 Post subject: Are WD's/SanDisk's SSDs now manufactured/designed by Huawei?
PostPosted: May 28th, 2020, 17:30
Ultrastar SAS Series Product Portfolio (includes Resources for Ultrastar DC SS540):
https://www.westerndigital.com/products/data-center-drives/ultrastar-sas-series-ssd
H507 Firmware Update:
https://support-en.westerndigital.com/app/answers/detail/a_id/29300
SDLTOCKR-018T-5CHW bin file:
https://download.wdc.com/ssd/prod_boot_dlp_Customer_SAS.bin
Western Digital and Huawei Sign Strategic Cooperation Agreement (Apr 8, 2019):
https://www.westerndigital.com/company/newsroom/press-releases/2019/2019-04-08-huawei
"Western Digital Corp. and Huawei have signed a Strategic Cooperation Agreement. The companies agree to a common goal of market success through the continuation of their relationship in the areas of HDD, SSD and NAND Flash storage technology."
Western Digital Ultrastar DC SS540 SAS SSDs: Up to 15.36 TB, Up to 3 DWPD:
https://www.anandtech.com/show/15066/western-digital-launches-ultrastar-dc-ss540-sas-ssds-up-to-1536-tb-up-to-3-dwpd
"Controller -- Proprietary"
Firmware header (HUAWEI_SAS3SFF_WI_200):
Offset(h) 00       04       08       0C
00000000  FC7C1A00 2B24EF25 48353037 03000000  ü|..+$ï%H507....
00000010  0D000100 00010000 00000000 09000200  ................
00000020  00E00100 00010000 0100E201 009B1800  .à........â..›..
00000030  00E10100 00000000 00000000 00000000  .á..............
00000040  00000000 00000000 00000000 00000000  ................
00000050  00000000 00000000 00000000 00000000  ................
00000060  00000000 00000000 00000000 00000000  ................
00000070  00000000 00000000 00000000 00000000  ................
00000080  00000000 00000000 00000000 00000000  ................
00000090  00000000 00000000 00000000 00000000  ................
000000A0  0D500000 0000D065 B0C33667 F0A70000  .P....Ðe°Ã6gð§..
000000B0  08460000 00000000 839E0000 03000000  .F......ƒž......
000000C0  B057A768 00000000 00000000 00000000  °W§h............
000000D0  00000000 00000000 00000000 00000000  ................
000000E0  48554157 45495F53 41533353 46465F57  HUAWEI_SAS3SFF_W
000000F0  495F3230 30000000 00000000 00000000  I_200...........
 Post subject: Re: Are WD's/SanDisk's SSDs now manufactured/designed by Hua
PostPosted: May 29th, 2020, 17:45
ICBW, but ISTM that the Ultrastar DC SS540 is a recent model and is not related to the SDLTOCKR-018T-5CHW which dates back to 2014. Is this another WD documentation screw-up, and is this just a case of product obfuscation that went too far?
This appears to be the datasheet (2016) that applies to the SSD part numbers affected by the H507 firmware update:
https://www.sandisk.com/content/dam/sandisk-main/en_us/assets/resources/enterprise/data-sheets/lightning-genII-sas-ssd-product-family-datasheet.pdf
Lightning Ultra™ Gen. II SAS SSDs – Ordering Information
Capacity & Part Number
(200GB) - SDLTMDKW-200G-5Cxx
(400GB) - SDLTMDKW-400G-5Cxx
(800GB) - SDLTMCKW-800G-5Cxx
Lightning Ascend™ Gen. II SAS SSDs - Ordering Information
(200GB) - SDLTODKM-200G-5Cxx
(400GB) - SDLTODKM-400G-5Cxx
(800GB) - SDLTODKM-800G-5Cxx
(1.6TB) - SDLTOCKM-016T-5Cxx
Lightning Eco™ Gen. II SAS SSDs - Ordering Information
(800GB) - SDLTODKR-800G-5Cxx
(1.6TB) - SDLTOCKR-016T-5Cxx
This FCC document identifies the various sub-models relating to a single model number, SXKLTK:
https://fccid.io/MSIP-REM-TAD-SXKLTK
Application Number: 201417100000059828
Company: SanDisk Corporation
Device Name: 2.5 "SAS SFF Solid State Drive
Model: SXKLTK
Sub-Model: SDLTMDKW-200G-xxxx,SDLTODKM-200G-xxxx,SDLTMDKW-400G-xxxx,SDLTMCKW-800G-xxxx,SDLTODKM-800G-xxxx,SDLTOCKR-016T-xxxx,SDLTODKR-900G-xxxx,SDLTOCKR-018T-xxxx,SDLTODKR-010T-xxxx,SDLTOCKM-016T-xxxx,SDLTODKM-400G-xxxx
Authorization Number: MSIP-REM-TAD-SXKLTK
Manufacturer: SanDisk Corporation
Country: USA
Date of Application: 2014-03-24
This is WD's firmware update page for the above SSDs:
H507 Firmware Update (Published 03/10/2020 03:31 PM):
The attached firmware file is firmware revision H507, for use in the SDLTODKR-900G-5CHW and SDLTOCKR-018T-5CHW SSD drives, which contains an update fix for the 40000 power on hour issue present in earlier code revisions. Customers are urged to upload the new code to their installed SDLTODKR-900G-5CHW and SDLTOCKR-018T-5CHW drives as soon as possible to avoid possible issues related to an issue in earlier codes, which can affect drives as they reach 40000 power on hours.
Please note this firmware update is only compatible with the following part numbers:
SDLTODKR-900G-5CHW https://download.wdc.com/ssd/prod_boot_dlp_Customer_SAS.bin
SDLTOCKR-018T-5CHW https://download.wdc.com/ssd/prod_boot_dlp_Customer_SAS.bin
This blog talks about the same (?) update that was released for Dell and HP OEM versions of the SanDisk model numbers:
Dell & HPE Issue Updates to Fix 40K Hour Runtime Flaw in Enterprise SSDs (by Anton Shilov on March 27, 2020 4:00 PM EST):
https://www.anandtech.com/show/15673/dell-hpe-updates-for-40k-hour-essd-failures
In a second SSD snafu in as many years, Dell and HPE have revealed that the two vendors have shipped enterprise drives with a critical firmware bug, one will eventually cause data loss. The bug, seemingly related to an internal runtime counter in the SSDs, causes them to fail once they reach 40,000 hours runtime, losing all data in the process. As a result, both companies have needed to issue firmware updates for their respective drives, as customers who have been running them 24/7 (or nearly as much) are starting to trigger the bug.
Overall, Dell EMC shipped a number of the faulty SAS-12Gbps enterprise drives over the years, ranging in capacity from 200 GB to 1.6 TB. All of which will require the new D417 firmware update to avoid an untimely death at 40,000 hours.
Meanwhile, HPE shipped 800 GB and 1.6 TB drives using the faulty firmware. These drives were, in turn, were used in numerous server and storage products, including HPE ProLiant, Synergy, Apollo 4200, Synergy Storage Modules, D3000 Storage Enclosure, and StoreEasy 1000 Storage, and require HPE's firmware update to secure their stability.
As for the supplier of the faulty SSDs, while HPE declined to name its vendor, Dell EMC did reveal that the affected drives were made by SanDisk (now a part of Western Digital). Furthermore, based on an image of HPE’s MO1600JVYPR SSDs published by Blocks & Files, it would appear that HPE’s drives were also made by SanDisk. To that end, it is highly likely that the affected Dell EMC and HPE SSDs are essentially the same drives from the same maker.
From a similar blog ...
https://blocksandfiles.com/2020/03/24/hpe-enterprise-ssd-40k-hours-flaw/
HPE issued a statement on 28 March 2020, which said: “HPE was notified by Western Digital of a firmware issue in a specific line of older end-of-life SanDisk SAS solid state drive (SSD) models used by select OEM customers. The defect causes drive failure after 40,000 hours of operation; no HPE customers are in danger of immediate failure. HPE is actively reaching out to impacted customers to provide updated firmware that addresses the issue.”
An example of the OEM models affected by the update:
https://blocksandfiles.com/wp-content/uploads/2020/03/HPE-affected-drive.jpg
    MO1600JVYPR – HPE 1.6TB 12G SAS MU-1 SFF SC SSD = SanDisk m/n SXKLTK, p/n SDLTOCKR-016T-5C14
    12V / 0.5A, 5V / 0.5A
    Made in China
PostPosted: May 29th, 2020, 17:47
These are the respective Dell and HP firmware updates:
"This release contains firmware version D417 for SanDisk drives. Vendor model numbers LT0200MO, LT0400MO, LT0800MO, LT1600MO, LT0200WM, LT0400WM, LT0800WM, LT0800RO and LT1600RO. (13 Feb. 2020)"
https://www.dell.com/support/home/en-au/drivers/driversdetails?driverid=8h6hj&oscode=w12r2
Bulletin: (Revision) HPE SAS Solid State Drives - Critical Firmware Upgrade Required for Certain HPE SAS Solid State Drive Models to Prevent Drive Failure at 40,000 Hours of Operation (2020-03-20, HPD7):
https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00097382en_us
Here are excerpts from the Dell, HP and retail firmware payloads:
D417.fwh (Dell)
00000000  00 00 00 00 F6 03 00 00 39 44 34 31 37 44 34 30  ....ö...9D417D40
00000010  57 78 02 00 00 00 00 00 00 00 00 00 00 00 00 00  Wx..............
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09  ................
00000040  20 20 31 30 33 31 33 30 20 20 20 20 20 20 20 20    103130
00000050  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000060  20 20 20 20 20 20 20 20 4C 54 30 32 30 30 4D 4F          LT0200MO
00000070  20 20 31 30 33 31 33 31 20 20 20 20 20 20 20 20    103131
00000080  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000090  20 20 20 20 20 20 20 20 4C 54 30 34 30 30 4D 4F          LT0400MO
000000A0  20 20 31 30 33 31 33 32 20 20 20 20 20 20 20 20    103132
000000B0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000000C0  20 20 20 20 20 20 20 20 4C 54 30 38 30 30 4D 4F          LT0800MO
000000D0  20 20 31 30 32 38 35 31 20 20 20 20 20 20 20 20    102851
000000E0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000000F0  20 20 20 20 20 20 20 20 4C 54 31 36 30 30 4D 4F          LT1600MO
00000100  20 20 31 30 33 31 33 33 20 20 20 20 20 20 20 20    103133
00000110  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000120  20 20 20 20 20 20 20 20 4C 54 30 32 30 30 57 4D          LT0200WM
00000130  20 20 31 30 33 31 33 34 20 20 20 20 20 20 20 20    103134
00000140  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000150  20 20 20 20 20 20 20 20 4C 54 30 34 30 30 57 4D          LT0400WM
00000160  20 20 31 30 33 31 33 35 20 20 20 20 20 20 20 20    103135
00000170  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000180  20 20 20 20 20 20 20 20 4C 54 30 38 30 30 57 4D          LT0800WM
00000190  20 20 31 30 33 31 33 36 20 20 20 20 20 20 20 20    103136
000001A0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000001B0  20 20 20 20 20 20 20 20 4C 54 30 38 30 30 52 4F          LT0800RO
000001C0  20 20 31 30 33 31 33 37 20 20 20 20 20 20 20 20    103137
000001D0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000001E0  20 20 20 20 20 20 20 20 4C 54 31 36 30 30 52 4F          LT1600RO
000001F0  FC9B1800 A50DEEAB 44343137 01000000  ü›..¥.î«D417....
00000200  01000100 009B1800 00000000 00000000  .....›..........
00000210  00000000 00000000 00000000 00000000  ................
00000220  00000000 00000000 00000000 00000000  ................
00000230  00000000 00000000 00000000 00000000  ................
00000240  00000000 00000000 00000000 00000000  ................
00000250  00000000 00000000 00000000 00000000  ................
00000260  00000000 00000000 00000000 00000000  ................
00000270  00000000 00000000 00000000 00000000  ................
00000280  00000000 00000000 00000000 00000000  ................
00000290  0D500000 00008D69 000C0701 F0A70000  .P.....i....ð§..
000002A0  28450000 00000000 719E0000 03000000  (E......qž......
000002B0  00D2A16F 00000000 00000000 00000000  .Ò¡o............
000002C0  00000000 00000000 00000000 00000000  ................
000002D0  44454C4C 5F534153 33534646 5F57495F  DELL_SAS3SFF_WI_
000002E0  32303000 00000000 00000000 00000000  200.............
00040970  4C190000 C8E6FFFF 44454C4C 5F534153  L...ÈæÿÿDELL_SAS
00040980  33534646 5F57495F 3230305F 57430000  3SFF_WI_200_WC..
00040990  20203130 33313333 00000000 304D374B    103133....0M7K
000409A0  59580000 44454C4C 5F534153 33534646  YX..DELL_SAS3SFF
000409B0  5F4D555F 3230305F 57430000 20203130  _MU_200_WC..  10
000409C0  33313330 00000000 30325852 304B0000  3130....02XR0K..
000409D0  44454C4C 5F534153 33534646 5F57495F  DELL_SAS3SFF_WI_
000409E0  3430305F 57430000 20203130 33313334  400_WC..  103134
000409F0  00000000 30543254 50460000 44454C4C  ....0T2TPF..DELL
00040A00  5F534153 33534646 5F4D555F 3430305F  _SAS3SFF_MU_400_
00040A10  57430000 20203130 33313331 00000000  WC..  103131....
00040A20  30433036 56580000 44454C4C 5F534153  0C06VX..DELL_SAS
00040A30  33534646 5F57495F 3830305F 57430000  3SFF_WI_800_WC..
00040A40  20203130 33313335 00000000 30464846    103135....0FHF
00040A50  4E4A0000 44454C4C 5F534153 33534646  NJ..DELL_SAS3SFF
00040A60  5F4D555F 3830305F 57430000 20203130  _MU_800_WC..  10
00040A70  33313332 00000000 30393839 52380000  3132....0989R8..
00040A80  44454C4C 5F534153 33534646 5F52495F  DELL_SAS3SFF_RI_
00040A90  3830305F 57430000 20203130 33313336  800_WC..  103136
00040AA0  00000000 304A3139 584D0000 44454C4C  ....0J19XM..DELL
00040AB0  5F534153 33534646 5F52495F 31303030  _SAS3SFF_RI_1000
00040AC0  5F574300 39303531 30303034 00000000  _WC.90510004....
00040AD0  4C543130 3030524F 00000000 44454C4C  LT1000RO....DELL
00040AE0  5F534153 33534646 5F52495F 31363030  _SAS3SFF_RI_1600
00040AF0  5F574300 20203130 33313337 00000000  _WC.  103137....
00040B00  30324D36 31470000 44454C4C 5F534153  02M61G..DELL_SAS
00040B10  33534646 5F4D555F 31363030 5F574300  3SFF_MU_1600_WC.
00040B20  20203130 32383531 00000000 304A4454    102851....0JDT
00040B30  47580000 44454C4C 5F534153 33534646  GX..DELL_SAS3SFF
00040B40  5F52495F 3438305F 57430000 20203939  _RI_480_WC..  99
00040B50  39393939 00000000 78787878 78780000  9999....xxxxxx..
00040F10           44454C4C 5F534153 33534646      DELL_SAS3SFF
00040F20  5F52495F 3936305F 57430000 44454C4C  _RI_960_WC..DELL
00040F30  5F534153 33534646 5F52495F 31393230  _SAS3SFF_RI_1920
00040F40  5F574300 44454C4C 5F534153 33534646  _WC.DELL_SAS3SFF
00040F50  5F52495F 3430305F 57430000 44454C4C  _RI_400_WC..DELL
00040F60  5F534153 33534646 5F52495F 3930305F  _SAS3SFF_RI_900_
00040F70  57430000 44454C4C 5F534153 33534646  WC..DELL_SAS3SFF
00040F80  5F52495F 31383030 5F574300 877D004B  _RI_1800_WC.‡}.K
00040F90  30860040 30800040 30A60B60 FC3F0000  0†.@0€.@0¦.`ü?..
00040FA0  5650444C 00000000 47656E65 7269635F  VPDL....Generic_
00040FB0  33703569 6E5F5341 535F3330 30        3p5in_SAS_300
000A6CD0  70470000 30860040 30800040 4C543032  pG..0†.@0€.@LT02
000A6CE0  3030574D 004C5430 34303057 4D004C54  00WM.LT0400WM.LT
000A6CF0  30383030 574D004C 54303230 304D4F00  0800WM.LT0200MO.
000A6D00  4C543034 30304D4F 004C5430 3830304D  LT0400MO.LT0800M
000A6D10  4F004C54 30383030 524F004C 54313630  O.LT0800RO.LT160
000A6D20  304D4F00 4C543136 3030524F 004C5431  0MO.LT1600RO.LT1
000A6D30  30303052 4F004C54 30343030 524F004C  000RO.LT0400RO.L
000A6D40  54303438 30524F00 4C543039 3630524F  T0480RO.LT0960RO
000A6D50  004C5431 39323052 4F004C54 30393030  .LT1920RO.LT0900
000A6D60  524F004C 54313830 30524F00 47656E65  RO.LT1800RO.Gene
000A6D70  7269635F 53415333 5346465F 57495F32  ric_SAS3SFF_WI_2
000A6D80  31395F57 43004765 6E657269 635F5341  19_WC.Generic_SA
000A6D90  53335346 465F5749 5F343139 5F574300  S3SFF_WI_419_WC.
000A6DA0  47656E65 7269635F 53415333 5346465F  Generic_SAS3SFF_
000A6DB0  57495F38 31395F57 43004765 6E657269  WI_819_WC.Generi
000A6DC0  635F5341 53335346 465F4D55 5F323139  c_SAS3SFF_MU_219
000A6DD0  5F574300 47656E65 7269635F 53415333  _WC.Generic_SAS3
000A6DE0  5346465F 4D555F34 31395F57 43004765  SFF_MU_419_WC.Ge
000A6DF0  6E657269 635F5341 53335346 465F4D55  neric_SAS3SFF_MU
000A6E00  5F383139 5F574300 47656E65 7269635F  _819_WC.Generic_
000A6E10  53415333 5346465F 4D555F31 3631395F  SAS3SFF_MU_1619_
000A6E20  57430047 656E6572 69635F53 41533353  WC.Generic_SAS3S
000A6E30  46465F52 495F3830 305F5743 0047656E  FF_RI_800_WC.Gen
000A6E40  65726963 5F534153 33534646 5F52495F  eric_SAS3SFF_RI_
000A6E50  31303030 5F574300 47656E65 7269635F  1000_WC.Generic_
000A6E60  53415333 5346465F 52495F31 3630305F  SAS3SFF_RI_1600_
000A6E70  57430047 656E6572 69635F53 41533353  WC.Generic_SAS3S
000A6E80  46465F52 495F3430 305F5743 0047656E  FF_RI_400_WC.Gen
000A6E90  65726963 5F534153 33534646 5F52495F  eric_SAS3SFF_RI_
000A6EA0  3438305F 57430047 656E6572 69635F53  480_WC.Generic_S
000A6EB0  41533353 46465F52 495F3930 305F5743  AS3SFF_RI_900_WC
000A6EC0  0047656E 65726963 5F534153 33534646  .Generic_SAS3SFF
000A6ED0  5F52495F 3936305F 57430047 656E6572  _RI_960_WC.Gener
000A6EE0  69635F53 41533353 46465F52 495F3138  ic_SAS3SFF_RI_18
000A6EF0  30305F57 43004765 6E657269 635F5341  00_WC.Generic_SA
000A6F00  53335346 465F5249 5F313932 305F5743  S3SFF_RI_1920_WC
0013D980  99996874 7470733A 2F2F7376 6E736475  ™™https://svnsdu
0013D990  732E7361 6E646973 6B2E636F 6D2F7376  s.sandisk.com/sv
0013D9A0  6E2F4845 4D693132 2F466972 6D776172  n/HEMi12/Firmwar
0013D9B0  652F7461 67732F54 34335800 00999934  e/tags/T43X..™™4
0013D9C0  30353631 00009999 54533A20 32303230  0561..™™TS: 2020
0013D9D0  2F30322F 30342031 363A3236 3A313100  /02/04 16:26:11.
0013D9E0  00999943 3A2F4553 532F4B69 6C695265  .™™C:/ESS/KiliRe
0013D9F0  6C656173 652F4B69 6C694657 322F4434  lease/KiliFW2/D4
0013DA00  31375434 33583945 37314B49 4C492D53  17T43X9E71KILI-S
0013DA10  41532D44 454C4C2D 74657374 64756D6D  AS-DELL-testdumm
0013DA20  79310000 9999484E 3A425549 4C444D41  y1..™™HN:BUILDMA
0013DA30  4348494E 45000099 99554944 3A455353  CHINE..™™UID:ESS
0013DA40  4C616200 0099994C 69627261 72792034  Lab..™™Library 4
0013DA50  30353631 00009999 44343137 00009999  0561..™™D417..™™
0013DA60  53616E44 69736B20 00000000 00000000  SanDisk ........
PLTGIID7.rel (HP)
00000000  FCA32000 9B241E0A 48504437 04000000  ü£ .›$..HPD7....
00000010  0E000100 00040000 00000000 01000500  ................
00000020  009B1800 00040000 0400A018 00000800  .›........ .....
00000030  009F1800 0F00A020 00040000 00010000  .Ÿ....  ........
000000B0  1A460000 00000000 849E0000 07000000  .F......„ž......
000000C0  B057A768 0C8E0000 00000000 00000000  °W§h.Ž..........
000000E0  48505F53 41533353 46465F57 495F3230  HP_SAS3SFF_WI_20
000000F0  30000000 00000000 00000000 00000000  0...............
000411E0  48502020 20202020 00000000 81030000  HP      ........
000411F0  B80B0000 53190000 4C190000 C8E6FFFF  ¸...S...L...Èæÿÿ
00041200  48505F53 41533353 46465F57 495F3230  HP_SAS3SFF_WI_20
00041210  305F5743 00000000 454F3032 30304A78  0_WC....EO0200Jx
00041220  78787820 20200000 48505F53 41533353  xxx   ..HP_SAS3S
00041230  46465F57 495F3430 305F5743 00000000  FF_WI_400_WC....
00041240  454F3034 30304A78 78787820 20200000  EO0400Jxxxx   ..
00041250  48505F53 41533353 46465F57 495F3830  HP_SAS3SFF_WI_80
00041260  305F5743 00000000 454F3038 30304A78  0_WC....EO0800Jx
00041270  78787820 20200000 48505F53 41533353  xxx   ..HP_SAS3S
00041280  46465F4D 555F3230 305F5743 00000000  FF_MU_200_WC....
00041290  4D4F3032 30304A78 78787820 20200000  MO0200Jxxxx   ..
000412A0  48505F53 41533353 46465F4D 555F3430  HP_SAS3SFF_MU_40
000412B0  305F5743 00000000 4D4F3034 30304A78  0_WC....MO0400Jx
000412C0  78787820 20200000 48505F53 41533353  xxx   ..HP_SAS3S
000412D0  46465F4D 555F3830 305F5743 00000000  FF_MU_800_WC....
000412E0  454B3038 30304A56 59504E20 20200000  EK0800JVYPN   ..
000412F0  26020000 48505F53 41533353 46465F4D  &...HP_SAS3SFF_M
00041300  555F3136 30305F57 43000000 454F3136  U_1600_WC...EO16
00041310  30304A56 59505020 20200000 48505F53  00JVYPP   ..HP_S
00041320  41533353 46465F52 495F3830 305F5743  AS3SFF_RI_800_WC
00041330  00000000 4D4B3038 30304A56 59505120  ....MK0800JVYPQ
00041340  20200000 48505F53 41533353 46465F52    ..HP_SAS3SFF_R
00041350  495F3130 30305F57 43000000 564F3130  I_1000_WC...VO10
00041360  30304A78 78787820 20200000 48505F53  00Jxxxx   ..HP_S
00041370  41533353 46465F52 495F3136 30305F57  AS3SFF_RI_1600_W
00041380  43000000 4D4F3136 30304A56 59505220  C...MO1600JVYPR
00041390  20200000 23050000 48505F53 41533353    ..#...HP_SAS3S
000413A0  46465F52 495F3438 305F5743 00000000  FF_RI_480_WC....
000413B0  564F3034 38304A78 78787820 20200000  VO0480Jxxxx   ..
000413C0  48505F53 41533353 46465F52 495F3936  HP_SAS3SFF_RI_96
000413D0  305F5743 00000000 564F3039 36304A78  0_WC....VO0960Jx
000413E0  78787820 20200000 48505F53 41533353  xxx   ..HP_SAS3S
000413F0  46465F52 495F3139 32305F57 43000000  FF_RI_1920_WC...
00041400  564F3139 32304A78 78787820 20200000  VO1920Jxxxx   ..
00041410  48505F53 41533353 46465F52 495F3430  HP_SAS3SFF_RI_40
00041420  305F5743 00000000 564F3034 30304A78  0_WC....VO0400Jx
00041430  78787820 20200000 48505F53 41533353  xxx   ..HP_SAS3S
00041440  46465F52 495F3930 305F5743 00000000  FF_RI_900_WC....
00041450  564F3039 30304A78 78787820 20200000  VO0900Jxxxx   ..
000A85E0                    4C543032 3030574D          LT0200WM
000A85F0  004C5430 34303057 4D004C54 30383030  .LT0400WM.LT0800
000A8600  574D004C 54303230 304D4F00 4C543034  WM.LT0200MO.LT04
000A8610  30304D4F 004C5430 3830304D 4F004C54  00MO.LT0800MO.LT
000A8620  30383030 524F004C 54313630 304D4F00  0800RO.LT1600MO.
000A8630  4C543136 3030524F 004C5431 30303052  LT1600RO.LT1000R
000A8640  4F004C54 30343030 524F004C 54303438  O.LT0400RO.LT048
000A8650  30524F00 4C543039 3630524F 004C5431  0RO.LT0960RO.LT1
000A8660  39323052 4F004C54 30393030 524F004C  920RO.LT0900RO.L
000A8670  54313830 30524F00 47656E65 7269635F  T1800RO.Generic_
000A8680  53415333 5346465F 57495F32 31395F57  SAS3SFF_WI_219_W
000A8690  43004765 6E657269 635F5341 53335346  C.Generic_SAS3SF
000A86A0  465F5749 5F343139 5F574300 47656E65  F_WI_419_WC.Gene
000A86B0  7269635F 53415333 5346465F 57495F38  ric_SAS3SFF_WI_8
000A86C0  31395F57 43004765 6E657269 635F5341  19_WC.Generic_SA
000A86D0  53335346 465F4D55 5F323139 5F574300  S3SFF_MU_219_WC.
000A86E0  47656E65 7269635F 53415333 5346465F  Generic_SAS3SFF_
000A86F0  4D555F34 31395F57 43004765 6E657269  MU_419_WC.Generi
000A8700  635F5341 53335346 465F4D55 5F383139  c_SAS3SFF_MU_819
000A8710  5F574300 47656E65 7269635F 53415333  _WC.Generic_SAS3
000A8720  5346465F 4D555F31 3631395F 57430047  SFF_MU_1619_WC.G
000A8730  656E6572 69635F53 41533353 46465F52  eneric_SAS3SFF_R
000A8740  495F3830 305F5743 0047656E 65726963  I_800_WC.Generic
000A8750  5F534153 33534646 5F52495F 31303030  _SAS3SFF_RI_1000
000A8760  5F574300 47656E65 7269635F 53415333  _WC.Generic_SAS3
000A8770  5346465F 52495F31 3630305F 57430047  SFF_RI_1600_WC.G
000A8780  656E6572 69635F53 41533353 46465F52  eneric_SAS3SFF_R
000A8790  495F3430 305F5743 0047656E 65726963  I_400_WC.Generic
000A87A0  5F534153 33534646 5F52495F 3438305F  _SAS3SFF_RI_480_
000A87B0  57430047 656E6572 69635F53 41533353  WC.Generic_SAS3S
000A87C0  46465F52 495F3930 305F5743 0047656E  FF_RI_900_WC.Gen
000A87D0  65726963 5F534153 33534646 5F52495F  eric_SAS3SFF_RI_
000A87E0  3936305F 57430047 656E6572 69635F53  960_WC.Generic_S
000A87F0  41533353 46465F52 495F3138 30305F57  AS3SFF_RI_1800_W
000A8800  43004765 6E657269 635F5341 53335346  C.Generic_SAS3SF
000A8810  465F5249 5F313932 305F5743           F_RI_1920_WC
0013FFA0  0C7B1460 00000000 99996874 7470733A  .{.`....™™https:
0013FFB0  2F2F7376 6E736475 732E7361 6E646973  //svnsdus.sandis
0013FFC0  6B2E636F 6D2F7376 6E2F4845 4D693132  k.com/svn/HEMi12
0013FFD0  2F466972 6D776172 652F7461 67732F54  /Firmware/tags/T
0013FFE0  35304D00 00999934 30353830 00009999  50M..™™40580..™™
0013FFF0  54533A20 32303230 2F30332F 30322031  TS: 2020/03/02 1
00140000  393A3431 3A313900 00999943 3A2F4553  9:41:19..™™C:/ES
00140010  532F4B69 6C695265 6C656173 652F4B69  S/KiliRelease/Ki
00140020  6C694657 5F485044 372F4850 44375435  liFW_HPD7/HPD7T5
00140030  304D3945 38344B49 4C492D53 41532D48  0M9E84KILI-SAS-H
00140040  502D7465 73746475 6D6D7931 00009999  P-testdummy1..™™
00140050  484E3A42 55494C44 4D414348 494E4500  HN:BUILDMACHINE.
00140060  00999955 49443A45 70696300 0099994C  .™™UID:Epic..™™L
00140070  69627261 72792034 30353830 00009999  ibrary 40580..™™
00140080  48504437 00009999 53616E44 69736B20  HPD7..™™SanDisk
prod_boot_dlp_Customer_SAS.bin (retail)
0005E9D0                    48554157 45495F53          HUAWEI_S
0005E9E0  41533353 46465F57 495F3230 305F5743  AS3SFF_WI_200_WC
0005E9F0  00000000 48554157 45495F53 41533353  ....HUAWEI_SAS3S
0005EA00  46465F57 495F3430 305F5743 00000000  FF_WI_400_WC....
0005EA10  48554157 45495F53 41533353 46465F57  HUAWEI_SAS3SFF_W
0005EA20  495F3830 305F5743 00000000 48554157  I_800_WC....HUAW
0005EA30  45495F53 41533353 46465F4D 555F3230  EI_SAS3SFF_MU_20
0005EA40  305F5743 00000000 48554157 45495F53  0_WC....HUAWEI_S
0005EA50  41533353 46465F4D 555F3430 305F5743  AS3SFF_MU_400_WC
0005EA60  00000000 48554157 45495F53 41533353  ....HUAWEI_SAS3S
0005EA70  46465F4D 555F3830 305F5743 00000000  FF_MU_800_WC....
0005EA80  48554157 45495F53 41533353 46465F4D  HUAWEI_SAS3SFF_M
0005EA90  555F3136 30305F57 43000000 48554157  U_1600_WC...HUAW
0005EAA0  45495F53 41533353 46465F52 495F3830  EI_SAS3SFF_RI_80
0005EAB0  305F5743 00000000 48554157 45495F53  0_WC....HUAWEI_S
0005EAC0  41533353 46465F52 495F3130 30305F57  AS3SFF_RI_1000_W
0005EAD0  43000000 48554157 45495F53 41533353  C...HUAWEI_SAS3S
0005EAE0  46465F52 495F3136 30305F57 43000000  FF_RI_1600_WC...
0005EAF0  48554157 45495F53 41533353 46465F52  HUAWEI_SAS3SFF_R
0005EB00  495F3438 305F5743 00000000 48554157  I_480_WC....HUAW
0005EB10  45495F53 41533353 46465F52 495F3936  EI_SAS3SFF_RI_96
0005EB20  305F5743 00000000 48554157 45495F53  0_WC....HUAWEI_S
0005EB30  41533353 46465F52 495F3139 32305F57  AS3SFF_RI_1920_W
0005EB40  43000000 48554157 45495F53 41533353  C...HUAWEI_SAS3S
0005EB50  46465F52 495F3930 305F5743 00000000  FF_RI_900_WC....
0005EB60  48554157 45495F53 41533353 46465F52  HUAWEI_SAS3SFF_R
0005EB70  495F3138 30305F57 43000000 48554157  I_1800_WC...HUAW
0005EB80  45495F53 41533353 46465F52 495F3430  EI_SAS3SFF_RI_40
0005EB90  305F5743 00000000 C733004B 30860040  0_WC....Ç3.K0†.@
0005EBA0  30800040 74AE0B60 5650444C 00000000  0€.@t®.`VPDL....
0005EBB0  47656E65 7269635F 33703569 6E5F5341  Generic_3p5in_SA
0005EBC0  535F3330 30                          S_300
000C53E0  30860040 30800040 4C543032 3030574D  0†.@0€.@LT0200WM
000C53F0  004C5430 34303057 4D004C54 30383030  .LT0400WM.LT0800
000C5400  574D004C 54303230 304D4F00 4C543034  WM.LT0200MO.LT04
000C5410  30304D4F 004C5430 3830304D 4F004C54  00MO.LT0800MO.LT
000C5420  30383030 524F004C 54313630 304D4F00  0800RO.LT1600MO.
000C5430  4C543136 3030524F 004C5431 30303052  LT1600RO.LT1000R
000C5440  4F004C54 30343030 524F004C 54303438  O.LT0400RO.LT048
000C5450  30524F00 4C543039 3630524F 004C5431  0RO.LT0960RO.LT1
000C5460  39323052 4F004C54 30393030 524F004C  920RO.LT0900RO.L
000C5470  54313830 30524F00 47656E65 7269635F  T1800RO.Generic_
000C5480  53415333 5346465F 57495F32 31395F57  SAS3SFF_WI_219_W
000C5490  43004765 6E657269 635F5341 53335346  C.Generic_SAS3SF
000C54A0  465F5749 5F343139 5F574300 47656E65  F_WI_419_WC.Gene
000C54B0  7269635F 53415333 5346465F 57495F38  ric_SAS3SFF_WI_8
000C54C0  31395F57 43004765 6E657269 635F5341  19_WC.Generic_SA
000C54D0  53335346 465F4D55 5F323139 5F574300  S3SFF_MU_219_WC.
000C54E0  47656E65 7269635F 53415333 5346465F  Generic_SAS3SFF_
000C54F0  4D555F34 31395F57 43004765 6E657269  MU_419_WC.Generi
000C5500  635F5341 53335346 465F4D55 5F383139  c_SAS3SFF_MU_819
000C5510  5F574300 47656E65 7269635F 53415333  _WC.Generic_SAS3
000C5520  5346465F 4D555F31 3631395F 57430047  SFF_MU_1619_WC.G
000C5530  656E6572 69635F53 41533353 46465F52  eneric_SAS3SFF_R
000C5540  495F3830 305F5743 0047656E 65726963  I_800_WC.Generic
000C5550  5F534153 33534646 5F52495F 31303030  _SAS3SFF_RI_1000
000C5560  5F574300 47656E65 7269635F 53415333  _WC.Generic_SAS3
000C5570  5346465F 52495F31 3630305F 57430047  SFF_RI_1600_WC.G
000C5580  656E6572 69635F53 41533353 46465F52  eneric_SAS3SFF_R
000C5590  495F3430 305F5743 0047656E 65726963  I_400_WC.Generic
000C55A0  5F534153 33534646 5F52495F 3438305F  _SAS3SFF_RI_480_
000C55B0  57430047 656E6572 69635F53 41533353  WC.Generic_SAS3S
000C55C0  46465F52 495F3930 305F5743 0047656E  FF_RI_900_WC.Gen
000C55D0  65726963 5F534153 33534646 5F52495F  eric_SAS3SFF_RI_
000C55E0  3936305F 57430047 656E6572 69635F53  960_WC.Generic_S
000C55F0  41533353 46465F52 495F3138 30305F57  AS3SFF_RI_1800_W
000C5600  43004765 6E657269 635F5341 53335346  C.Generic_SAS3SF
000C5610  465F5249 5F313932 305F5743 00000000  F_RI_1920_WC....
0015C730  FC641460 00000000 99996874 7470733A  üd.`....™™https:
0015C740  2F2F7376 6E736475 732E7361 6E646973  //svnsdus.sandis
0015C750  6B2E636F 6D2F7376 6E2F4845 4D693132  k.com/svn/HEMi12
0015C760  2F466972 6D776172 652F7461 67732F54  /Firmware/tags/T
0015C770  35304C00 00999934 30353739 00009999  50L..™™40579..™™
0015C780  54533A20 32303230 2F30332F 30322031  TS: 2020/03/02 1
0015C790  363A3331 3A333700 00999943 3A2F4553  6:31:37..™™C:/ES
0015C7A0  532F4B69 6C695265 6C656173 652F4B69  S/KiliRelease/Ki
0015C7B0  6C694657 2D485765 692F4835 30375435  liFW-HWei/H507T5
0015C7C0  304C3945 38334B49 4C492D53 41532D48  0L9E83KILI-SAS-H
0015C7D0  55415745 492D7465 73746475 6D6D7931  UAWEI-testdummy1
0015C7E0  00009999 484E3A42 55494C44 4D414348  ..™™HN:BUILDMACH
0015C7F0  494E4500 00999955 49443A45 70696300  INE..™™UID:Epic.
0015C800  0099994C 69627261 72792034 30353739  .™™Library 40579
0015C810  00009999 48353037 00009999 53616E44  ..™™H507..™™SanD
0015C820  69736B20 00000000 00000000 00000000  isk ............
PostPosted: May 29th, 2020, 18:23
The firmware payload includes several references to Pliant, eg ...
"Need to unlock the Pliant vendor unique mode for this feature"
The implication is that the firmware has its roots in earlier Pliant firmware. There is also a reference to "LS300S" which is a Pliant SSD model number. Pliant was an enterprise SSD manufacturer which was acquired by SanDisk in 2011.
SANDISK ANNOUNCES AGREEMENT TO ACQUIRE PLIANT TECHNOLOGY (May 16, 2011):
http://web.archive.org/web/20110519221028/http://www.sandisk.com:80/about-sandisk/press-room/press-releases/2011/2011-05-16-sandisk-announces-agreement-to-acquire-pliant-technology
SanDisk Corporation (NASDAQ:SNDK), a global leader in flash memory storage solutions, today announced a definitive agreement to acquire Pliant Technology, Inc., a leading developer of enterprise solid state drives (SSD).
Pliant currently sells ultra-high performance enterprise solid state drives based on the SAS protocol to meet the demanding performance, data integrity and reliability needs of enterprise storage customers. The company's product roadmap also includes PCIe-based solutions for high-performance compute servers. Pliant is a leader in the use of multi-level cell (MLC) NAND in enterprise SSDs, and the lower cost of MLC is a key enabler for the broad adoption of SSDs in the enterprise market.
Here is an FCC document:
https://fccid.io/PN1-LS300S
PN1-LS300S
Device: 3.5 "SSD Disk Drive - LS 300S
Manufactured by Asteel Flash Group
Application Number: 201 013 167
Company: Pliant Technology Inc.
Device Name: 3.5 "SSD Disk Drive
Model: LS 300S
Sub-Model:
Authorization Number: PN1-LS300S
Alphanumeric Authorization Number: PN1LS300S
Manufacturer: Asteel Flash Group
Country: USA
Date of Application: 2010-06-14
Here is an example on eBay:
SanDisk Pliant 300GB SAS Enterprise Flash Drive LS 300S 3.5" EFD SSD 43608-04:
https://www.ebay.com.au/itm/SanDisk-Pliant-300GB-SAS-Enterprise-Flash-Drive-LS-300S-3-5-EFD-SSD-43608-04/173853090475
https://i.ebayimg.com/images/g/o6sAAOSwuxFYyZOX/s-l1600.jpg
https://i.ebayimg.com/images/g/mf4AAOSwB-1YyZOV/s-l1600.jpg
    DOM: 04 April 2012
    Produced in USA
    12V / 0.6A, 5V / 1.0A
PostPosted: May 29th, 2020, 18:34
Is it possible that Huawei was once an OEM customer of SanDisk, and that WD has now mistakenly released OEM Huawei firmware into its retail channel? If so, then where is Huawei's corresponding firmware update page?
PostPosted: June 1st, 2020, 17:38
Here is WD's product support page for the subject SSD:
Lightning Gen. II SAS SSD support information page:
http://kb-in.sandisk.com/app/answers/detail/a_id/18183/~/lightning-gen.-ii-sas-ssd-support-information-page
Tech info:
http://web.archive.org/web/20160712232955/https://www.sandisk.com/business/datacenter/products/flash-devices/ssds/sas-ssd/lightning-gen2
http://web.archive.org/web/20171210203103/https://www.sandisk.com/content/dam/sandisk-main/en_us/assets/resources/enterprise/data-sheets/lightning-eco-genII-sas-ssd-datasheet.pdf
Lightning Eco Gen. II SSD models:
    SDLTODKR-800G-5C (800GB)
    SDLTOCKR-016T-5C (1.6TB)
Lightning Gen. II SSD Drive Firmware:
https://kb.sandisk.com/app/answers/detail/a_id/18565
http://downloads.sandisk.com/downloads/ess/firmware/lightning-gen2-fw-p405.zip (P405)
Release Notes -- LIGHTNING GEN II Rev B September, 2017:
http://downloads.sandisk.com/downloads/ess/firmware/lightning-gen2-releasenotes-p405.pdf
P405 Change List:
[KILI-8041] – SMART error limits and rate values adjusted to reflect media end of life performance.
[KILI-8124] – Updated T10 compliance of the Unmap command.
[KILI-8992] – Fixed drive assert when Background Extended Self-test exceeds the advertised Extended Self-test Completion Time in mode page 0Ah when foreground activity is prominent.
[KILI-9087] – Added code to assure proper initialization of variable when encountering non-fully erased blocks in the Logical to Physical area.
[KILI-9116] – Fixed Max Temperature not being persistent in Log page 2Fh SMART page across power cycle or code download.
[KILI-9121] – Optimized rebuild time at power-up and relax timeout in some cases.
[KILI-9147] – Optimized endurance throttling, to ensure drive won't throttle below 30MB/s that could cause excessive timeouts or write command hangs.
[KILI-9195] – Delayed the code download metadata save call to the very end of “offline code download” (i.e. Write Buffer mode Eh), where there are no more exception handling possibilities if a Read Buffer is received before the activation.
This P405 retail firmware update (P405) predates the latest OEM HPD7, D417, H507 updates by more than 2 years. Since this is the latest update on WD's web site, this would imply that the retail version was not affected by the 40K POH bug???
The reference to "end of life performance" in the "KILI-8041" patch would suggest that the SSD alters its performance in some way as it approaches end of life. This appears to shine some light on the reason for a trigger at 40K Power On Hours.
The following blocks of data look like what one would expect for retail firmware. This would support the idea that the H507 update is in fact a Huawei OEM update that was released in error into WD's retail channel.
00000000  FC 9B 18 00 DF 9B 72 44 50 34 30 35 01 00 00 00  ü›..ß›rDP405....
00000010  01 00 01 00 00 9B 18 00 00 00 00 00 00 00 00 00  .....›..........
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000A0  0D 50 00 00 00 00 8D 69 00 0C 07 01 F0 A7 00 00  .P.....i....ð§..
000000B0  28 45 00 00 00 00 00 00 6E 9D 00 00 03 00 00 00  (E......n.......
000000C0  00 D2 A1 6F 00 00 00 00 00 00 00 00 00 00 00 00  .Ò¡o............
000000D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000E0  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
000000F0  57 49 5F 32 30 30 00 00 00 00 00 00 00 00 00 00  WI_200..........
00040D90  4C 19 00 00 C8 E6 FF FF 47 65 6E 65 72 69 63 5F  L...ÈæÿÿGeneric_
00040DA0  53 41 53 33 53 46 46 5F 57 49 5F 32 30 30 5F 57  SAS3SFF_WI_200_W
00040DB0  43 00 00 00 47 65 6E 65 72 69 63 5F 53 41 53 33  C...Generic_SAS3
00040DC0  53 46 46 5F 57 49 5F 34 30 30 5F 57 43 00 00 00  SFF_WI_400_WC...
00040DD0  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
00040DE0  57 49 5F 38 30 30 5F 57 43 00 00 00 47 65 6E 65  WI_800_WC...Gene
00040DF0  72 69 63 5F 53 41 53 33 53 46 46 5F 4D 55 5F 32  ric_SAS3SFF_MU_2
00040E00  30 30 5F 57 43 00 00 00 47 65 6E 65 72 69 63 5F  00_WC...Generic_
00040E10  53 41 53 33 53 46 46 5F 4D 55 5F 34 30 30 5F 57  SAS3SFF_MU_400_W
00040E20  43 00 00 00 47 65 6E 65 72 69 63 5F 53 41 53 33  C...Generic_SAS3
00040E30  53 46 46 5F 4D 55 5F 38 30 30 5F 57 43 00 00 00  SFF_MU_800_WC...
00040E40  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
00040E50  4D 55 5F 31 36 30 30 5F 57 43 00 00 47 65 6E 65  MU_1600_WC..Gene
00040E60  72 69 63 5F 53 41 53 33 53 46 46 5F 52 49 5F 38  ric_SAS3SFF_RI_8
00040E70  30 30 5F 57 43 00 00 00 47 65 6E 65 72 69 63 5F  00_WC...Generic_
00040E80  53 41 53 33 53 46 46 5F 52 49 5F 31 30 30 30 5F  SAS3SFF_RI_1000_
00040E90  57 43 00 00 47 65 6E 65 72 69 63 5F 53 41 53 33  WC..Generic_SAS3
00040EA0  53 46 46 5F 52 49 5F 31 36 30 30 5F 57 43 00 00  SFF_RI_1600_WC..
00040EB0  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
00040EC0  52 49 5F 34 38 30 5F 57 43 00 00 00 47 65 6E 65  RI_480_WC...Gene
00040ED0  72 69 63 5F 53 41 53 33 53 46 46 5F 52 49 5F 39  ric_SAS3SFF_RI_9
00040EE0  36 30 5F 57 43 00 00 00 47 65 6E 65 72 69 63 5F  60_WC...Generic_
00040EF0  53 41 53 33 53 46 46 5F 52 49 5F 31 39 32 30 5F  SAS3SFF_RI_1920_
00040F00  57 43 00 00 47 65 6E 65 72 69 63 5F 53 41 53 33  WC..Generic_SAS3
00040F10  53 46 46 5F 52 49 5F 39 30 30 5F 57 43 00 00 00  SFF_RI_900_WC...
00040F20  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
00040F30  52 49 5F 31 38 30 30 5F 57 43 00 00 47 65 6E 65  RI_1800_WC..Gene
00040F40  72 69 63 5F 53 41 53 33 53 46 46 5F 52 49 5F 34  ric_SAS3SFF_RI_4
00040F50  30 30 5F 57 43 00 00 00 87 2C 00 4B 30 86 00 40  00_WC...‡,.K0†.@
00040F60  30 80 00 40 F8 AE 0B 60 56 50 44 4C 00 00 00 00  0€.@ø®.`VPDL....
00040F70  47 65 6E 65 72 69 63 5F 33 70 35 69 6E 5F 53 41  Generic_3p5in_SA
00040F80  53 5F 33 30 30 00 00 00 53 03 00 00 72 10 00 00  S_300...S...r...
000A72B0  30 80 00 40 4C 54 30 32 30 30 57 4D 00 4C 54 30  0€.@LT0200WM.LT0
000A72C0  34 30 30 57 4D 00 4C 54 30 38 30 30 57 4D 00 4C  400WM.LT0800WM.L
000A72D0  54 30 32 30 30 4D 4F 00 4C 54 30 34 30 30 4D 4F  T0200MO.LT0400MO
000A72E0  00 4C 54 30 38 30 30 4D 4F 00 4C 54 30 38 30 30  .LT0800MO.LT0800
000A72F0  52 4F 00 4C 54 31 36 30 30 4D 4F 00 4C 54 31 36  RO.LT1600MO.LT16
000A7300  30 30 52 4F 00 4C 54 31 30 30 30 52 4F 00 4C 54  00RO.LT1000RO.LT
000A7310  30 34 30 30 52 4F 00 4C 54 30 34 38 30 52 4F 00  0400RO.LT0480RO.
000A7320  4C 54 30 39 36 30 52 4F 00 4C 54 31 39 32 30 52  LT0960RO.LT1920R
000A7330  4F 00 4C 54 30 39 30 30 52 4F 00 4C 54 31 38 30  O.LT0900RO.LT180
000A7340  30 52 4F 00 47 65 6E 65 72 69 63 5F 53 41 53 33  0RO.Generic_SAS3
000A7350  53 46 46 5F 57 49 5F 32 31 39 5F 57 43 00 47 65  SFF_WI_219_WC.Ge
000A7360  6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F 57 49  neric_SAS3SFF_WI
000A7370  5F 34 31 39 5F 57 43 00 47 65 6E 65 72 69 63 5F  _419_WC.Generic_
000A7380  53 41 53 33 53 46 46 5F 57 49 5F 38 31 39 5F 57  SAS3SFF_WI_819_W
000A7390  43 00 47 65 6E 65 72 69 63 5F 53 41 53 33 53 46  C.Generic_SAS3SF
000A73A0  46 5F 4D 55 5F 32 31 39 5F 57 43 00 47 65 6E 65  F_MU_219_WC.Gene
000A73B0  72 69 63 5F 53 41 53 33 53 46 46 5F 4D 55 5F 34  ric_SAS3SFF_MU_4
000A73C0  31 39 5F 57 43 00 47 65 6E 65 72 69 63 5F 53 41  19_WC.Generic_SA
000A73D0  53 33 53 46 46 5F 4D 55 5F 38 31 39 5F 57 43 00  S3SFF_MU_819_WC.
000A73E0  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
000A73F0  4D 55 5F 31 36 31 39 5F 57 43 00 47 65 6E 65 72  MU_1619_WC.Gener
000A7400  69 63 5F 53 41 53 33 53 46 46 5F 52 49 5F 38 30  ic_SAS3SFF_RI_80
000A7410  30 5F 57 43 00 47 65 6E 65 72 69 63 5F 53 41 53  0_WC.Generic_SAS
000A7420  33 53 46 46 5F 52 49 5F 31 30 30 30 5F 57 43 00  3SFF_RI_1000_WC.
000A7430  47 65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F  Generic_SAS3SFF_
000A7440  52 49 5F 31 36 30 30 5F 57 43 00 47 65 6E 65 72  RI_1600_WC.Gener
000A7450  69 63 5F 53 41 53 33 53 46 46 5F 52 49 5F 34 30  ic_SAS3SFF_RI_40
000A7460  30 5F 57 43 00 47 65 6E 65 72 69 63 5F 53 41 53  0_WC.Generic_SAS
000A7470  33 53 46 46 5F 52 49 5F 34 38 30 5F 57 43 00 47  3SFF_RI_480_WC.G
000A7480  65 6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F 52  eneric_SAS3SFF_R
000A7490  49 5F 39 30 30 5F 57 43 00 47 65 6E 65 72 69 63  I_900_WC.Generic
000A74A0  5F 53 41 53 33 53 46 46 5F 52 49 5F 39 36 30 5F  _SAS3SFF_RI_960_
000A74B0  57 43 00 47 65 6E 65 72 69 63 5F 53 41 53 33 53  WC.Generic_SAS3S
000A74C0  46 46 5F 52 49 5F 31 38 30 30 5F 57 43 00 47 65  FF_RI_1800_WC.Ge
000A74D0  6E 65 72 69 63 5F 53 41 53 33 53 46 46 5F 52 49  neric_SAS3SFF_RI
000A74E0  5F 31 39 32 30 5F 57 43 00 00 00 00 01 00 00 00  _1920_WC........
0013F1D0  99 99 68 74 74 70 73 3A 2F 2F 73 76 6E 73 64 75  ™™https://svnsdu
0013F1E0  73 2E 73 61 6E 64 69 73 6B 2E 63 6F 6D 2F 73 76  s.sandisk.com/sv
0013F1F0  6E 2F 48 45 4D 69 31 32 2F 46 69 72 6D 77 61 72  n/HEMi12/Firmwar
0013F200  65 2F 74 61 67 73 2F 54 34 33 57 00 00 99 99 34  e/tags/T43W..™™4
0013F210  30 33 30 32 00 00 99 99 54 53 3A 20 32 30 31 37  0302..™™TS: 2017
0013F220  2F 30 38 2F 32 32 20 30 39 3A 33 34 3A 35 30 00  /08/22 09:34:50.
0013F230  00 99 99 43 3A 2F 45 53 53 2F 4B 69 6C 69 52 65  .™™C:/ESS/KiliRe
0013F240  6C 65 61 73 65 2F 4B 69 6C 69 46 57 2D 43 68 61  lease/KiliFW-Cha
0013F250  6E 6E 65 6C 2F 50 34 30 35 54 34 33 57 39 44 36  nnel/P405T43W9D6
0013F260  45 4B 49 4C 49 2D 53 41 53 2D 47 65 6E 65 72 69  EKILI-SAS-Generi
0013F270  63 2D 74 65 73 74 64 75 6D 6D 79 31 00 00 99 99  c-testdummy1..™™
0013F280  48 4E 3A 42 55 49 4C 44 4D 41 43 48 49 4E 45 00  HN:BUILDMACHINE.
0013F290  00 99 99 55 49 44 3A 45 53 53 4C 61 62 00 00 99  .™™UID:ESSLab..™
0013F2A0  99 4C 69 62 72 61 72 79 20 34 30 33 30 32 00 00  ™Library 40302..
0013F2B0  99 99 50 34 30 35 00 00 99 99 53 61 6E 44 69 73  ™™P405..™™SanDis
0013F2C0  6B 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00  k ..............
Users browsing this forum: No registered users and 91 guests
