 Post subject: How to unlock Seagate momentus 7200.4
PostPosted: April 14th, 2012, 6:12
HDD: Seagate momentus 7200.4 500GB
Wwn: 5000C50038431C8D
SN: 5VJBKN4F
ST9500420AS
PN: 9HV144-037
FW: D005SDM1
I don't care about data from this drive
 Post subject: Re: How to unlock Seagate momentus 7200.4
PostPosted: April 14th, 2012, 11:06
seagate-non-standard-ata-master-password-t12920.html
with Sediv : Vendor to Track Seek, Read Track, Copy Bufer Read to Write Buffer, Edit Buffers to First Byte 00, wrote the buffer back to the drive.
SeDiv Seagate Terminal:
http://sediv2008.narod.ru/Easy1014.rar
English documentation:
http://sediv2008.narod.ru/HelpEn.rar
See this thread:
sediv-hdd-seagate-terminal-for-windows-t11980.html
In order to get SeDiv to run, you may need to wind back your system date to the date stamp of sediv.exe.
You will need to access the drive via its TTL RS232 port. To do this, you can use an adapter such as the ones described in this thread:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
PostPosted: April 14th, 2012, 12:56
http://www.hddunlock.com/
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: April 14th, 2012, 12:59
RMA should work
PostPosted: April 14th, 2012, 14:56
Prove it is your HDD and see a person with know how and tools to do this one for you.
Iorana Haraharaini
PostPosted: April 14th, 2012, 17:57
HDD Unlock Wizard "cannot detect hard disk"
Disk is connected do my Dell Latitude via eSata or via Sata
PostPosted: April 14th, 2012, 18:17
Are you sure that the drive is locked by an ATA password, and not any other kind of problem?
Is the drive shown with the correct make, model & capacity in the BIOS disk setup screen of the PC?
What are the steps which led to this situation - what changed between the drive being usable, and now?
Or follow the suggestion from Doomer :)
PostPosted: April 14th, 2012, 18:50
i'm sure disk is locked by ATA password.
Tomorow i have to buy new drive (Seagate Momentus XT 500GB)
Now i'm sure RMA will be the best for me, but time is money
PostPosted: April 14th, 2012, 19:15
OK, since you have a plan then I'll stop here. Good luck!
Users browsing this forum: No registered users and 326 guests
