 Post subject: Another Maxtor OneTouch II that Won't Boot (Pics)
PostPosted: November 2nd, 2012, 1:10
I have a second Maxtor OneTouch II 300GB Hard Drive, that will not rev up.
I believe that in this case also, a 19V power input was plugged into it instead of the 12V it requires, and I understand that this is a somewhat common error and that a frequent result is a fried TVS Diode.
As before, I have attached some pictures of the board and I am hoping someone with more knowledge than me can diagnose if this is the problem and, if not, what the issue might be...
I welcome any advice and proposed solutions. Thanks.
 Post subject: Re: Another Maxtor OneTouch II that Won't Boot (Pics)
PostPosted: November 2nd, 2012, 19:51
There are two 12V TVS diodes, CR201 near the power connector, and CR501 near the SMOOTH motor controller. One of them will probably be shorted.
PostPosted: November 6th, 2012, 10:08
This is a duplicate post (and duplicate answer!!): maxtor-onetouch-300-hard-drive-won-work-pics-t24377.html
PostPosted: November 6th, 2012, 10:12
@Northwind,
Did you use copy / paste or did you take the time to read and type like Speedy Gonzales , all this in less than one minute ?!? :mrgreen:
PostPosted: November 6th, 2012, 10:13
:mrgreen:
Users browsing this forum: Majestic-12 [Bot] and 159 guests
