 Post subject: Seagate MOMENTUS not spinning up
PostPosted: February 3rd, 2008, 17:41
Hello mates, I see for the first time a 2,5" Momentus 4200 ST9100822A that doesn't spin up - connected to external power supply the drive only emit a slight clicking.
Before opening the HDA (suspected bearing seizure), any advice / reported experience / common issues ? This is the first time I see such a HDD.
Many thanks in advance for sharing, best regards.
 Post subject: Re: Seagate MOMENTUS not spinning up
PostPosted: February 3rd, 2008, 19:33
Can you swap the PCB? Your problem could be electrical.
More likely, the heads are parked out of position, preventing the HDU from starting.
Jon
http://www.datasaversllc.com
PostPosted: February 4th, 2008, 12:44
Hello black ST
, i had some cases on seagate momentus, wheres that slight clinking and not spin was caused by a head sticktion
Best Regards
PostPosted: August 22nd, 2009, 16:00
My Seagate Momentus 5400.4 is making the same sound as this youtube video:
http://www.youtube.com/watch?v=oA-Vf7nx ... rofilepage
I was wondering if I should swap the platters or fix the sticktion.
cyberstep
PostPosted: August 22nd, 2009, 16:39
You could start by posting a terminal log... and make a new thread instead of resurrecting old ones from over a year ago...
PostPosted: August 22nd, 2009, 16:43
ok thanks
PostPosted: August 22nd, 2009, 19:49
hi,
did you have terminal log for post?
data recovery service[/b]
PostPosted: August 26th, 2009, 1:29
hi,
not yet.
PostPosted: December 2nd, 2009, 4:56
Hi there,
(sorry for my english)
I have the same problem. I removed disk from external case and connected it to my laptop with SATA-USB adapter. The computer doesn't see hard drive, and from the disk I hear noise like on Youtube video posted here. When I connect hdd with terminal the sound is the same. Here is my log from terminal:
Reset
4096k x 16 DRAM
CORSAIR - 1_Disk    S-00   11-05-07_18:00
Buzz
Buzz
Buzz
Buzz
[Buzz infinite all the time, but when I press CTRL+Z...]
     F>
Buzz
Buzz
[and again Buzz all the time]
Any ideas how to fix it?
Disk is (external case data):
Seagate Freeagent GO 250GB
P/N: 9NN2AG-500
S/N: 5RG0G0AT
Data from hdd:
Seagate Momentus 5400.4 250GB
SN: 5RG0G0AT
ST9250827AS
FW: 3.CTA
Thanks for helping me.
PostPosted: December 4th, 2009, 5:28
Hello, is the hard drive still under Seagate's warranty (usually 3 years)?You can check on their website by typing in the model number and serial number of your hard drive. If it is warranty then they will exchange it for you. I Hope that helps.
Cheers
Laptopdrivestore.com - New and Refurbished Laptop Hard Drives
PostPosted: December 4th, 2009, 5:49
fz50, HDD's heads sticked to discs!
PostPosted: December 4th, 2009, 6:06
Black ST asking for help with stiction case? This is something we dont see anymore :)
Users browsing this forum: No registered users and 241 guests
