 Post subject: restoring a drive to max capacity part 2
PostPosted: January 23rd, 2010, 15:37
OK I now have the hard drive I spoke about in this thread
need-help-restoring-drive-max-capacity-t14529.html
in a computer and ready to go.
I ran MHDD disk tools and used help, tried a few of the commands NHPA FDISK drv_reset and couldn't accomplish anything. The drive is still showing up as less than 32 when booted in XP.
I tried Sea tools for DOS and It did tell me the right size of the drive 163+ GB but when I tried to get it to restore the drive to max capacity it failed instantly.
What do I need to do to get this drive to max capacity.
I've already got the 2 boot discs I mentioned above and
disc wizard
samsung disc manager diagnostic tool
I'm pretty much lost in DOS. Any help.
 Post subject: Re: restoring a drive to max capacity part 2
PostPosted: January 23rd, 2010, 16:52
So now I'm trying the capacity restore tool.
IT detects the drive and says it is 163 GB meanwhile windows still says it is 31.4.
When I select the drive on the opening screen the pop up says...
This operation will determine factory capacity of the drive .
If the device is detected in the system, it will now be removed from the device manager.
This is needed to avoid conflicts with the operating system.
Then I select "OK", the other option is "cancel."
device is currently in use please remove it from the device manager manually
So I uninstall it I disable it, everything requires a restart and the drive is auto detected again and I'm back where I started.
Anyone have any ideas?
Users browsing this forum: No registered users and 80 guests
