 Post subject: Seagate ST9500325AS 5400.6
PostPosted: March 17th, 2010, 11:26
Hi
i have a problem with Seagate ST9500325AS F/W : 0001BSM1 F3 Family it is showing ID and Capacity i can't access SA i checked in Terminal it shows this Error LED : 000000EE FAddr:005C48A Appreciate for u r Comments Thanks.
 Post subject: Re: Seagate ST9500325AS 5400.6
PostPosted: March 19th, 2010, 3:42
what's that problem?
why do you want access to sa?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 23rd, 2010, 8:32
first of all do this:
1. disconnect pcb from heads, but keep motor connected and power on disk, turn on terminal ^Z
2. wait when motor stops and give a command to stop motor (/2 and Z)
3. press ^X
4. connect pcb and run drive by U command
5. when drive spins up
6. press ^X
7. type /T then V4
8. press ^X
9. send log to forum...
10. do not try commands like N1, m0... etc... it could destroy overlays at this moment.
PostPosted: March 23rd, 2010, 9:04
Hi
Thanks for Reply Problem solved.
PostPosted: April 2nd, 2010, 22:53
clayron, Can not say about how they deal with?
PostPosted: June 3rd, 2010, 17:17
I have this same drive with same or very similar problem (though my firmware is 0002BSM1 and the LBA is 0, model and serial # correct).
"LED: 000000CC FAddr: 00271D47" when I follow clayron's instructions after getting to V4 (same thing happens with N1, trans regen, etc).
Also, the U command gives me the following error:
"Spin Error
Elaspsed Time 17.463 sec
R/W Status 2 R/W Error 84150180"
The drive makes a purring sound (like a cat) when "reading."
Is this bad head(s)? Any advice/insight appreciated.
Rst 0x08M
ASCII Diag mode
F3 T>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
            opts = 00000000
RW Err = 84150180
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.124 msecs
F3 2>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
3312812391 99999999 1340445677 75  F553B510 4555B351 71 749505F3
1410597719 2392752624 2906684414 05  5DD53D45 55555D57 5D 144C55C5 SRV_FLW
1473664343 63066624 4283220514 30  5CD4C445 44CC5715 73 95476575 SPN_DN
1346657349 4167960302 532718848 15  14401595 45710115 47 95D15465 HD_DIAG
1364546929 17889580 100596288 58  D5712455 690571F0 10 55D4D556
1433474325 68927396 2140422655 46  D7713D49 129C3D31 7D 43455740 XFR_SEC BO 580755F2 VL 4170.354D
1431525828 4293018799 453637715 50  5C54C711 14540D4C 78 05D57615
178972843 3042414311 2147599869 AC  2EFCE3AA F8438B8E E8 AA2E8EEA
2997546510 2818573667 3624779994 28  88A7A2AE 3082AE32 AA B88FAA3E FIX_RAP
3182069931 184523421 754983415 A2  3CAE3AA3 FA22A2CA AB ADA3AA26
1848290020 2961187385 2055212038 AA  89DA913A B8ABABBA BF DB827CA9
673946618 3120623894 2047020720 A4  ABEEAA28 E26AAAEA A0 CAA0BA28
3467553707 2793607089 3225468663 CA  A8A8AAAA B0AB38BA AA E6ABBBBB
1871424063 2698837652 1227817139 BF  A86A1A8A AAC88A6E BD 966FAB8C
448445859 2871989092 267451912 A4  EABBEE0A 886A8BBF 54 DD556651
1394422613 945976754 37167696 41  7DE5D774 C5758165 56 17E145C5 SEC2RLL
2505526351 1111103738 1207862662 17  FD455414 54940357 46 544D5557 REALLOC HARD UNMRK B 01443F55 L 00005705 BO 5D551D45 VL 5D57.5555 Valid 68
1597101143 3386542088 2972943109 57  594F7515 57565553 34 89077744
399791220 3097657373 763428097 75  D95D43D5 50545D45 D4 55455655
1352129397 952338177 1626958288 61  55355563 55555571 75 55745544
2086493403 734364006 3647994597 23  4158D550 55757515 45 C8554544 SRV_EC
407115127 2615589020 1065435038 05  70149775 555179C4 94 A5745254 SRV_FLW
2531982988 2124867861 664335407 A8  ABB2B2AB AAAE8AB A3 282BAEB6
       707 1762985015    14692 2F  000000 000000 2 84150180 SPN_UP NORMAL
     15394    14687 99999999 2F  000000 000000 AB B62A8ABB SPN_UP NORMAL
     15417       23        4 1B  000000 000000 1 00000080 MEM_DBG
     15421        4        0 03  000000 000000 1 00000080 RD_CHNL
     15421        0     3331 30  000000 000000 1 00000080 SPN_DN NORMAL
     26184    10763        1 27  000000 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
                                                          012F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
     26185        1        0 27  000000 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
     26185        0        1 27  000000 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 AD6F 00D0
                                                          AD6F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
     26186        1        0 30  000000 000000 1 00000080 SPN_DN NORMAL U
DiagError 00006008
Spin Error
Elapsed Time 17.462 secs
F3 2>
ASCII Diag mode
F3 T>
ATA  15 Cmds
RW  32 Cmds
2997546510 99999999 3624779994 28  88A7A2AE 3082AE32 AA B88FAA3E FIX_RAP
     89549    63363    17463 2F  000000 000000 2 84150180 SPN_UP NORMAL
    107012    17463        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 00D0
                                                          F802 E22C E559 E22C E5DD E006 ECD7 0080 0014 0080 0014 0080 0014 0080 0014 0080
    107013        1        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 00D0
                                                          0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080
    107014        1        0 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 D14E 00D0
                                                          0014 0080 0014 0080 0014 0080 0014 0080 0071 0080 0014 0080 0071 0002 D100 D14E
    107014        0        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
                                                          D120 DA00 DA4E DA20 0001 6247 C877 8100 E22C E559 E22C E5DD E006 ECD7 0080 0014
    107015        1        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
                                                          0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014
    107016        1        0 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0071 00D0
                                                          0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0071
    107016        0        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0000 00D0
                                                          0080 0014 0080 0071 0002 D100 D14E D120 DA00 DA4E DA20 0001 6247 C877 0000 0000 /T
F3 T>V4
LED:000000CC FAddr:00271D47
LED:000000CC FAddr:00259965
PostPosted: November 11th, 2010, 22:31
Got one with similar error:
Rst 0x08M
            opts = 00000000
RW Err = 84150180
Rst 0x08M
            opts = 00000000
RW Err = 84150180
ASCII Diag mode
F3 T>
ATA  15 Cmds
RW  32 Cmds
     62759 99999999        1 27  000000 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
     62760        1        0 27  000000 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
     62761        1        0 27  000000 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 AD6F 00D0
     62833       72    17386 2F  000000 000000 2 84150180 SPN_UP NORMAL
     80203    17370       17 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 0090
     80220       17 4294967281 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 0050
                                                          0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0080 0014 0000
     78173 4294965249     2048 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 D14E 00D0
                                                          0014 0080 0014 0080 0004 0000 0014 0080 0071 0080 0014 0080 0071 0002 D100 D14E
     80221     2048        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
                                                          D120 DA00 DA4E DA20 0001 6247 C877 8100 E22C E559 E228 E5DD E006 ECD7 0080 0014
     80222        1        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
     80223        1 4294967292 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0071 00D0
     80223        0        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0000 00D0
    146128    65905        1 27  020000 1000000 1 00000080 SND_SRV 0901 0020 0000 0000 0000 0000 0000 0000 0001 0000 00D0
                                                          0080 001C 0080 0071 0002 D100 D14E D120 DA00 DA4E DA20 0001 6247 C877 0000 0000
4292804607 4292658479 4280352735 FE  FFEFFFFF FFFEFEFF FF F7F7F7F7
4126668287 4128830976   526840 F7  F7FFFFF7 F5FFF7F7 FF FDFFF5FF
4261277693 134609406     3322 FD  FDFDFDE5 FFFDFFF5 2F 9F2F2F0F
2944368575 2978058178 271588208 BB  1B9F1F6F 2F3FBF7F EF 8E6ECF6F
3419385855 475017280 855658223 CF  CF8E4FCF EEEE0FDF 77 72F3F7F2
1945752563 2821334004 2138643582 F5  FAF3FF70 F77BBAF2 FC D5D4DDFC
2130509436 184756873 1375796054 F4  FA7CDC7D F6FEF4DE 7F FFFFFFFB
4217110367 2086600931 1687683228 FF  FF5EFBFF FF7B7B7B FE FFDFDFFE
3758087903 3835944832 536871199 FF  FFDEFFDA FFFFDFDF F5 F7F5F7FF
4160059379 401971476   165890 F7  F5F7F7F5 B5F7F7FF F5 F5FDF5FD
4126539261 4261447178 3758096384 FF  FFF5FFF5 FFFFFDFD 93 7F7FBF7F
2131442543 2299870578 3223250000 2F  3F3BAF1B 1B9BAF73 EF 4D5FCEEF SPN_UP
248418190 2411942943 3238051777 73  72737357 727973F3 FE 72707B76
3707567324 3459149134 4261411840 D8  F8D8D1FC 5EDEFEF8 F4 F8ECF8FD
4294705023 587137699 2080604288 FB  FB7FFEFF FB7F7BFF FF 7BFBFBFF
       707   262980    14528 2F  000000 000000 2 84150180 SPN_UP NORMAL
     15229    14522 99999999 2F  000000 000000 FE FBDEFEFF SPN_UP NORMAL
     15252       23        4 1B  000000 000000 1 00000080 MEM_DBG
     15256        4        0 03  000000 000000 1 00000080 RD_CHNL
     15257        1     3230 30  000000 000000 1 00000080 SPN_DN NORMAL
ASCII Diag mode
F3 T>/2
F3 2>U
DiagError 00006008
Spin Error
Elapsed Time 17.405 secs
F3 2>
ATA  15 Cmds
RW  32 Cmds
    146128 99999999        1 27  020000 1000000 1 00000080 SND_SRV 0901 0020 0000 0000 0000 0000 0000 0000 0001 0000 00D0
    133495   118238        0 27  000000 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
    133495        0        1 27  000000 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
    133496        1        0 27  000000 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 AD6F 00D0
    133569       73    17405 2F  000000 000000 2 84150180 SPN_UP NORMAL
    150974    17405        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 00D0
    150975        1        0 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0080 00D0
    150975        0        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 D14E 00D0
    150976        1        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
    150977        1        0 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0014 00D0
    150977        0        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0071 00D0
    150978        1        1 27  000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0000 00D0
F3 T>V4
PAD-dataservice
http://www.pad-dataservice.dk
PostPosted: December 3rd, 2010, 18:28
I am having a similar problem and have not had any luck fixing it. The drive had bad heads and I replaced them with a donor. Patient heads in donor enclosure confirm they were bad. Now the heads are good, but I am getting errors when trying to read in the drive's details. I ran the commands clayron suggested, and the output is below.
Rst 0x08M
opts = 00000000
RW Err = 84150180
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.141 msecs
F3 2>
ATA 15 Cmds
RW 32 Cmds
4294950911 99999999 4286595072 FF F777FFFD FF7FFFBF FF FFEFDDFF
4294901759 4294918144 4261478400 FF EFCFFFFF FFEFFFFF FF 7FFFFFFF
4294967287 65528 4286578568 FF FFFFFFFF FBFFFFBF FF FFFFDFF7
3992969199 3992969208 301932560 FF FDE7FDFF FFEDFFFF FB F7FF7FFF
4294967295 301998096 4290772992 FD BFFFFFFF FFFEFFFD FE FFFFFFFF
2134374391 2134374392 2160032768 F7 FFFFFF7F BFFFBFFF F7 B7FFF7FF
4292870137 2158495746 1965574 FF FFFFFFEF FFEDFFFF FE BDEDFFFD
4294932283 2062146 4147642564 7F FFFBF7F7 FFFFF7F7 FF FBBBFFF7
4026531839 4026566852 1878917087 FF FEDDFFFF EEEFFFFF BF FFFF7BFF
4286553951 260022112 8413344 F7 FFBF7FFF FF7BBBFB BF CDDFFFFC
3758026751 3766440096 536940528 FC FFFEDFFC FFFFFFFF FF FFFFFFFF
2944401407 3481341952 1145044924 F7 FBFFBF7F E7FFFFFF FF FFFFFFFE
2952396799 7995392 1023606766 FF FFFFFDEF FFDFFDFF F7 FFB7FFFB
4294967291 1342570492 4227842052 7F FFFBF7FF FFBDF7FF FF EEFFFFFF
4025483263 4025483268 3759144920 FF EFFFFFFF FDDFFFFF FF FF7FBFFB
4294933439 269450176 4294966335 FF FFFFB7FF FFFFBFFF FF FEDDBFFF
4294827759 4294861616 4294811920 FF EFFFDFFF FFFEFFFF BB FBFFFFFF
4294967295 139536 4152358784 FF FFBB3FF7 FFFFFFF7 EF EFFDFFCF
4177461247 4177461248 117506016 FF F7FFFFFF EDFFDFEF FF FFFFFF7F
2080374783 2197880832 2205679616 FF FFFFB7FF FFFFFFFF FF FFFFEDFF
4294967263 2214592480 4261412896 FF FFBFFB7F 7F37F7F7 FF FFF7FF77
4294959103 4294959136 3756006910 FF FEFFFDFF FFFFFFF9 EF FFDFFFFF
4160225147 4160233340 3208380420 FF F7B71FF7 FFFF773B 7F FF7FBFFF
709 134742858 12399 2F 000000 000000 2 84150180 SPN_UP NORMAL
13102 12393 99999999 2F 000000 000000 FF FDFFECED SPN_UP NORMAL
13124 22 4 1B 000000 000000 1 00000080 MEM_DBG
13128 4 0 03 000000 000000 1 00000080 RD_CHNL
13129 1 3290 30 000000 000000 1 00000080 SPN_DN NORMAL
39754 26625 1 27 000000 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
39755 1 0 27 000000 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
39755 0 1 27 000000 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 AD6F 00D0
39756 1 0 30 000000 000000 1 00000080 SPN_DN NORMAL U
DiagError 00006008
Spin Error
Elapsed Time 17.730 secs
F3 2>
ATA 15 Cmds
RW 32 Cmds
4026531839 99999999 1878917087 FF FEDDFFFF EEEFFFFF BF FFFF7BFF
764887 725131 17731 2F 000000 000000 2 84150180 SPN_UP NORMAL
782618 17731 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0380 00D0
F802 E22E E4F9 E22C E395 E006 EBAD 0380 0314 0380 0314 0380 0314 0380 0314 0380
782618 0 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0380 00D0
0314 0380 0314 0394 0314 0380 0314 0380 0314 0380 0314 0380 0314 0394 0314 0380
782619 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 D14E 00D0
0314 0380 0314 0380 0314 0380 0314 0380 0371 0380 0314 0380 0371 0302 D100 D14E
782620 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0314 00D0
D120 DA00 DA4E DA20 0301 6247 C877 8100 E22E E4F9 E22C E395 E006 EBAD 0380 0314
782620 0 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0314 00D0
0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0314
782621 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0371 00D0
0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0314 0380 0371
782621 0 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000 0000 0000 0000 0000 0000 0001 0000 00D0
0380 0314 0380 0371 0302 D100 D14E D120 DA00 DA4E DA20 0301 6247 C877 0000 0000 /T
F3 T>V4
LED:000000CC FAddr:002723EF
Any help is greatly appreciated. Please PM if you would not like to share with the general public.
Regards,
Dizi
PostPosted: December 19th, 2010, 9:22
what' that details donor and original hdd?
maybe is not compatible ?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: January 27th, 2011, 11:51
Details of original are:
ST9500325AS
FW: 0002BSM1
Site: SU
Serial: 6VExxxxx
Details of donor are:
ST9500325AS
FW: 0002BSM1
Site: SU
Serial: 6VExxxxx
Don't have the drives anymore, but still am curious about the solution for knowledge sake.
Regards,
Dizi
PostPosted: August 31st, 2011, 12:14
I have same drive
momentus 5400.6
ST9320325AS-(S1)
FW 0010lvm1
from notebook lenovo
with very similar problem BIOS show disk but LBA(0)
DiagError 00006008
Spin Error
Elapsed Time 12.470 secs
maby somebody know how to solve problem, please
F3 2>Z
Spin Down Complete
Elapsed Time 0.127 msecs
F3 2>
ATA 15 Cmds
RW 32 Cmds
4294967295 99999999 4294967285 FD 7FFFFFBF FFF7FFEF 7F 77FFFFFF
4227579390 4227579391 67387377 FA FFFDFFFF 7FDFBFF7 FF FFFFEBFF
2146959359 2214347265 2143813248 FF FFDFFFDF FFFDFFFB FF FFFFF7FF
4294934511 2147975152 2684354576 FF FFBFFFDF FFFFFFFB FF B7BFFFFE
4278185981 4278218766 4276097026 FC FEEFFBFF FBFFFFFE FF FD7FFFEF
4294967295 16781314 4294956532 FF FFFEFFFF FF7FFFFB F5 FEFFDEFF
3758095101 3758095102 534185218 FF FFFFFFF7 FDFFFFFF FE DFFEFFFF
4261412607 503317506 4194304256 FF ADFFFFDF EFFFFFFF FF AFFFFFFB
4227856383 4261411072 50267136 2F FBDFFFFF FEFFFFFF FF FFFFDFFE SPN_UP
4293918655 66062272 1048544 FF BFDFFFFF FEFFFFFF F5 7FAFFDFF
4294967294 1048639 4143970297 FF FBF7FDF9 FFFFFFF7 FF FFFFFDFF
4294967279 4294967281 4294672384 FF FFFDBF7E F7FFFDFF FF FFDEFBFF
4024172543 4024172560 270794232 FF FFFAFFFE FDFFEFFD FB F97DFFFF
4294893559 270721016 4293812231 FE 6FBFFFFF DFFFFFFA BB F6FFEFFF
2147483647 2147557384 2139094784 F7 7FDF7FBB BFFFDADF FF FFEFFAFF
4294836223 2147352576 4261543936 FF FFBDFFFE FFFFFFFF FB FFBFFDFB
4293918717 4294049790 4262460410 EF BFFFDFFD FBFBBDEE 7F DFE6FDFA
4294967167 1048450 4286578816 FF DDFDF77 7FF7FFFF F7 FFFFFFFF
4160225262 4160225391 130546673 FF FFFFFF7F FFFF7FEF DF FBFFFFAF
4227858427 67633165 67108483 B7 6FFFFDFF FEFFEFFD 7F FEAFFF78
4294934262 67075835 33029 FB FFBEFFFF FFF7FFFF FC FEFFFFFF
4294967295 33033 4026531776 BA FFFFFFFF DFFFFAED FF FEFFBFFF
3085959162 3085959163 1191968773 FF EB7FFFFF FDFFFEFF FF FFF7FFEF
4227858367 1141899205 4294901824 F7 A7FFFFF7 FBFFF7FF FF CFFFFFFB
4294967287 67108920 4253024248 7F FE97EFF7 FFEFFFBF FF FEFFFFFE
672 681 11339 2F 000000 000000 2 84150180 SPN_UP NORMAL
12005 11333 99999999 2F 000000 000000 FD FFEFF7FF SPN_UP NORMAL
12011 6 3291 30 000000 000000 1 00000080 SPN_DN NORMAL
66942 54931 1 27 000000 000000 1 00000080 SND_SRV 0501 0000 0000
0000 0000 0000 0000 0000 0001 0130 00D0
0130 0000 0000 0000 00
66943 1 0 27 000000 000000 1 00000080 SND_SRV 0106 0000 0000
66944 1 0 27 000000 000000 1 00000080 SND_SRV 0501 008F 0000
66944 0 0 30 000000 000000 1 00000080 SPN_DN NORMAL U
DiagError 00006008
Spin Error
F3 2>
ATA 15 Cmds
RW 32 Cmds
4227856383 99999999 50267136 2F FBDFFFFF FEFFFFFF FF FFFFDFFE SPN_UP
212744 145800 12471 2F 000000 000000 2 84150180 SPN_UP NORMAL
225215 12471 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
0000 0000 0000 0000 0000 0001 0001 00D0
F802 C873 8100 E22C E5
57 E22C E5DD 0001 407F C873 8100 E22C E557 E22C E5DD 0001
225216 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
0000 0000 0000 0000 0000 0001 E22C 00D0
407F C873 8000 8106 C8
81 8000 8100 E22C E557 E22C E5DD 0001 407F C873 8100 E22C
225217 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
7F C873 8100 E22C E557 E22C E5DD 0001 407F C873 8100 E22C
225217 0 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
225218 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
225218 0 1 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
225219 1 0 27 000000 000000 1 00000080 SND_SRV 0901 0000 0000
7F C873 8100 E22C E557 E22C E5DD 0001 407F C873 0000 0000
/T
F3 T>V4
LED:000000CC FAddr:0026A53F
PostPosted: August 31st, 2011, 13:19
I had a Momentus 5400.6 today which IDs and comes ready but showed 0MB. Bad sectors in translator module in SA. Recovered SA with the new 'fork' method, worked really well, drive imaged 100%
Data Recovery Cape Town
PostPosted: September 1st, 2011, 3:53
Can you describe this 'fork' method please?
PostPosted: September 1st, 2011, 16:22
It's a function that PC-3000 performs, it's done automatically with new version.
PostPosted: September 2nd, 2011, 3:24
Is it possible to do the same thing by connecting through the rs232 whith help
hyper terminal?
PostPosted: August 28th, 2013, 2:18
Little bit change I have followed, written in bold what I did, and attached the LOG
(As the DRIVE comes READY, that's why I didn't disconnect PCB from heads, there is another reason because after disconnecting terminal shows nothing even after shorting the pcb)
3. press ^X
6. press ^X
7. type /T then V4
8. press ^X
Log attached
Please now advice.
Original problem: Drive comes Ready but 0 LBA. translator regen doesn't work to restore capacity.
NB: Before issuing any command, V4 had same output as now.
LOG ST.rar [1.28 KiB]
Downloaded 1452 times
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
