 Post subject: Healing slow blocks by Erasing: Is it durable?
PostPosted: August 29th, 2008, 16:56
Hello:
My Samsung F1 (1TB) had a lot of slow blocks: 700 green blocks.
I have done a secure erase of this disk.
Before: aprox 700 slow blocks (greens)
Now: aprox 100 slow blocks (greens)
The question is : will they come back? Is this "healing" durable?
 Post subject: Re: Healing slow blocks by Erasing: Is it durable?
PostPosted: August 29th, 2008, 17:19
Wilk they come back? YES. Durable healing? NO.
PostPosted: August 29th, 2008, 17:20
any more details? :roll:
how long will it last before I return to the previous situation?
weeks, months?
PostPosted: August 29th, 2008, 17:30
How long Wilk this go on? Ugh!!!!!
PostPosted: August 29th, 2008, 17:39
i'll take a newbie guess at helping, feel free to shoot me when i'm wrong:
I assume "green blocks" are what MHDD is showing you, readable but slowish.
"healing" as I understand will just move these blocks to the Plist so as to "hide" them. Those blocks won't re-appear unless you flush the list (that won't happen by it self)
what will happen is that more duff blocks will appear as time goes on.
If you doubt the disk why put important data on it? use it as a backup of backups, in a second location, and buy a new one.
shoot away ;)
PostPosted: August 29th, 2008, 17:41
no, my question is: how long... will the healing last :lol:
PostPosted: August 29th, 2008, 17:46
shoot away ;)
Hi mediaman.
Yes, green blocks are just slow blocks.
No, as I understand it, when I secure-erased the disk, these slow sectors were not hidden. Just got faster. I am asking if they will eventually get slower again.
Yes, if I don't return it, I will use it as backup, at least at the beginning.
Buy a new drive? No, I don't have money for another new drive.
PostPosted: August 29th, 2008, 18:15
shoot away ;)
Hi mediaman.
Hi for all!
Healing the slow block in mhdd is only mean overwrite its contents to new one (like zero).
It is a destructive option, don't use it on important data filled drive!!!
This procedure refresh the contents, and the block have 2 choice:
1. be faster again
2. be UNC(orrectable). If the remap is ON, the drive can "hide" this block, reallocate it. (goes to G-list).
The slowness caused by hyperparamagnetic effect.
The corruption can be corrected by ECC circuit in the pcb, but takes more time.
Additionally sometimes the corrector code try to read again and again, try to read a little off-track.
This causes the slowness, sometimes make strange noises as well.
If the content is rewritten, the block can be correctly readable again. :)
If the part of the surface is weaker than the others, the slowness will come again sooner or later....
Regards,
Janos
PostPosted: August 29th, 2008, 18:35
N.C. wrote:
Hi for all!
1. be faster again
Regards,
Janos
Thanks N.C.:
In fact, I "healed" the disk using the CMRR Secure Eraser, not MHDD.
(The disk was empty of data).
Then I scanned the disk and there was much fewer green blocks.
No bad blocks.
Then I think the slow sectors are now faster.
The question is whether they will slow down again. Most probably, as you say, this is a weakened media problem, and they will resurface.
How long will it take to resurface? How about rescanning in a couple of weeks? will I see the "resurfacing trend", in case there is one?
PostPosted: August 29th, 2008, 21:08
hddgorilla wrote:
Nobody knows or can predict how long it will take. The point is, the media seems week so it wouldn't be advisable to store anything important on that drive.
PostPosted: August 30th, 2008, 5:53
sorry, i mean superparamagnetic, not hyperparamagnetic. :mrgreen:
Too late was yesterday... :mrgreen:
@ hddgorilla no software, and no company can resurface the media.
It is only recyclabel.
The slow blocks depends on the content, and the media part quality.
(if you fill the disk with 0x00 and 0xff, you can find a lot of equal place slow sectors, and a lot of different place as well.)
If the data is overwrited, the magnetic domains flipped right again.
The superparamagnetic effect can corrupt again the block, but depends on the content.
IMHO better to be bad, and moved to G list.
It is a safe place for this sectors. :)
If the disk have a lot of slow sectors, i suggest to don't use it on important place.
The periodically recheck is good idea.
The UNC sectors goes to G list, without the OS crashed because finds needed part in UNC sector.
Regards,
Janos
PostPosted: August 30th, 2008, 7:04
I can fully recertify the drive in 48 hours :)
PostPosted: August 30th, 2008, 16:27
@N.C.:
I have erased the disk another time with the same program as before, MCRR, but
now I got no improvement. Aprox 125 green blocks, same as before.
Erasing with MHDD also no improvements.
Also, considering that the healed sectors will probably go slow again, I have decided to return the drive to the shop (RMA), and we will see if Samsung accepts the RMA.
Also, as suggested, I could create a Badblock with MHDD, and then, the disk won't pass Samsung diagnostics, and the RMA will be accepted, I think.
PostPosted: August 30th, 2008, 16:28
certify the defunction? :mrgreen:
PostPosted: August 30th, 2008, 16:33
No, I mean re-certify and REPAIR the drive completely.
PostPosted: August 30th, 2008, 23:50
No, thanks BlackST, I don't have any money left, seriously.
Also, the drive costs about 120€, makes no sense to repair it.
I have no data to recover.
And the disk can be used as it is.
Anyway, I will try to RMA it.
PostPosted: August 31st, 2008, 3:12
In any case don't expect zero 'greens'. And - according to the use you seem to do with drive - don't expect more than 1 year life.
PostPosted: August 31st, 2008, 8:17
hddgorilla wrote:
@N.C.:
The situation is a little bit more complicated, i am affraid. :S
The slowness can caused by some weak signal or little corruption of the sector's servo field, or the addressmark or id as well.
So, in this case, the seriously overwrite, won't help. :(
If you force samsung, to replace the drive, you have a big chance, to receive one refurbished drive with bigger problem inside, but passes the diagnostics. :S
I suggest to try to sell the drive, because it is error-free, and buy another new one. :)
Janos
PostPosted: August 31st, 2008, 14:09
Janos
Hi:
The first erase made a big improvement. From 700 to 125 greens.
But then no further improvement is possible.
Humm, I don't know, I think the shop would send me a new one, but I am not sure. I will ask them. I bought the drive 2 weeks ago.
Sell the drive? Good idea, I will sell it to BlackST (110 EUROS) :lol:
Another question: If I force a Badblock using MHDD, Samsung diagnostic will fail. But in case Samsung won't accept the RMA, will I be able to regenerate the block using HDDRegenerator, or at least map out the badblock?
regards
PostPosted: August 31st, 2008, 14:42
I pay it much less, and 1st choice drive, not "shopping mall quality", sorry (for you).
Users browsing this forum: Google [Bot], hannahmiller and 36 guests
