 Post subject: WD5000AVVS - PROBLEM, PLS HELP
PostPosted: April 13th, 2012, 15:34
Hello
I have a problem with the hard drive WD Caviar WD5000AVVS
The problem is that it has established an ATA password.
Please do not remove the subject, I have seen this issue;
http://forum.hddguru.com/unlocking-ata-password-for-western-digital-t8374-440.html
But I still can not unlock the drive by MHDD.
Every time I try to open the program writes the script, "Incorrect version or batch file"
It's about this script:
; script name: read md
; reads md 02 on WD drives Marwell
reset
waitnbsy
regs = $ 45 $ 0B $ 00 $ 44 $ 57 $ 80 $ a0
waitnbsy
regs = $ d 6 $ 01 $ be $ 4f $ c2 $ a0 $ b0
waitnbsy
checkdrq
sectorsfrom = cs.bin
regs = $ d5 $ 01 $ bf $ 4f $ c2 $ a0 $ b0
waitnbsy
checkdrq
sectorsto = 21.bin
waitnbsy
checkdrq
sectorsto = 22.bin
end;
What am I doing wrong?
Please help because I really depend on that drive, I have no important data on it.
I`m Polish - translated by google
 Post subject: Re: WD5000AVVS - PROBLEM, PLS HELP
PostPosted: April 13th, 2012, 19:23
If you have no important data, and if the master password is still at its default setting, then you could try the following:
http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml
PostPosted: April 14th, 2012, 1:58
OK, thanks - we'll see if that works.
PostPosted: April 14th, 2012, 3:24
How do I use this program? I did.
Iso on the cd, I turned the computer
off the CD, boot the thing itself, then
I had to choose a driver and as a
result could not see the program
window. Before I checked the
windows should look like window.
What should I do?
PostPosted: April 14th, 2012, 14:11
I managed to run the program, but he unlocked the drive
gave such a password that did not work and did not remove the password disk
also Secure Erase thread because it requires a password.
Where is the saved password?
Disk or in ROM?
And how are things with this script?
I care about this drive.
PostPosted: April 14th, 2012, 15:05
If you really care about this drive. I think it would be wise to find a person close to you that has the proper tools and know how to unlock this HDD for you. Make suer you take proof of ownership and can prove this is your HDD other wise no respected company will touch this one. There are too many problems to unlock a HDD that does not belong to the right person and nobody in this field will do this one for you with out proof of ownership. This should be simple and not cost you very much to have this one done professionally. Other wise you will need to study HDD, modules, and how all this works with passwords and then buy the tools needed to get it done with. Will be cheapter to take it to a shop in your area and have it done for you.
Iorana Haraharaini
PostPosted: April 14th, 2012, 15:48
So it happens that the drive was purchased for allegro.pl - Polish side of the auction. I bought it for 10 PLN or your $ 3-4
The disk was most likely drawn from a set-top box or DVR. Unfortunately, I do not know the person who could, which she could do it. That I am a total geek, these threads - you must want to learn something like that.
But back to the topic - apparently this script to the MHDD really works - so I want to do it.
What is wrong in this script?
I have just noticed the differences in files script - in the example file sample.mba are some strange characters, and in my letters are normal. I figured that the script must be written in some other way - the program?
My script file I created in this way;
First I created a new file in Notepad
Second pasted the script which is located above the subject
Third save as> script.mba
Any ideas?
Here are the files in which I noticed these differences;
http://www.sendspace.pl/file/44e8c51030fab3b4e09f90f
http://www.sendspace.pl/file/6b5f6e235e409dc3a7aad26
PostPosted: April 14th, 2012, 17:12
Did you read this topic? unlocking-ata-password-for-western-digital-t8374.html
Iorana Haraharaini
PostPosted: April 15th, 2012, 3:25
So I read this, I wrote about that - but not too well know angileski and the translator is not enough.
PostPosted: April 15th, 2012, 4:00
wirus wrote:
angileski
*english*
Exactly what the extension should have a script file?
I turned on the editor and created HxD mw.mba and cs.bin
But I noticed that the files in the folder MHDD v4.5 script, the files have the extension - is this what? But how do the file without extension?
OK, I ran the script finally, now crashes for me "drive reports error"
LOG:
[PRE]
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 04
  [ Drive parameters - PRESS F2 to DETECT ]   [        Current position       ]
*  CONFIG         Configure a drive. View current config *
*  SETCDSPEED     Change current CD speed (IDE only)     *
*  UNITSIZE       Change unit size (SCSI)                *
*  SCSIFORMAT     Format unit                            *
ţ Use command MAN to see detailed help
ţ Press <SHIFT+F3> to select controller
MHDD>.mw.mba
MHDD ATA/SCSI TERMINAL v2.1
Script: MW.MBA
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
LINE 1: RESET
LINE 2: WAITNBSY
LINE 3: REGS = $45 $0B $00 $44 $57 $A0 $80
LINE 4: WAITNBSY
LINE 5: REGS = $D6 $01 $BE $4F $C2 $A0 $B0
LINE 6: WAITNBSY
LINE 7: CHECKDRQ
LINE 8: SECTORSFROM = CS.BIN
ERROR: drive reports error
| Help : <F1> and command MAN                                       | 10:06:34
[/PRE]
PostPosted: April 15th, 2012, 10:50
I figured that I have a bad file cs.bin
Except that I do not know what is in the wrong ...
Does anyone wrzycić Mølby this file to a server?
Or the mail;
mkwirusek82@gmail.com
PostPosted: April 15th, 2012, 13:12
Or the mail;
move this file to the server *? - cs.bin
PostPosted: April 15th, 2012, 18:29
Use your hex editor to create a binary file of size 512 bytes containing the following hexadecimal data:
0x000  08 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00
0x1f0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Otherwise you could use Debug in a Windows DOS box, as follows:
D:\>debug
-f 100 2ff 0
-e 100
12EB:0100 00.08 00.00 00.01 00.00 00.02
-rcx
CX 0000
:200
-n cs.bin
-w
Writing 00200 bytes
-q
PostPosted: April 16th, 2012, 12:51
Good?
PostPosted: April 16th, 2012, 18:23
http://www.users.on.net/~fzabkar/temp/CS.BIN
PostPosted: April 18th, 2012, 10:16
OMG!
Drive reports error!
Do you have any ideas?
PostPosted: April 18th, 2012, 18:43
What does the drive report in response to ID, EID, and Smart Att commands?
PostPosted: April 19th, 2012, 9:51
security; max on
s.m.a.r.t. - realocadet sector count - ALE wcześniej próbowałem remapa - oczywiście się nie dało, a smart pewnie naliczył
PostPosted: April 19th, 2012, 10:07
With respect, I think it's time to give up and say goodbye to your $4 investment. :-(
PostPosted: April 19th, 2012, 13:38
:mrgreen:
Iorana Haraharaini
Users browsing this forum: No registered users and 93 guests
