July 22nd, 2010, 5:43
July 22nd, 2010, 5:56
July 22nd, 2010, 10:19
July 22nd, 2010, 10:56
HWHacker wrote: Most likely the USB IC is at fault. So a new PCB and ROM swap may work.
July 22nd, 2010, 11:55
hgrills wrote:Well I have the tools you say you require, (which has taken 13 years to acquire) but alas in this case it is not enough
So I agree a pre-equipped brain is essential, but disagree with the assumption i don't have one!
July 24th, 2010, 6:02
HWHacker wrote:The important thing is the OS is not recognizing this device. Most likely the USB IC is at fault. Even if the drive had issues with the HDA the USB should recognize in the OS. I can not read the part number of the IC closest to the USB connector. Maybe you could post the details. Also I think there is the standard ROM next to the big SDRAM IC. So a new PCB and ROM swap may work.
August 21st, 2010, 8:36
August 26th, 2010, 1:22
August 26th, 2010, 3:00
August 26th, 2010, 17:25
einstein9 wrote:i guess that i found it , there is a special pinout connection for this drive which can be done
and converted to sata
thnx for the reply and quick tips guys
August 26th, 2010, 23:06
ericstratton wrote:So much for tech folks helping out tech folks in a bind and hopefully returning the favor later if they can for someone else.
August 27th, 2010, 5:40
August 27th, 2010, 6:09
August 27th, 2010, 6:19
August 27th, 2010, 6:43
August 27th, 2010, 7:21
August 27th, 2010, 13:12
August 29th, 2010, 20:13
August 29th, 2010, 21:16
August 29th, 2010, 22:01
jono-ats wrote:Is this a fair question: Would you feel slighted, if -- after a good meal -- you ask chef for the recipe and he refuses to divulge it to you?
