 Post subject: [Ask]The Partition is not accessible
PostPosted: January 3rd, 2009, 1:43
Hello guys, I have a problem with my slave harddisk. There are two partitions in my slave harddisk. When I want to open one of the partition, there is warning message "E:\ is not accessible, The file or directory is corrupted and unreadable". But sometimes, when I want to open the partition again, the windows stated that the drive is not formatted and ask to format the partition again. I check the format of partition and it becomes raw format now.
Is there any software that can fix this problem ?
I will appreciate if anyone here can help me to fix this problem.
 Post subject: Re: [Ask]The Partition is not accessible
PostPosted: January 3rd, 2009, 5:30
This state that BR still GOOD and Problem with File System Structure
State that BR already Damage and Window can not read BR as well. Win will act it as New Partition and ask to Format it.
if you need data of course format it is a bad solution...
I'm affraid this drive Got Bad sector.
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 4th, 2009, 6:52
@ prodata
So, is there any software that can fix this problem ?
PostPosted: January 4th, 2009, 22:03
if Drive got seriously bad sector.. I think DR software will not help you the most.
better to send it to nearly DR in your place if you need data....
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 5th, 2009, 7:46
arow wrote:
@ prodata
You can try to access your data with commercial DR software, but Prodata is right, if data is valuable and there is possibility of BAD sectors, send to a professional for a evaluation.
