 Post subject: LEXAR NM610PRO
PostPosted: January 27th, 2025, 7:40
Hello everyone,
Is there anyone willing to take on a desperate recovery attempt? Here's the situation:
I have an M.2 SSD Lexar NM610 Pro. After disconnecting and reconnecting it, the NTFS file system got corrupted. Even after a full scan, the drive appears to be 70% empty, with most sectors filled with 00s.
There are some traces of files and the filesystem, but overall, the drive looks empty, whereas it was previously about 80% full. The disk controller is a MAP1202A. Given the sudden disappearance of data but no issues with drive accessibility, is there any hope of recovering the contents?
I’ve tried using DMDE and other scanning software, as well as a hex editor, but the data in 70% of the sectors is still 00. If anyone has any advice or is willing to take on this recovery attempt without high financial expectations, I’d greatly appreciate it.
Thank you in advance!
 Post subject: Re: LEXAR NM610PRO
PostPosted: January 27th, 2025, 8:55
Sounds like a translator 'thing' then. Lexar NM600 is supported by PC3000, no mention of NM610.
