 Post subject: Hard drive showing as the wrong size?
PostPosted: June 14th, 2012, 14:19
What does it mean when a utility reports the incorrect size of a hard drive? I see it all the time, but what causes this?
Right now I have a 640GB Western Digital and for whatever reason, it shows as 250.2 GB in Disk Utility (Mac program)
 Post subject: Re: Hard drive showing as the wrong size?
PostPosted: June 15th, 2012, 18:00
I guess this is related to your other thread:
quote-needed-for-hard-drive-repair-recovery-t23226.html
but I'll reply here instead of there, since that seems specific to getting a quote for a fix.
That depends on exactly what "size" that specific utility is reporting - I can think of at least 4 possibilities.
That is not my experience - when the exact meaning of the reported size is understood.
That depends on what "this" is :) More diagnosis needed IMHO. As I said, I don't see your reported behaviour "all the time" at all. It would be interesting what pattern you can find in the disks reporting this e.g. similar reported "new" capacity? Or similar reduction from normal capacity? Or similar action immediately before the problem is seen? Or similar machine type in each case? Or similar disk model in each case? etc. See what I mean?
I don't work with Macs, but on a PC, I'd start with MHDD or HDAT2 etc. and look for an HPA or DCO on the disk, as well as checking what the disk reports in an Identify Device response. Then proceed from there...
Users browsing this forum: No registered users and 249 guests
