 Post subject: hdd laptop st9500325as 500 seagate head fail
PostPosted: January 27th, 2010, 13:59
hi all
first hdd customer hdd laptop
st9500325as
pn:9hh134-566
fw:0001BSM1
this hdd is fallen then clik clik and not detect with 0 byte detect
in pc3000
( model and serial is ok but size 0 byte ) mqaybe for rom flash
second hdd
st9500325as
pn:9hh134-566
fw:0002bsm1
this hdd was work
conditional repalce head is model hdd
is it true? do you think head fail
NS DATA RECOVERY
www.nsrecovery.ir
 Post subject: Re: hdd laptop st9500325as 500 seagate head fail
PostPosted: January 28th, 2010, 4:02
as the hard drive has been dropped it wont be a rom flash problem
the reason for it to be clicking all the time
is that
it has lost its service area alighment
so that why its 0 bytes
and its more likely possible headstack damaged
which your have to replace.
PostPosted: January 29th, 2010, 12:47
thanks fro replay
i swape head but not worked , i think missed second head
then i swaped head again with original donor
the first time detect (true size) and then not detect again in port terminal
Rst 0x08M
RW cmd 0002 req = 40 55 00 00 08 00 00 00 00 00 00 00 00 9A 05 00 FF 9E 05 00 00
9A 05 00
opts = 00001121
RW Err = C3160080
RW cmd 0002 req = 40 55 00 00 01 00 00 00 00 00 00 00 00 9A 05 00 FF 9E 05 00 00
9A 05 00
opts = 0000112
F3 T>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:00237E89
what means this message?
it mean heads or any of 4 head in failure
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 1st, 2010, 16:43
i tested with second donor with same model and firmware 0002bsm1
in end not detect again swap head to original head and worked
1. first head write white stiker wy4-t TICB-C
i2. second and third head is writed wy4-t TICB-B
in this condition 1,2 heads not match
is it true?
with thanks
ha bid
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 4th, 2010, 4:09
Donor disk for seagate:
1 Same Model
2 Same FW
PostPosted: February 17th, 2010, 1:33
hi
we need Model and Firmware only to check on Donor Drive for seagate head swap ????
Thanks for any comments.
PostPosted: August 10th, 2012, 7:59
Does anyone know the significance of the WY4-T part versus the TIBC-C or sometimes TIBC# part?
Thanks for any insights.
PostPosted: August 10th, 2012, 17:20
It would seem to be irrelevant on this series drive in my experience.
Users browsing this forum: Google [Bot] and 229 guests
