 Post subject: DELAYS found in HARD DISK
PostPosted: December 20th, 2010, 9:50
hello everyone....
i was running my pc fine with within a month it has become very slow.it takes a lot of time during booting and also takes time during start up.
when i try to copy files from one drive to another it hangs suddenly and nothing works and i have to restart. this happens when i am transferring data from c to other drive.
i am formatted my c drive but still i am experiencing the same.
please help me to solove this problem.
i dont want to loose my data.
my hard disk is seagate 250gb and is 2 years old.
i used HDD Regenerator to find delays in my hard disk with 0 bad sectors.
please provide a solution fast..
Thanking you.
 Post subject: Re: DELAYS found in HARD DISK
PostPosted: December 20th, 2010, 10:19
Hi
connect your Hard Drive to another Computer and install any recovery software open your Defective Drive by recovery software and copy Data.
PostPosted: December 20th, 2010, 10:53
microsoftengineer wrote:
Hi
thx a lot for ur help.
but i dont have other pc i have checked by hdd regenerator and it shows that i my hard disk has delays please tell me some software from which i can fix those delays.
PostPosted: December 20th, 2010, 11:23
i have taken some screenshots from HD Tune Pro
i think i am in a deep trouble.
but hdd regenerator is not showing bad sectors its showing delays found in hard disk.
please help..
PostPosted: December 20th, 2010, 19:05
A drive with 717 reallocated sectors can't be trusted. I recommend that you replace it.
The flatlined benchmark suggests that the drive may be running in PIO mode.
Windows XP will downgrade a drive's performance from DMA mode to PIO mode if it detects more than 6 CRC errors.
DMA Mode for ATA/ATAPI Devices in Windows XP:
http://www.microsoft.com/whdc/device/st ... E-DMA.mspx
DMA reverts to PIO:
http://winhlp.com/node/10
PostPosted: December 21st, 2010, 13:11
DMA reverts to PIO:
id there any software through which i can repair my hard disk coz i cannot effoert to loose my data and when i tries to copy it hangs suddenly.so pls give a full proof solution.
PostPosted: December 21st, 2010, 13:21
means my hard disk is in PIO mode.
and that is why my pc is working slower.
can i enable dma mode ?????
enabling dma mode will make it faster or not????
should i use hdd regenerator to repair the delays ..????????
or should regenerate every sector?????????
PostPosted: December 22nd, 2010, 11:02
i have taken screenshots of hd tune pro when i installed windows 7 the graph has changed please have a look.
now what does this suggest????
PostPosted: December 22nd, 2010, 12:08
should i use MHDD to low level format my hard drive...
will it solve the problem....or something else to format.....
please help and reply soon...
PostPosted: December 22nd, 2010, 13:31
my data is getting corrupt and i am not able to access files on my hard disk like rar files or iso files coz they got corrupted . is der any process to bring these files to their original state coz they are precious to me...
pls reply .....
i am not getting proper responses...
PostPosted: December 22nd, 2010, 13:41
Are you REALLY sure you don't have ALSO viral problems ?
PostPosted: December 22nd, 2010, 17:15
Do not format your drive -- formatting is data destructive.
Your drive now appears to be running in DMA mode. However there appear to be many slow sectors.
You need to clone your drive, sector by sector, and then use data recovery software on your clone, if necessary.
Some freeware cloning tools are ...
HDclone: http://www.miray.de/products/sat.hdclone.html
dd_rescue: http://www.garloff.de/kurt/linux/ddrescue/
ddrescue: http://www.gnu.org/software/ddrescue/ddrescue.html
Comparison between ddrescue and dd_rescue:
http://www.forensicswiki.org/wiki/Ddrescue
ddrescue can perform multipass cloning. It clones the easy sectors on the first pass, and attempts the more difficult ones on subsequent passes.
http://en.wikipedia.org/wiki/Ddrescue#R ... ants_of_dd
http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
The following is a GNU ddrescue example from Wikipedia:
# first, grab most of the error-free areas in a hurry:
ddrescue -n /dev/old_disk /dev/new_disk rescued.log
# then try to recover as much of the dicey areas as possible:
ddrescue -r 1 /dev/old_disk /dev/new_disk rescued.log
PostPosted: December 22nd, 2010, 17:44
Too many things don't match:
Formatted ? Then data was already lost. Then :
... on the same drive ?!? And now :
WHERE are those files ? On the previously formatted drive or elsewhere ?
vaibhav wrote:
pls reply .....
Until you don't make PROPER questions and tell things as things are, you won't get proper answers. Crystal balls don't help, unfortunately.
PostPosted: December 23rd, 2010, 6:22
vaibhav wrote:
hello everyone....
Thanking you.
If you can't afford to lose your data, the best solution is go to a pro, there is indian guy on this forum, I am sure he can help..
Good Luck.
RAID/Server Recovery
PostPosted: December 23rd, 2010, 9:20
vaibhav wrote:
pls reply .....
i have 4 partitions .... c d e f
c has windows and i only format c drive not others coz other has data.
i only tried to copy files from c drive not from others and yesterday when i tried to copy from other drives i could not copy from them also .
crc errors were found in the files and error messages came that the file is corrupted now ..also i checked that i have 3 years warranty left on my hard drive...
but i need to backup my data but the data is corrupted ...
will it be still corrupted after using recovery software or it will come to its original state as it was earlier..
hdd regenerator only shows delays with 0 bad sectors ..
hd tune pro shows reallocated sector count as
current -80
worst -80
threshold- 36
data -814
status - warning
but i read somewhere that new hard drives coming do not show bad sectors in chkdsk utility .
this time i am crystal clear and will be always from next time.
sorry for inconvenience caused..
PostPosted: December 23rd, 2010, 19:38
current -80
worst -80
threshold- 36
data -814
status - warning
Your thread began with 717 reallocated sectors, now you have 814. Backup or clone whatever data you can ASAP.
PostPosted: December 25th, 2010, 10:56
current -80
worst -80
threshold- 36
data -814
status - warning
yup they are increasing day by day.
PostPosted: December 25th, 2010, 16:32
which software i should use to backup my data and recover my data.
i have arranged an external hard drive of 250 gb.
PostPosted: December 25th, 2010, 19:09
My previous post lists three possibles. If you're not comfortable with any of them, then perhaps someone could recommend others.
Alternatively, see this thread:
best-cloning-imaging-software-for-t13745.html
PostPosted: December 26th, 2010, 4:19
@fzabkar thx a lot for ur help.
the softwares that u told earlier can clone the hard disk with bad sectors also.
i am confused.
should i use any utility in hirens boot cd version 11.
or something else.
tell the best software (dont include freeware)
i will download from torrent..
thx waiting for ur reply..
Users browsing this forum: Greenman, Majestic-12 [Bot] and 91 guests
