 Post subject: data recovery to a SSD ocz vertex 2 80Gb
PostPosted: October 17th, 2011, 13:11
i have a ocz vertex 2 80gb which seems that doesn't get power. only the green led is on and at DDI seems buzy.
can someone do data recovery to it, how much will it cost and how long will it take.
PM
thank you
 Post subject: Re: data recovery to a SSD ocz vertex 2 80Gb
PostPosted: October 18th, 2011, 9:35
You should note here the controller it uses.
It is not always possible to repair, in such situation it would be useful to know if it can be recovered through its NAND memory.
Most new Vertex use Sandforce controller, which is with encryption. Im pretty sure your case has Indilinx controller, but I am not 100% on that.
PostPosted: October 19th, 2011, 4:01
If it's an issue with the onboard DC-DC converters, then the parts cost should be very low (a few $).
If you would like to identify the power supply test points, upload a detailed photo.
PostPosted: October 19th, 2011, 4:48
Common issue I see with Sandforce based Vertex is poor contact on 1 or more NAND chip. somehow legs of NAND can 'lift' and contact is no longer good. You can solve this through a reflow.
In case of bad controller, in my experience, device will show DRDY in status register but ID and capacity is wrong. This is same with Indilinx cases, but for Indilinx recovery is quite straightforward from NAND memory. Sandforce use encryption so repair is your only option.
Franc gives good advice, upload photo of PCB of side with Controller.
 Post subject: Re: data recovery to a SSD ocz vertex 2 80Gb & 120GB
PostPosted: January 30th, 2012, 9:56
Hello there,
I've got a similar OCZ 120GB Vertex 2. When in DDI it is stuck in Busy, & can't ID the drive.
The controller chip is as follows:
Sandforce
SF-1222TA3-SBH
PAC461.00
0411 Taiwan
As such encryption will be on by default so removing the NAND chips is not much use. Does anyone have any suggestions? I'm currently testing the components on the PCB to see if there are any obvious failures.
The quality of the image attached is not great, if need I can take more focussed picture.
All the best,
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: January 30th, 2012, 10:38
Although I didn't mention it before, I don't get any info from the drive when I have it hooked up by the TX/RX
PostPosted: January 30th, 2012, 16:18
If you would like to verify the onboard supply voltages, then could we see a detailed view of the underside?
Did you measure anything at the Vcc terminal of the Tx/Rx header?
Do any of the three LEDs light up (ACT, FLT, PWR)?
Here are datasheets for the MT29F64G08 NAND Flash:
http://read.pudn.com/downloads160/ebook ... ,128Gb.pdf
http://wiki.laptop.org/images/4/48/CL1_NAND_Micron.pdf
Product brief for SF-1200 processor:
http://www.sandforce.com/userfiles/file ... 060110.pdf
PostPosted: January 31st, 2012, 9:43
PWR (green) & ACT (blue) lights are on constantly when powered. The FLT (red) light comes on when initially powered for a fraction of a second, then turns off.
Attached is jpg of the underside:
I haven't had chance to check the electronic components as a couple of emergency jobs have come in this morning. Once I have I will post the results.
Thanks for the help,
John
PostPosted: January 31st, 2012, 10:23
Read with programmer and show content of ROM chip.
And post terminal log please.
Angel Data Recovery
PostPosted: January 31st, 2012, 16:22
ISTM that the supplies are probably OK.
The Vcore and Vio (+3.3V) test points would be the two coils, L10 and L11, in the top left corner. Measure the load side, ie the plated through-holes at C82 and C99.
I can't see the markings on U33 and U38, but they would be the PWM regulators.
PostPosted: July 11th, 2012, 5:14
I have similar issue like this.
I have the exact same drive and voltage at L11 / C99 is 0.9V, the voltage on L10 / C82 is 2.8V.
I have a short on D2, but it's not the diode itself, if I remove the diode, the short is still there and the diode itself works fine.
Does anyone have a schematics?
Any idea on how I could recover this?
Thanks and best regards,
Conair.
PostPosted: July 11th, 2012, 5:41
Connected terminal program to UART port, getting this:
CLI> PINRST
*** ROM 106 Mar 12 2009 20:29:35 ***
FW_SRC 0 SHA PASS!
*** EEPROM 207 Jan 3 2011 18:36:47 BuildServer:FW_Common_Critical_Fixes:P1_EEPROM_2_0_7_drop-290232 ***
IMFT25 Timing EPch
*** Patch 1.4.1 Mar 10 2011 16:30:10 BuildServer:P1_3_6_0_MP4_7:P1_3_6_0_MP4_7-300475 ***
IMFT25 Timing EPch
RCPch SAK0
ÿýÞÝÖÃX
Then lot's of strange characters.
PostPosted: July 25th, 2012, 6:20
Hello, can anybody help on this?
Thanks.
PostPosted: July 25th, 2012, 6:24
Thanks.
Remotely, likely not.
If the recommendations given so far in the thread are not helpful enough, then send it to a REAL professional.
PostPosted: July 26th, 2012, 17:54
Do you have schematics for this HDD?
Or any information about the power-supply?
Are you sure it is 3.3V on both supplies?
Thanks.
PostPosted: July 27th, 2012, 14:48
CLI> PINRST
FW_SRC 0 SHA PASS!
IMFT25 Timing EPch
IMFT25 Timing EPch
RCPch SAK0
ÿýÞÝÖÃX
Can you give full terminal log, with this "strange characters" ?
Angel Data Recovery
PostPosted: August 1st, 2012, 14:12
Sure ;)
Can you read that scrambled output?
File comment: Broken drive terminal output
SF_terminal.TXT [6.67 KiB]
Downloaded 2387 times
PostPosted: August 1st, 2012, 15:21
fayn wrote:
Sure ;)
Why not ;)
Hmm, your drive have been turning on only 14 times . Almost new drive.
Angel Data Recovery
PostPosted: August 1st, 2012, 15:32
An unusual way of finding it out ;)
I am curious what the drive tells about itself... Could you post / PM the output in a readable form?
PostPosted: August 9th, 2012, 6:30
Hello, could you send me these details as well?
Also, could you let me know how to decode?
Thanks.
HDD_log.txt [8.76 KiB]
Downloaded 2272 times
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 68 guests
