 Post subject: How to swap a Toshiba PCB ? Any tips?
PostPosted: June 22nd, 2008, 6:46
Hi All,
I have a Toshiba 2.5" SATA hard disk which does not power up. I have checked the fuzes and that's not the problem in this case. I have also checked and the motor/bearings are not zeized. It's a PCB problem.
I have had some problems in the past finding matching parts for a Toshiba PCB Swap, what should i look for in a donor drive?
The drive here has the following printed on it:
Toshiba MK1637GSX
HDD2D60 D ZM 01
DP/N: PH-0UM742-26402-7BW-69GL
FW: DL040D
And the number printed on the white sticker on the PCB is: TF47Y8YZX
Which of these numbers are critical to match on the donor part before i buy it?
Thanks!
Zed.
 Post subject: Re: How to swap a Toshiba PCB ? Any tips?
PostPosted: June 22nd, 2008, 7:44
You need to swap the CPU on the PCB as it contains adaptive data. Not an easy job and something we outsource to a professional electronics shop to ensure it's done properly. It's a BGA chip, so can't be soldered without an infrared solder setup.
Data Recovery Ireland
PostPosted: June 22nd, 2008, 9:22
Thanks but what should i look for when buying the donor? What numbers have to match?
PostPosted: June 22nd, 2008, 13:06
Normally, I just match the model and factory site.
e.g. MK1637GSX, HDD2D60 D ZM 01 in your case
Also, as you have a Dell part number, you can try searching for that. This way, you're nearly always guaranteed that the drives will be from the same batch.
PostPosted: June 22nd, 2008, 14:06
Hello, Zed
I suggest to check the preamp chip!
Toshiba sometimes not spin up, or spin up, but don't do seek when the preamp is damaged. :shock:
Regards,
Janos
PostPosted: June 22nd, 2008, 17:49
What is the best way to check the pre-amp to see if it is damaged for this kind of hard drive?
PostPosted: June 22nd, 2008, 18:19
Make sure you have power to the motor connectors on the pcb before jumping to the most difficult problems.
PostPosted: June 23rd, 2008, 9:59
Thanks everybody, on the 1st troubleshooting step - what does everybody else use as the criteria to buy a hard disk for the PCB?
Do you all match ALL of these numbers:
"MK1637GSX
and
HDD2D60 D ZM 01?
Or can some of these be left out?
PostPosted: June 23rd, 2008, 10:53
sorry, I just copied and pasted your model number.
I normally seek: MK1637GSX and ZM 01
PostPosted: June 24th, 2008, 6:17
Thanks CK, do you usually look for anything else to match? e.g country of manufacture or date code? Ot is the model # and the "ZM 01" in my example enough usually in your experience?
PostPosted: June 24th, 2008, 6:26
Hi Zed,
I always choose the country of manufacture. e.g. ZL01 T - Where T is the country of manufacture
Some suppliers may list the Dell part number that you have. If so, try and get that one as it's likely to be your closest match.
PostPosted: July 2nd, 2008, 21:15
Ok - i found an exactly identical drive, exactly the same! Everything other than the serial # match.
I swapped the pcbs and the drive powers up now, makes a faint but repeated ticking like the head is trying to read then try again and again. It sounds like the PCB is simply not compatible this way. See the photo attached - which is the chip i need to swap? Chip 1 or 2 ?
Thanks.
PostPosted: July 2nd, 2008, 22:54
Hello zed, next to the M Chip right hand, looks like an Atmel chip, at some models thats could be the ROM wich u need to unsolder and solder on donnor, i cant see very good on u photo, check t
Best Regards
PostPosted: July 4th, 2008, 7:40
Thanks beto, i swapped the small 8 legged chip and it fixed the problme! Success! Thanks all.
PostPosted: August 27th, 2008, 2:16
Where is the small 8 legged chip at the photo ? thanks
PostPosted: August 27th, 2008, 2:21
Noth East od the M chip.
PostPosted: December 14th, 2009, 14:52
Hi!
I have the same problem with a toshiba hard drive and even got a pcb from a disk having the same model number.
My problem is that the pcb is different from the one posted before.
Maybe you could tell me what part of the pcb I have to swap?
Cheers!
Sven
Link to PCB Image
PostPosted: December 14th, 2009, 14:56
Hi!
I have the same problem with a toshiba drive.
I even got a drive having the same model number but replacing the pcb only didn't worked.
Maybe you could tell me which part of the pcb I have to swap?
Cheers!
Sven
Link to pcb image
PostPosted: January 12th, 2014, 12:09
DOSE THIS HDD HAVE AND OVER VOLTAGE PROTECTION FUSE
WHAT IS THE LOCATION ON THE PRINTED CIRCUT BOARD FOR THE
OVER VOLTAGE PROTECTION FUSE THAT BLOWS WHEN 5+ VOLT FEED GETS REVERSED WITH 12+ VOLT FEED ?
(OVER VOLTAGE PROTECTION FUSE FOR 5+ VOLT FEED WOULD BE BLOWN)
DRIVE IS Toshiba 500GB MK5061GSYN, HDD2F22 F VL01 T, G002872A, SATA 2.5 PCB
Users browsing this forum: Google [Bot] and 130 guests
