 Post subject: How can I fix a shorted Toshiba MK326GSX?
PostPosted: April 8th, 2011, 0:48
I have a Toshiba MK3263GSX 320GB/5400RPM 2.5" SATA drive from a customer's laptop. The laptop's motherboard and hard drive were shorted out when the AC adapter was plugged in (I'm still trying to find the reason).
I've taken a look at the PCB to see if I could figure out what's wrong. I bypassed the "S" fuse and got the drive spinning again, but it still isn't accessible. Are there any other components I could troubleshoot?
I have a working 500GB Toshiba MK5055GSX with a nearly-identical PCB. Would I be able to take the ICs from the shorted PCB and have them work with the donor PCB? I have the necessary equipment for rework/reballing.
Here are photos of the drives:
If anyone can give me some tips on this, I'd really appreciate it!
--James
 Post subject: Re: How can I fix a shorted Toshiba MK326GSX?
PostPosted: April 8th, 2011, 8:47
I can see there is ROM on location IC602 if u can replace this onto the Donor PCB. This should start your dirive, if its a PCB fault
PostPosted: April 8th, 2011, 10:01
I just finished swapping IC602, and it worked! I've got the drive backing up via Acronis as I type this. Thanks a lot for the help!
I'm still going to try to get the other PCB working, but that's gravy at this point.
Thanks again!
PostPosted: May 24th, 2011, 6:52
Hi guys,
I've got similar case, MK3263GSX didn't want to spin, I removed the fuse, bridge the solder points and now works good - I'm making a data copy right now, but I want to use this drive in future so it's better to protect it with a fuse.
My question is related to spare fuse. May I use any working fuse from any Toshiba drive? if not, what shall I pay attention while choosing the fuse? Currently I've got an old PCB from 52GSX and I'm not sure if shall I use it?
Waiting for an advice, thank You in advance.
PostPosted: May 24th, 2011, 18:50
See my notes:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
Littelfuse Surface Mount Fuses, N = 2A, S = 4A:
http://www.farnell.com/datasheets/48294.pdf
Users browsing this forum: pepe, szlaci_s70 and 204 guests
