 Post subject: 7200.11 shows 0mb
PostPosted: September 3rd, 2009, 5:19
hi all
i have the seagate drive witht eh error of 0mb, i have done several of these with no issues but this one will not work.
drive spins up, shows, model , serial and firmware sd15, it then shows translation error,
i run the solution and it fails, i try and run it manually and i get the below results
F3 T>/1
F3 1>N1
F3 1>
F3 T>i4,1,22
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8
Error 1008 DETSEC 0000500D
User Partition Format Failed - Elapsed Time 0 mins 00 secs
R/W Sense 00000002, R/W Error 00000084, File Error 00001002
Blk Addr 01080001, Blk Addr Type D0, Cyl 00000000, Hd 00
F3 T>
have i missed something here.
Thank you
 Post subject: Re: 7200.11 shows 0mb
PostPosted: September 3rd, 2009, 6:08
BADS in SA?
up the read/write retries when you regen translator.
PostPosted: September 3rd, 2009, 6:13
hi,
thank you for the reply
do you mean N? up to a larger nuymber such as 10 or more
thank you
PostPosted: September 3rd, 2009, 9:43
Hi ,
Increasing retries refers to :
m0,6,2,2,2,0,0,22 , but confirm from a recovery pro here before use , using the option 2 for read and write retries .
and do not use the command m0,1,1,0,0,0,0,22 it is mentioned in some other forums as a remedy to translator command failure .
Cheers,
Nitin
PostPosted: September 3rd, 2009, 19:10
hi guys
went through several more atemps and it is showing that it is most lieky an isse with bad sectors in SA as pointed out by HZZ SPAZ.
as the drive was dropped i am wondering if it is a scratch on the platters or possibly a fault with heads,
have you come accross this before, if it is bad blocks in SA can anything be done to work around issue ?
thx for all replies
PostPosted: September 4th, 2009, 4:24
after you perform the procedure to regen translator does the hard drive LBA appear correctly before powering down?
See if you can access data without powering the disk down after you run the commands.
PostPosted: September 6th, 2009, 4:50
Hi
lba does not appear. Tried new heads same thing exactly happens
PostPosted: September 6th, 2009, 6:51
@Crecomp,
see if u can find something here
http://www.msfn.org/board/solution-seag ... ge-80.html
http://www.msfn.org/board/solution-seag ... ntry881318
PostPosted: September 8th, 2009, 9:22
I assume from the post that you have some problem with defect table. Can you view PLIST or Slip list with 'V' command?
PostPosted: September 8th, 2009, 10:11
Nitin wrote:
Hi ,
Cheers,
Nitin
this will destroy user data.
Users browsing this forum: Google [Bot] and 114 guests
