falther wrote:
@ HDD Spaz
Data Compass is definitely not a cloning / imaging device.
You don't know what your talking about. Of course it's an imaging device.
Fromthe salvation data website :
Pioneered
Disk Image Technique - ShadowDisk, which
images the sector physically from the defective drive to a functioning drive at the same time as the sector is being requested automatically. So that each sector being requested will first be
imaged to a good drive, and then the read/write request will be directed to the image disk. You don't need to spend lots of time to create an image, but actually you are working on an image.
Data Compass adopts UDMA100 transmit protocol to reduce the time it takes to
image a disk with bad sectors, which is at least 30% faster than any other imaging tools available elsewhere.
Stop and continue imaging as needed - configuration information together with the map of good/bad/unprocessed sectors are saved on the destination drive, so whenever you stop you will have the read permit to each imaged sector. Shadow Disk will also record each sector you successfully read from the source drive during the
imaging process. There is no way you would lose what you've done.
Real-time monitor, buzzer and LEDs give you a clear feedback of the
current imaging.
We give
total control over imaging parameters: passes scripts configuration, read timeouts, retry attempts, bad sector retrieval (Error Correction Code (ECC) processing), selectable read commands (PIO or UDMA), and error-dependent imaging algorithm based on UNC/AMNF/IDNF/ABRT bad sectors or read/ready timeouts.
And you say its not an imaging device. Have I missed something?
