 Post subject: Translator for Sabre2
PostPosted: July 25th, 2007, 4:27
Hi guys,
I'm using the UDMA version to recover a Maxtor 6V160E0 sabre2.
All heads and modules ok, but data cannot be read, so i suspect translator corruption.
However, in the menu of udma, i cannot find 'translator regeneration'. Or has the sabre2 a dynamic translator?
Anyone has an idea how to solve this ?
Best regards,
Dobre
Murphy was an optimist
 Post subject: Re: Translator for Sabre2
PostPosted: July 25th, 2007, 9:08
in data extractor there is a opetion "virtual translator" you can use this. to get data.
DF :D
DF :)
www.datatracksystem.net
PostPosted: July 25th, 2007, 9:16
You mean when creating the heads map?
I tried that allready but the problem is that it uses the plist or other modules, none of which appears at checking the modules, as if they are not there :(
Dobre
PostPosted: July 25th, 2007, 9:21
what happened to this hard disk Plist modules.
DF :)
PostPosted: July 25th, 2007, 9:30
Here is the report:
SA structure test
Selected family ........................... SABRE2
Model ..................................... Maxtor 6V160E0
Firmware .................................. VA111630
Serial .................................... V30571JG
Min. cylinder ............................. 932
Max. cylinder ............................. 99887
HDD configuration module
Id ........................................ 1F
Read ...................................... Yes
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. V30571JG
Max LBA ................................... 312581808
Head number ............................... 3
Head map .................................. 2 3 4
SA head map ............................... 2 3 4
Model1 ............................... Maxtor 6V160E0
Max LBA .............................. 320173056
Model2 ............................... Maxtor 6V160E0
Max LBA .............................. 312581808
Model3 ............................... Maxtor 6V150E0
Max LBA .............................. 293719104
Model4 ............................... Maxtor 6V120E0
Max LBA .............................. 240121728
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV8ь
Checksum .................................. Ok
Checking User data adaptives
Header .................................... CR0T`
What immediately appears is:
Checking RZTbl
Error ..................................... Wrong Module Id "78"
Checking G-List
Error ..................................... Wrong Module Id "1B"
Checking RZTbl-PList
Error ..................................... Wrong map
What could cause this ???
It is like modules of sabre have the id of these from calypso??
Regards,
Dobre
PostPosted: July 25th, 2007, 10:27
dobrevjetser wrote:
Here is the report:
SA structure test
The CS shouldn't be wrong - but if drive inits - it does not matter
Checking RZTbl
Checking G-List
Regards,
Dobre
this is normal because these modules are absent on a SABRE2 drive
PostPosted: July 25th, 2007, 10:33
P-List is B7 module
but it has different structure and DE cannot use it :)
PostPosted: July 25th, 2007, 10:37
So no solution ??? :(
PostPosted: July 25th, 2007, 13:36
I guess not yet
Ask PC3000 guys
You can send drive for us
we can repair this with our own utilities
PostPosted: July 25th, 2007, 17:58
I purchased UDMA about 1 month and 1 week ago.
I'm getting no replies any more from Ace.
Dobre
PostPosted: July 25th, 2007, 18:01
Dobre
:shock:
Have you tried to send e-mail directly ?
or ask you question on the PC3000 forum - http://acelab.ru/pcTechSupport/forum/
PostPosted: July 25th, 2007, 18:15
I emailed directly. They give only support for 1 month ...
Dobre
PostPosted: July 26th, 2007, 3:21
I suggest you to read ALL module Groups and try to seacrh where is the PLIST and GLIST Module based on their Header. and search the corelation between RZTable PLISt and Glist...
Aping
Спасибо
СУТИОНО / АПИНГ
PostPosted: July 26th, 2007, 7:40
ridiculous that ACE trying to read 1B for G-List - SABRE2
They know where G-List and others reside and they
know modules reference like 2C and one's mentioned by Doomer.
So why they don't include this for Sabre2 in UDMA version ??
Cause they ripping you off and they have this info for more than
a year and they cripple their programs...
PostPosted: July 26th, 2007, 10:39
they have completely different format
it is not so easy to add support of new modules
but not so hard, as well :)
PostPosted: July 26th, 2007, 21:43
It IDs correctly, so why do you think it's a translator problem?
Maybe it just needs good imaging?
PostPosted: July 27th, 2007, 4:25
Imaging is not working or very slow with lots of bad sectors, and if you restart the process, it returns different good and bad sectors.
BUT: very strange, i connected the drive to another pc to give A-FF a try, and that one reported nothing should be done. Amazingly, i could open the drive in explorer, and copy files!
After about 20 minutes, the drive disappeared from the system.
Rebooting this morning showed the drive again, and i could copy all i needed for my client :)
No problem any more so, but what causes this??? Perhaps temperature sensitive preamp or head.
Regards,
Dobre
PostPosted: July 30th, 2007, 10:22
Wow,
The Last Answer Was Like :roll: .Any Answers To This Mates
PostPosted: August 2nd, 2007, 18:49
Sabre2 probably has another version of Defect-Management control. 8)
A man is as old as he feels, and a woman as old as she looks
Users browsing this forum: No registered users and 86 guests
