password but no luck. I read somewhere that I could upgrade the firmware. Does anyone know where I can get the firmware? I 've tried the seagate site already.
Al
PostPosted: February 26th, 2007, 17:05
Hi all,
Does anyone know the master password for unlock the ST3200822AS? Don't know for what reason it got suddenly locked which connected to 3ware adaptor at Raid 5 configuration used about 2 years. Any ideas that it was caused by the drive defect or virus? Thanks a lot!
JK
PostPosted: April 4th, 2007, 2:25
I also have a problem with 40gb seagate barracuda 7200.7 there are three partitions on the drive when i do write erasing on drive using victoria it gets
stuck on 765 sector and drive stuck on DRDY , DSC & BSY then i replug the
drive and chk partition still there .
What is the problem?
Thanks in advance .
PostPosted: May 1st, 2007, 5:11
u r right alef have re write on ATA #1 AND SEE WAT HAPPEN IF HAVE PROBL;EM AGAIN MEANS HE HAVE DONE WITH WRONG FIRMWARE ..
PostPosted: May 1st, 2007, 5:31
Hi guys
I know how to enable writes on this write-protect hdd's but what to do next?... I mean how to figure out what is the cause of this error?
I tryed N2,,22 but nothing, I tryed rewrite Cert, Ata tracks but the problem remains....
Any ideas?
 Post subject: Re: Seagate Barracuda 7.7200 few bads trouble
PostPosted: October 26th, 2007, 6:04
Hi
I have an Barracuda 7200.7(80G) with few bad sectors(about 100)....some of them are IDNF errors which ,of course, can't be added in g-list.
My question is does anyone know which tests from the selfscan T?? can be run to have this sectors put in p-list or another list except g-list?....or which command moves the g-list to p-list?
Thanks in advance
www.datasave.ro
PostPosted: October 29th, 2007, 15:25
U can try I,,22 on level T .
PostPosted: October 30th, 2007, 5:25
Hi rameez
Thanks for reply but i think i don't need the I,,22 test...it's for SA area and i have defects in user area..so no point in running that test...
Anyway i allready resolved that issue...i found out myself witch test is better to run in this case...
Rgds
www.datasave.ro
PostPosted: March 3rd, 2008, 1:47
wipe the first sector! and rebuild the MBR AND PATITION TABLE
PostPosted: May 17th, 2008, 13:17
so old a talks,but very interesting...
Best Regards
DIYer
PostPosted: May 23rd, 2008, 15:25
ccc,
If u have another solution to this problem can u share please .
PostPosted: June 17th, 2009, 17:40
Very dears all,
I have found this forum because of browsing for info to recovery my data but I am on Apple platform (MacOsX 10.5.7).
Is there anyone to talk in Appleish?
Many thanks,
Carmine
PostPosted: June 17th, 2009, 22:12
DR is platform independent , it depend on what you need...
