 Post subject: Hard Disk How To Wipe a Sectors Range Only
PostPosted: March 12th, 2011, 11:18
Is there any hard disk wipe utility that wipes drives from sector to sector? In few words, one hdd wipe utility that can wipe a sectors range,
I mean that allow you to choose the starting sector and erase from that sector on, some kind of offset, the final sector is welcome but not needed, it would be enough to wipe from a certain sector up to the last one.
Thank you if you have the right tip.
Vulcan kindly suggested me to use dd, but reading dd documentation, I don't understand how to use it for the purpose I ask above.
If you are practice with dd, thank you for any suggestion
C.
 Post subject: Re: Hard Disk How To Wipe a Sectors Range Only
PostPosted: March 12th, 2011, 12:10
Take a look at eraser I have used it to erase specific area's of the drive. I am not sure it will do sector ranges but take a look at it. http://eraser.heidi.ie/
PostPosted: March 12th, 2011, 15:14
Hi again,
Thanks for starting a new thread instead of continuing to hijack the HDDErase thread. :)
Since you said that you want to wipe several whole partitions, the approach which I would take is shown below, as it avoids you needing to worry about specifying LBAs. Note that you do this at your own risk! :)
a) Take a backup onto other media (and check it is valid!) for whatever data you want to keep on that disk, in case anything goes wrong.
b) Ideally, disconnect any other disk drives in the system, leaving just the disk to have partitions erased, in order to minimise the chances of you making a mistake and erasing the wrong disk.
c) Using Linux (e.g. via a bootable "live CD"), as root run "fdisk -lu /dev/---" (where "---" is the device node for this disk drive where you want to erase some partitions - the disk device node name does not contain a number, and it depends on your system configuration e.g. /dev/sdh or /dev/hdz or whatever).
This output from fdisk will report the size & starting LBAs of each partition on that disk, and also the partition device node names, which you will need to use with dd when erasing partitions from that disk.
d) Make sure that you have correctly identified the partitions that you want to erase e.g. by confirming their size from this fdisk output, with what you expect their size to be. If you are not sure that you have correctly identified the partitions to erase, then do not continue.
e) Since you are erasing whole partitions, you don't need to worry about specifying starting LBAs to dd - you just need to specify the partition device node name, as the "of" parameter to dd.
So as an example, to erase partition /dev/sdh3, you would run (as root):
dd if=/dev/zero of=/dev/sdh3 bs=1M
Note: You need to find the correct partition device node names (these have a number at the end e.g. /dev/sdh3 or whatever) for your system, from the fdisk output.
(FYI, by using "bs=1M" you would be specifying that dd should write 1MB blocks, and although that is not necessarily the size of I/O being done to the physical disk, this will be much faster than leaving dd to use its default blocksize of 1 sector. Using this is optional.)
f) Repeat this for all the partitions that you want to wipe.
g) Run fdisk again (or parted or whatever you like) to delete the partition entries of the erased partitions, from the partition table itself.
If you wanted to run dd just once and specify a starting LBA to erase from there to the end of the disk, this is possible - but you need to be aware of the effect which using a "bs" parameter will have in that case. For simplicity, I don't recommend this, but it's your choice.
If you're doing this from Windows, without using Linux, then a similar approach could be used - except you'd need to use the port of dd to Windows http://www.chrysocome.net/dd and to identify the partitions (i.e. Windows drive letters) which you want to erase using Windows (My Computer or Disk Management etc.) or the Windows dd program "--list" option.
You can use a hex editor in Windows, or hexdump in Linux, to confirm that the specified partitions (drive letters) are wiped (zero'ed).
There is a totally different approach which you could take - after making sure you have a good, tested, backup of the partition(s) you want to keep and of the MBR, then you could erase the whole disk, and then restore what you wanted from the backup. The risk with this procedure is that you are definitely using your backup in this case, so if anything is wrong with it, then you have a big problem. That is why I would not recommend this - but it's an alternative which some people might prefer.
Hope this helps. Corrections welcome :)
PostPosted: March 14th, 2011, 9:45
MHDD can do this easily
PostPosted: March 16th, 2011, 11:37
C.
WinHex:
Go to sector X
Beginning of block (Alt +1)
Go to sector Y
End of block (Alt +2)
Edit/Fill Block (Ctrl+L)
Angel Data Recovery
PostPosted: March 17th, 2011, 8:19
DMDE can do it
data recovery Poland
PostPosted: March 17th, 2011, 8:46
It's possible to do that in R-Studio's built-in editor. Select Fill on the Edit menu, specify the pattern to fill with, and start and end sectors.
R-Studio Data Recovery Software
Users browsing this forum: No registered users and 100 guests
