 Post subject: Too many delays detected during HDD regenerator Scan
PostPosted: March 23rd, 2018, 20:13
My PC can´t open a 2Tb Seagate External Drive (If I go to Windows Disk Management I can see the Drive)
Im scanning with HDD Regenerator, I Connected the Drive as Internal using a Sata cable.
The scanning is running very slowly, here is what I got so far
Time: 141 hours
Progress: 8.40%
Scanned 160.400Mb (328.499.979 sectors)
0 bad sectors found
1.521.861 delays detected
I often see in forums that 1 or 2 delays are normal, but this drive have 1.5 Million delays in only 8.4%
What means to have this huge amount of delays?
Also I tried Ontrack EasyRecovery and warns me that I have bad sectors on my Disk, and when I scan it say that the completion time will be 2460 days
Anyone have suggestions?
Thank you
 Post subject: Re: Too many delays detected during HDD regenerator Scan
PostPosted: March 23rd, 2018, 20:16
With hdd degenerator, you will only kill the drive earlier. At least use Seagate´s own software for diagnosing it.
The drive probably have problems, and you need to decide if you want(ed) your data or not.
PostPosted: March 23rd, 2018, 20:28
why kill the drive earlier?
I used SeaTools, the S.M.A.R.T scan says is Ok
The Fix Test warns me that I have to have the data backed up before do any testing
PostPosted: March 23rd, 2018, 20:44
Seagate, already with problems, being tortured.
If the drive is already failing, the excessive access made by that program will increase other problems present in the drive.
Connect it to a computer, and try to access it with dmde . If possible, copy the data you need to other disks.
PostPosted: March 23rd, 2018, 21:19
Good.
Why? What is your goal with the drive/data on it?
PostPosted: March 23rd, 2018, 21:26
Ok, thanks
Im running DMDE and got a WinError 1117, sent me to Help: Device I/O Dialog Box
I think I have to do a Device Cloning
I used HDD regenerator because 6 years ago I had a problem with a external drive that got fixed using that software, and the Drive is still working fine
This drive is from a uncle, he needs to recover some documents from there, he uses that drive for everything (work documents and watch movies on the TV) and I know he has a heavy hand for electronics, I dont have a clue if the drives got hit, but I know that he unplugs the drive always without clicking the safe unplug button in windows
PostPosted: March 24th, 2018, 2:21
Alright, thank you.
For file recovery purpose, never ever run HDDRegenerator, SpinRite and the likes. It just does not do any good. It forces the drive to reallocated bad sectors, which is a bad practice for file recovery. We don't want this to happen. Rather, we want to prevent it.
Indeed, clone first, if you have the resources, know-how, etc.
viewtopic.php?f=1&t=36600
Overall, it would be best to understand how bad in shape the drive is. Have you run a SMART report?
PostPosted: March 24th, 2018, 11:28
Thanks for your responses, I did a SMART scan using SeaTools, Victoria and HDDSCAN
I heard about avoiding SpinRite, but I didn´t knew HDDregenerator was on the same list.
I Did the VERIFY test on Victoria, I get Block ******** Error: ABRT ,scanning at the start and at the ending.
I Don´t have a TTL adaptor
About paying for Data Recovery service, how messed up the economy is in my country, paying for the service is almost impossible.
File comment: In Victoria I only get a GOOD after the scan, but doesnt show any useful data, If I scan my main WD I get all the useful info
File comment: I Don´t know is this information is useful, comes from SeaTools
File comment: In SeaTools I only get a thumbs up
File comment: In HDD Scan I don´t receive any data
PostPosted: March 26th, 2018, 22:35
Getting all BLUE blocks in Victoria means that the HDD is dead? even when the SMART says is ok?
PostPosted: March 27th, 2018, 2:48
It is not completely dead, yet. But the firmware has a lot of problems, as it can't read user data area. Maybe, mechanical problem as well.
Need help by a specialist at this point, sorry.
PostPosted: March 27th, 2018, 21:14
oh crap :(
thanks anyway for the help, I apreciate it
I will contact a professional for this
Users browsing this forum: Google [Bot] and 65 guests
