I'm always trying to solve problem with my samsung hdd.
My only access is a terminal using putty.
So here is what i found on this forum, on the net, and on another tools.
My materiels for doing my "researches":
1 good samsung sata drive
1 corrupt samsung sata drive (same as above)
1 usb corrupt samsung drive (the important one)
Legend :Black: Unknown command
Orange: Working command but needs explanationRed: Error code on executionGreen: Working and known command and resultsSamsung CMD List (ENG> Mode):[CMD LIST]
HE RT RC PD D DS DL DB DW DI DT M MD MS ML MB
MW FB FW DX SB CA DN DT DG DO BI SP RB KH ZM DZ
D1 LE PP RP FE FU EP EF RD WR SK QT QB QK QN QA
QL QS QG QW QR QD Q1 QC R0 R1 XT XL XN XA XC XE
XS XP XR SL AS AO AF OU ST
SU SD PK UV SM SG EI
WI MI PR PW RU WU DU TI TU DV LI WS WO CB DC MC
DP MP CI AT MT BB DD DE FD MF EV HT CC RF XV S1
S2 EL BD BS BC GO SS NS DA DR MR
LL LM LR LS LV
LT LB LD L4 LC
CMD without params (which returns something usefull !?) :HE: Help
LB: View BIRSLT (Harddrive info, serial number, firmware version, ....)
LD: View Zone Map
L4: View ?
LT: View Tlist
LS: View Slip List
LV: View Vlist
LM: View Mlist
LR: View Rlist
LL: View Pending-list
SU: Spin UP
SD: Spin Down
RT: Reset
CMD with params :Error code :E:0001: Command doesn't exist ?
E:0003: Bad command's arguments (THX hard2bit)
E:0004: Command is not supported in the current level (ENG>, DBG>, etc.) (THX hard2bit)
Switching Mode :Echap: Go in DBG Mode
GO: Return in ENG Mode
Here is my log from my good disk (my usb disk returns the same except firmware version !!!)
For now i don't know what can i do with that, if someone can help and explain the detail of this output.
cmd-full-output.txt [48.34 KiB]
Downloaded 4186 times
