Has been unlocked, after unlocking can list the following list
ASCII Diag mode
F3 T> ASCII Diag mode
F3 T>/c
F3 C>Q
Online CR: Rev 0011.0000, Flash, Abort Online ESC: Rev 0011.0000, Flash, Abort Looping Command or Batch File Online ' ': Rev 0001.0000, Overlay, Pause Output Online '.': Rev 0013.0000, Overlay, Display Active Status Online '?': Rev 0011.0001, Overlay, Display Diagnostic Buffer Information Online '`': Rev 0017.0000, Flash, Display Read/Write Statistics Online '$': Rev 0017.0000, Flash, Display Read/Write Statistics By Zone Online '': Rev 0011.0000, Overlay, Toggle EIB-Specific R/W Tracing Online ^D: Rev 0011.0001, Overlay, Toggle R/W Tracing Online ^N: Rev 0011.0001, Overlay, Toggle R/W Tracing Online ^W: Rev 0011.0000, Flash, Enable and Init RW Statistics Online ^O: Rev 0004.0000, Overlay, Advance Servo Tracing State Online ':': Rev 0001.0000, Flash, PrepSecondaryOnlineCmd Online '!': Rev 0012.0000, Overlay, Display Current Read Channel Settings Online '<': Rev 0011.0000, Overlay, Decrement Read/Write Scope Sync Online '>': Rev 0011.0000, Overlay, Increment Read/Write Scope Sync Online '~': Rev 0015.0000, Overlay, Display Native Interface Command State Online ^A: Rev 0019.0000, Flash, Display Firmware Revision Online ^B: Rev 0015.0000, Overlay, Get Thermistor Temperature Online ^C: Rev 0011.0000, Overlay, Firmware Reset Online ^E: Rev 0011.0000, Overlay, Display Native Interface Configuration Online ^F: Rev 0011.0001, Overlay, Display Native Interface Read Cache Information Online ^H: Rev 0001.0000, Overlay, Display Performance Statistics Online ^I: Rev 0011.0000, Overlay, Display Controller Registers Online ^K: Rev 0011.0000, Overlay, Display DST Status Online ^L: Rev 0026.0000, Overlay, Display Sign On Message Online ^P: Rev 0011.0000, Overlay, Toggle Diag Idle Mode Online ^Q: Rev 0011.0000, Overlay, Resume Interface Task Online ^R: Rev 0011.0000, Flash, Enable ASCII Online Serial Port Mode Online ^S: Rev 0011.0000, Overlay, Pause Interface Task Online ^T: Rev 0011.0000, Flash, Enable ESLIP Serial Port Mode Online ^U: Rev 0011.0000, Overlay, Display Congen Online ^V: Rev 0011.0000, Overlay, Toggle Interface Command Echo Online ^X: Rev 0014.0000, Overlay, Display Native Interface and Read/Write Command History Online ^Y: Rev 0011.0000, Overlay, Display DST Status Online ^Z: Rev 0011.0000, Flash, Enable ASCII Diagnostic Serial Port Mode Online ^\: Rev 0012.0000, Overlay, Toggle Debug Display Enable Level : '`': Rev 0017.0000, Flash, QMON Counters Level : '$': Rev 0017.0000, Flash, QMON Stats Level : 'C': Rev 0001.0000, Overlay, Dump Seacorder Log Level : 'D': Rev 0001.0000, Flash, Dump CFD Log Level : 'W': Rev 0001.0000, Overlay, Dump Servo Capture Log Level : 'E': Rev 0001.0000, Flash, Dump EERT Log Level : 'S': Rev 0001.0000, Overlay, Dump Servo Seek Failure Log Level : '.': Rev 0001.0000, Flash, Display R/W Status All Levels CR: Rev 0011.0000, Flash, Abort All Levels '/': Rev 0001.0000, Flash, Change Diagnostic Command Level, /[Level] All Levels '+': Rev 0012.0000, Flash, Peek Memory Byte, +[AddrHi],[AddrLo],[NotUsed],[NumBytes] All Levels '-': Rev 0012.0000, Flash, Peek Memory Word, -[AddrHi],[AddrLo],[NotUsed],[NumBytes] All Levels '=': Rev 0011.0002, Flash, Poke Memory Byte, =[AddrHi],[AddrLo],[Data],[Opts] All Levels '@': Rev 0001.0000, Overlay, Batch File Label, @[LabelNum] All Levels '|': Rev 0001.0000, Overlay, Batch File Terminator, | All Levels '*': Rev 0011.0000, Overlay, Special Batch File Function, *[FuncId],[FuncParm0],[FuncParm1] All Levels 'A': Rev 0013.0001, Overlay, Set Test Space, A[OptsOrParmSelect],[ParmValue],[AddrType],[HdForCylLimit] All Levels 'L': Rev 0001.0002, Overlay, Enable Looping, L[Opts],[CountOrStopOnErrCode] Level 1 'N': Rev 0017.0006, Flash, SMART Control, N[SubCmd],[SubCmdParm0],[SubCmdParm1] Level 1 'd': Rev 0002.0000, Flash, Get Stack Usage Information, d Level 1 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits] Level 1 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes] Level 1 'G': Rev 0011.0000, Overlay, Generic Read/Write Request, G[Parm0],[Parm1],[Parm2],...[Parm9] Level 1 'S': Rev 0011.0001, Overlay, Edit Processor Memory Byte, S[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts] Level 1 'U': Rev 0011.0001, Overlay, Edit Buffer Memory Byte, U[AddrHi],[AddrLo],[MemValue],[NumBytes] Level 1 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr] Level 1 'e': Rev 0011.0000, Overlay, Spin Down and Reset Drive, e[MsecDelay],[Opts] Level 1 'j': Rev 0001.0000, Overlay, Display Hardware Jumper Setting, j[HardwareJumperSelect] Level 1 'm': Rev 0011.0001, Overlay, Edit Processor Memory Word, m[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts] Level 1 's': Rev 0001.0000, Overlay, Call SDBP Cmd, s[Parm1],[Parm2],[Parm3] Level 2 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options] Level 2 'x': Rev 0032.0001, Flash, Display Zone Information, x[Partition],[Hd],[Zone],[Options] Level 2 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits] Level 2 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks] Level 2 'D': Rev 0003.0000, Overlay, LdpcIterationControl, D[itratn cnt],[glbl itratn],[BERP opts],[erasure],[slidewindowjog_sz],[ext itratn],[slidingwindow itratn],[MAMR itratn] Level 2 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level 2 'F': Rev 0013.0000, Overlay, Modify Track Defect List, F[PSctr/LBA],[Action],[SourceMask],[BBMMask] Level 2 'I': Rev 0017.0000, Overlay, Display / Modify Adaptive Parameter, I,[GroupId] Level 2 'J': Rev 0001.0000, Overlay, Particle Sweep, J[ Start Cyl ],[ End Cyl ],[ Duration mSec ],[ Dwell mSec ],[ JIT mode ] Level 2 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload] Level 2 'M': Rev 0012.0000, Overlay, Set Diag Idle Mode, M[ModeSelect],[ModeMask],[ResetToPowerOn] Level 2 'N': Rev 0001.0000, Overlay, Set Direct Write Mode, N[EnableDirWrtModeOpt], [Toggle Test Mode] Level 2 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd] Level 2 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks] Level 2 'Q': Rev 0011.0001, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts] Level 2 'R': Rev 0011.0003, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts] Level 2 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 2 'T': Rev 0017.0000, Overlay, Measure Throughput, T[Opts],[CylSkew],[HeadSkew],[MiniZoneSkew],[SkewStep],[LengthInTracksOrBands],[OffsetInTracksOrBands],[NumberOfRetries] Level 2 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl] Level 2 'V': Rev 0011.0001, Overlay, Read Verify CHS, V[Sec],[NumSecs],[CompareBlk],[Opts] Level 2 'W': Rev 0011.0002, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts] Level 2 'X': Rev 0016.0001, Overlay, Display Track Information, X[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage] Level 2 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options] Level 2 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z Level 2 'a': Rev 0002.0000, Overlay, Measure Optimum Skew, a Level 2 'b': Rev 0017.0000, Overlay, BER by Hd / Zone, b[hd][,zone] Level 2 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr] Level 2 'e': Rev 0001.0000, Overlay, Clean Track Range, e[StartLogicalTrack],[EndLogicalTrack],[Head] Level 2 'h': Rev 0018.0000, Overlay, Translate Physical Sector, h[Sec],[NumSecs] Level 2 'i': Rev 0011.0000, Overlay, Display Defects On Current Track, i[Print Summary] Level 2 'j': Rev 0011.0001, Overlay, Read Wedge, j[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13] Level 2 'k': Rev 0001.0000, Overlay, Set User Cylinder/Head/MiniZone Skew, k[CylSkew],[HeadSkew],[MiniZoneSkew] Level 2 'l': Rev 0018.0000, Overlay, Translate Logical Sector, l[Sec],[NumSecs] Level 2 'o': Rev 0002.0002, Overlay, Corrupt LBA, o[Lba],[NumBlocks],[BurstSpan],[BurstOffset],[NumberOfRandomCorrupt],[Flags] Level 2 'r': Rev 0011.0001, Overlay, Read Long CHS or Read System CHS, r[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],[LongOpts],[SysOpts] Level 2 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 2 't': Rev 0018.0000, Overlay, Translate Wedge, t[Wdg],[NumWdgs] Level 2 'u': Rev 0011.0000, Overlay, Enable/Disable Channel/Preamp Register Display, u[EnableDisableOpt] Level 2 'v': Rev 0011.0000, Overlay, Convert Data Track Percentage To Servo Offset Count, v[Percentage] Level 2 'w': Rev 0012.0001, Overlay, Write Long CHS or Write System CHS, w[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],,[SysOpts],[SysValidKey] Level 2 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2] Level 2 'z': Rev 0012.0001, Overlay, Write Wedge, z[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing] Level 2 '7': Rev 0011.0001, Overlay, Write Verify CHS, 7[Sec],[NumSecs],[WrBufBlk],[Opts] Level 3 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options] Level 3 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks] Level 3 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level 3 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd] Level 3 'Q': Rev 0011.0001, Overlay, Write, Read, Write, Read CHS, Q[Sec],[NumSecs],[Opts] Level 3 'R': Rev 0012.0000, Overlay, Read Current Servo Destination, R Level 3 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 3 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl] Level 3 'V': Rev 0012.0000, Overlay, Read or Write Power ASIC Register, V[RegAddr],[RegValue],[WrOpt] Level 3 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z Level 3 'b': Rev 0001.0000, Overlay, LoadUnloadHeads, b[Cmd],[Velocity],[Dwell],[Lock] Level 3 'f': Rev 0013.0000, Overlay, Real Time Servo Trace, f[SubCmd],[SubPrm0],[SubPrm1],[SubPrm2] Level 3 'p': Rev 0018.0000, Overlay, Translate Physical Sector, p[Sec],[NumSecs] Level 3 'q': Rev 0018.0000, Overlay, Translate Logical Sector, q[Sec],[NumSecs] Level 3 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 4 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options] Level 4 'B': Rev 0011.0000, Overlay, Enable / Disable RVFF, B[NewRvffControlMode] Level 4 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks] Level 4 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level 4 'F': Rev 0001.0000, Overlay, Fast IO Cmd, F[NumRevs],[Attrib1],[Attrib2],[Attrib3] Level 4 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload] Level 4 'O': Rev 0011.0000, Overlay, Display Micro Jog for Logical Cylinder and Head, O[LogCyl],[Hd],[Opts],[SysAreaOpt] Level 4 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 4 'U': Rev 0011.0000, Overlay, Servo Batch Test sub commands, U[SubCmd],[SubCmdParm0],[SubCmdParm1],[SubCmdParm2] Level 4 'c': Rev 0001.0000, Overlay, Find Min Or Max Cylinders c[Head],[Mode],[RangeMultiplier],[RetryCountLimit],[FilterTimeConstant] Level 4 'e': Rev 0011.0000, Overlay, Enable / Disable PES Output, e[PesLeftShiftCnt],[DisablePesOut] Level 4 'g': Rev 0001.0000, Overlay, Display Servo Sector Error Log, g Level 4 'k': Rev 0001.0000, Overlay, Get VGA Data, k[OpType],[StartHt],[EndHt],[HtInc] Level 4 'l': Rev 0011.0000, Overlay, Scan Track for Servo Defects and ZAP, l[RdPositionOpt] Level 4 'q': Rev 0001.0000, Overlay, Display Servo Event Log, q Level 4 's': Rev 0002.0000, Overlay, Display Servo Sector Error Count, s Level 4 't': Rev 0011.0000, Overlay, Display / Modify ZAP Table, t[EntryNum],[EntryValue] Level 4 'u': Rev 0011.0000, Overlay, Set Seek Speed, u[Opts],[SkSpeed] Level 4 'v': Rev 0011.0000, Overlay, Butterfly Seek Test, v[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd] Level 5 'E': Rev 0001.0000, Flash, Measure Disc Eccentricity Level 5 'R': Rev 0011.0000, Flash, Read Servo RAM at Address, R[Addr],[NumBytes] Level 5 'S': Rev 0011.0000, Flash, Enter Servo Matlab Shell, S Level 5 'B': Rev 0011.0000, Overlay, Servo Bode Plot, B[BodeType],[InjAmp],[Fmin],[Fmax],[NumFreq],[NumSamples],[EnableTracing] Level 5 'C': Rev 0011.0000, Overlay, Generic Servo Command, C[CmdNum],[Parm1],...[Parm7] Level 5 'D': Rev 0011.0000, Overlay, Read / Unlock DDR Buffer, D[OperateCode] Level 5 'F': Rev 0011.0001, Overlay, DriveFreeFallProtection, F[OpCode],[FreeFallSen],[TumbleSen],[SimDur],[SimSensorOutputs] Level 5 'G': Rev 0011.0000, Overlay, Select Servo Controller, G[Head],[Controller],[InputShift] Level 5 'P': Rev 0004.0000, Overlay, PZT Test, P[OperationId],[DAC gain] Level 5 'U': Rev 0011.0000, Overlay, Enable / Disable Servo Updates, U[VcmDacUpdateOpt],[AToDUdateOpt] Level 5 'W': Rev 0011.0000, Overlay, Write Servo RAM at Address, W[Addr],[NumBytes],[Data] Level 5 'Z': Rev 0011.0000, Overlay, Read Zap from Disc to Table, Z Level 5 'b': Rev 0001.0000, Overlay, Bist Functionality, b[FunctionCode],[Mode] Level 5 'd': Rev 0011.0000, Overlay, Disable / Enable Servo ZAP coefficients and ZAP read, d[ZapControlMode] Level 5 'e': Rev 0001.0000, Overlay, Enable / Disable Shock Sensor, e[Operation] Level 5 'i': Rev 0011.0000, Overlay, Read Servo Symbol Table at Index, i[Index] Level 5 'p': Rev 0001.0000, Overlay, Set Power Mode, p[PowerMode] Level 5 'r': Rev 0011.0000, Overlay, Read Servo RAM at Index, r[Index],[NumBytes],[ByteOffset] Level 5 'w': Rev 0011.0000, Overlay, Write Servo RAM at Index, w[Index],[NumBytes],[Data],[ByteOffset] Level 6 'B': Rev 0011.0000, Overlay, Run Batch File, B[BatchFileNum],[DisplayOpt] Level 6 'D': Rev 0011.0000, Overlay, Display Batch File, D[BatchFileNum] Level 6 'E': Rev 0011.0000, Overlay, Enter Batch File, E[BatchFileNum] Level 7 'G': Rev 0003.0000, Flash, MonitorBackgroundTasks, G[SubCmd] Level 7 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options] Level 7 'x': Rev 0032.0001, Flash, Display Zone Information, x[Partition],[Hd],[Zone],[Options] Level 7 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits] Level 7 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks] Level 7 'D': Rev 0014.0000, Overlay, Display Temperature, D,[DevSelect] Level 7 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level 7 'I': Rev 0017.0000, Overlay, Display / Modify Adaptive Parameter, I,[GroupId] Level 7 'K': Rev 0011.0000, Overlay, Set Track Format, K[UserAreaTrkFormatType],[SysAreaTrkFormatType] Level 7 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks] Level 7 'Q': Rev 0011.0001, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts] Level 7 'R': Rev 0011.0003, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts] Level 7 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 7 'U': Rev 0015.0005, Overlay, Preamp Temperature Adjust, U[TweakTemperature],[Partition],[Hd],[Zone],[Opts],[WrPreht],[WrWrtHt],[WrRdHt],[RdPreht],[RdWrtHt],[RdRdHt],[RelHum] Level 7 'W': Rev 0011.0002, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts] Level 7 'X': Rev 0011.0000, Overlay, Display Preamp Head Resistance Level 7 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options] Level 7 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z Level 7 'b': Rev 0012.0000, Overlay, Erase Track, b[AdjacentTrkCnt],[EraseCntPerTrk],[AcEraseOpt] Level 7 'c': Rev 0011.0000, Overlay, Off Track Capability, c[Sec],[NumSecs],[SecIncrement],[Offset] Level 7 'd': Rev 0002.0000, Overlay, Create Recoverable Read Error, d LBA,[min],[max],[cnt],[sev] Level 7 'e': Rev 0001.0000, Overlay, BipsControl, e[BipsControlOptions] Level 7 'g': Rev 0001.0000, Overlay, Sector Based BER, g[sctr],[len],[option] Level 7 'h': Rev 0011.0001, Overlay, Mark Media Flaw, h[PhyCyl],[Hd],[PhySec],[UndisturbedRadius],[EraseBandTrks],[PtrLen],[WgSpec],[Od/Id] Level 7 'i': Rev 0011.0000, Overlay, Generic Read/Write Request, i[Parm0],[Parm1],[Parm2],...[Parm9] Level 7 'j': Rev 0001.0000, Overlay, GetSetLongErasureMaskTableCount, L[Mission],[Value] Level 7 'm': Rev 0028.0000, Overlay, Display DOS Information, m[Flags],[LBA],[MinCnt] Level 7 'r': Rev 0012.0000, Overlay, Read Non-Volatile Adaptive Parameters, r[Opts] Level 7 's': Rev 0011.0000, Overlay, Write Peripheral Register - channel or preamp, s[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr] Level 7 't': Rev 0012.0000, Overlay, Read Peripheral Register - channel or preamp, t[OpType],[RegAddr],[NumRegs],[RegMask],[RegPagAddr] Level 7 'u': Rev 0011.0000, Overlay, Enable/Disable Write Fault, u[Op] Level 7 'v': Rev 0002.0000, Overlay, GetPvt, v[StartingSuperBlock],[NumSuperBlocks],[OutputFormat],[Options] Level 7 'w': Rev 0011.0000, Overlay, Save Adaptives To Flash, w[Seg],,22 Level 7 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2] Level 8 'C': Rev 0011.0000, Overlay, Servo Diag Sub Cmds, C[SubCmd],[Parm0],[Parm1],[Parm2] Level 8 'R': Rev 0012.0000, Overlay, Read Current Servo Destination, R Level 8 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level 8 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl] Level 8 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z Level 8 'd': Rev 0001.0000, Overlay, Head Smash Test, d[HeadDirection],[AccelerationDuration],[DecelerationDuration],[AccelerationCurrent],[DecelerationCurrent] Level A 'F': Rev 0018.0001, Flash, Translate LBA, F[LbaHi],[LbaLo],[SysAreaOpt],[NumLbas] Level A 'G': Rev 0018.0000, Flash, Translate Host LBA, G[LbaHi],[LbaLo],[NumLbas] Level A 'C': Rev 0018.0000, Overlay, Translate PBA, C[PbaHi],[PbaLow],[NumPbas] Level A 'D': Rev 0018.0000, Overlay, Translate Symbols From Index, D[PhyCyl],[Hd],[Sfi],[NumSfis] Level A 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level A 'M': Rev 0011.0000, Overlay, Set Controller Test Port, M[Port],[Value] Level A 'P': Rev 0013.0001, Overlay, Merge Alt List into Slip List, P[RADIAL_PAD_IN_TRACKS],[CIRCUMFERENTIAL_PAD_SINGLE_IN_WEDGES],[CIRCUMFERENTIAL_PAD_MULTI_IN_WEDGES],[OPTIONS] Level A 'Q': Rev 0011.0001, Overlay, Write, Read, Read LBA, Q[Lba],[NumLbas],[Opts] Level A 'R': Rev 0012.0000, Overlay, Read LBA, R[Lba],[NumLbas],,[Opts] Level A 'S': Rev 0011.0000, Overlay, Seek to LBA, S[LbaHi],[LbaLo],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level A 'T': Rev 0001.0000, Overlay, GetLbaTracks, T[Zone],[Head] Level A 'V': Rev 0001.0001, Overlay, SeqThroughputByLba, V[Operation],[StartHostLba],[EndHostLba],[XferLenInHostBlks],[SampleCount],[Options] Level A 'W': Rev 0012.0001, Overlay, Write LBA, W[Lba],[NumLbas],,[Opts],[WSPattern] Level A 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options] Level A 'c': Rev 0018.0000, Overlay, Translate Logical Cylinder, Logical Head and Logical Sector, c[Cyl],[Hd],[Sec],[SysAreaOpt],[NumSecs] Level A 'd': Rev 0018.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Sector, d[Cyl],[Hd],[Sec],[NumSecs] Level A 'e': Rev 0018.0000, Overlay, Translate Nominal Cylinder and Logical Head, e[Cyl],[Hd],[Sec],[SysAreaOpt] Level A 'f': Rev 0018.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Wedge, f[Cyl],[Hd],[Wdg],[NumWdgs] Level A 'g': Rev 0001.0002, Overlay, Write Band, g[Band],[Offset],[Count],[Options] Level A 'h': Rev 0001.0002, Overlay, Read Band, g[Band],[Offset],[Count],[Options] Level A 'l': Rev 0016.0001, Overlay, Display Track Information, l[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage] Level A 'q': Rev 0001.0001, Overlay, q[RWQoptions], [StartLba],[TransferLength],,[Opts] Level A 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2] Level C 'B': Rev 0001.0001, Overlay, Display Channel Status List Data Level C 'D': Rev 0003.0000, Overlay, Display Channel Memory, D[MemorySelect],[StartAddress],[NumberOfSymbols],[BufferSelect] Level C 'E': Rev 0001.0000, Overlay, Display Bonanza Memory Size, E Level C 'G': Rev 0001.0000, Overlay, Set Channel Status List Triggers,[mask] Level C 'H': Rev 0001.0000, Overlay, Set Channel Status List Thresholds,[action],[value] Level C 'Q': Rev 0001.0000, Overlay, Display ASCII Command Information, Q[CmdLevel],[Cmd] Level C 'S': Rev 0000.0000, Overlay, Display Channel Status List Status Level C 'T': Rev 0012.0000, Overlay, Goop Plot, T[Hd],[StartTrk],[EndTrk],[ECCLvl],[NoFrcSync],[SkipCnt] Level C 'U': Rev 0003.0001, Overlay, Display / modify media cache Level C 'a': Rev 0001.0000, Overlay, InjectChannelADC, a Level E 'B': Rev 0012.0001, Overlay, Write Wedge, B[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing] Level E 'C': Rev 0011.0001, Overlay, Read Wedge, C[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13] Level E 'G': Rev 0001.0000, Overlay, HeadDegradation, G[OperationControlOptions],[MeasurementControlOptions] Level E 'n': Rev 0001.0000, Overlay, Dibit Extraction, n[sctr],[cnt],[dibit],[dibit],[dibit],[skip],[trim],[dsply] Level E 'o': Rev 0011.0000, Overlay, Fine RW Offset Measurement, o[NumAvgs],[TrkStepSize],[NumGuardTrks] Level E 'w': Rev 0011.0002, Overlay, Slow Write CHS, w[Sec],[NumSecs],[ConSec],[Skip],[UnitOfSkip] Level F 'b': Rev 0011.0000, Flash, Set Baud Rate, b[BaudRate],[MsecDelay] Level F 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits] Level F 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks] Level F 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes] Level F 'I': Rev 0001.0000, Overlay, IdleTaskControl, I[enable] Level F 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks] Level F 'R': Rev 0002.0000, Overlay, Displays BER Count, R[Head],[SingleHeadZone] Level F 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl] Level F 'V': Rev 0011.0000, Overlay, Buffer Compare, V[SrcBlk],[RefBlk],[NumBlks],[ContOnErr] Level F 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options] Level F 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z Level F 'g': Rev 0001.0000, Overlay, ConfigureGPIOTestPins, g[SubCmd] Level F 'p': Rev 0002.0000, Overlay, GetSetPartitionAttributes, p[dsk sz],[sparing],[restore parms],[host blks per dsk],[PI type] Level F 'r': Rev 0011.0001, Overlay, Read System CHS, r[LogSec],[NumSecs],[Opts] Level F 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level F 't': Rev 0011.0000, Overlay, Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr] Level F 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2] Level F 'z': Rev 0012.0000, Overlay, SataDebug, z[SubCmd],[Parm1],[Parm2],[Parm3] Level G 'B': Rev 0011.0000, Overlay, Fill Correction Buffer, B[StartAddr],[EndAddr],[Pattern],[Opts] Level G 'C': Rev 0011.0000, Overlay, Copy Correction Buffer, C[SrcAddr],[DestAddr],[NumSyms] Level G 'D': Rev 0011.0000, Overlay, Display Correction Buffer, D[StartAddr],[EndAddr],[CompareData] Level G 'E': Rev 0001.0000, Overlay, ToggleEdacEnable, E Level G 'F': Rev 0011.0000, Overlay, Fill Super Parity RAM, F[StartAddr],[EndAddr],[Pattern] Level H 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits] Level H 'D': Rev 0001.0000, Overlay, Amplitude Ratio Sensor, D[Flags],[NumCollectionsToAvg],[Head],[FafhDiameter],[HscIntgLength],[PctOfBpi],[ChannelFreqMhz],[StartHtr],[EndHtr],[HtrIncr],[PreAmpGain],[CtffrScaler],[Ctffr],[Zfr],[PctOfTgtClr],[ChannelPreheatRevs] Level H 'I': Rev 0001.0000, Overlay, Serial Identify, I[Strt],[Cnt] Level H 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks] Level H 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options] Level H 'f': Rev 0002.0000, Overlay, DisplayModifyFafhParms, f[Options],[ParmValue],[Ix0],[Ix1],[Ix2],[Ix3],[Ix4],[Ix5],[Ix6],[Ix7],[InitParmFileEnable] Level H 'l': Rev 0001.0000, Overlay, DisplayFafhHistoryLog, l[Options],[Interval],[Frame],[Head],[Diameter],[ClearLogEnable] Level H 'q': Rev 0001.0000, Overlay, DisplayFafhConfig, q Level H 't': Rev 0001.0000, Overlay, TriggerFafh, t Level L 'C': Rev 0011.0000, Overlay, Copy Log File, C[SrcLog],[DestLog],[AppendOpt] Level L 'D': Rev 0013.0000, Overlay, Display Log File, D[Log],[ErrCode] Level L 'E': Rev 0011.0001, Overlay, Enable / Disable Logging, E[ErrLoggingOpt],[AsciiLoggingOpt],[RwStatsLoggingOpt] Level L 'I': Rev 0011.0000, Overlay, Display Log FileInfo, I[Log] Level L 'R': Rev 0001.0000, Overlay, Read SMART Log, R[LogAddr],[LengthInBytes],[Offset],[Options] Level L 'W': Rev 0001.0000, Overlay, Write SMART Log, M[LogAddr],[LengthInBytes],[Offset],[Options],[StringValueForOptns] Level L 'c': Rev 0011.0000, Overlay, Create Log File, c[Log],[LogType],[BufferOrDiskOpt],[NumBytes] Level L 'd': Rev 0011.0000, Overlay, Delete Log File, d[Log] Level L 'i': Rev 0011.0000, Overlay, Initialize Log File, i[Log] Level M 's': Rev 0002.0000, Overlay, Serial Port Test Results, s[Sub-command],[SptIndex],[ValidKey] Level M 'l': Rev 0001.0000, Overlay, Loopback, l Level T 'B': Rev 0011.0000, Flash, Set Baud Rate, B[BaudRate],[MsecDelay] Level T 'S': Rev 0001.0000, Flash, Reset drive customer settings, SHIP,[ParmValue] Level T 'm': Rev 0017.0219, Flash, Format Partition, m[Partition],[FormatOpts],[DefectListOpts],[MaxWrRetryCnt],[MaxRdRetryCnt],[MaxEccTLevel],[MaxCertifyTrkRewrites],[ValidKey],[DataPattern],[2ndMaxWrRetryCnt],[2ndMaxRdRetryCnt][2ndMaxEccTLevel] Level T 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc] Level T 'F': Rev 0011.0000, Overlay, Display / Modify Congen, F[ValueRef],[Data],[ResetEnable] Level T 'J': Rev 0012.0000, Overlay, Display / Modify CAP, J[ParmValue],[ParmId],[ParmArrayBytes],[ParmByteArrayOffset] Level T 'O': Rev 0001.0000, Overlay, Select Data Output Mode, O[Mode],[VerboseOpts] Level T 'P': Rev 0011.0000, Overlay, Download Generic File, P[FileBytes] Level T 'R': Rev 0012.0000, Overlay, Read Non-Volatile Adaptive Parameters, R[Opts] Level T 'V': Rev 0029.0000, Overlay, Display Defect Lists, V[ListMask],[Hd],[StartCyl],[NumCyls],[Summary],[FlagsMask] V1 - User Area Slip List : Rev 1.0 V2 - System Area Slip List : Rev 1.0 V4 - Reassigned Sectors List aka "Alt List" : Rev 2.0 V8 - Servo Flaws List : Rev 1.0 V10 - Primary Defect List aka "PLIST" : Rev 1.0 V20 - Primary Servo Flaws List : Rev 1.0 V40 - Nonresident G List : Rev 1.0 V80 - Resident G List : Rev 1.0 V100 - Primary DST List : Rev 1.0 V200 - Data Scrub List aka "Mickey Cert List" : Re Level T 'W': Rev 0011.0000, Overlay, Save Adaptives To Flash, W[Seg],,22 Level T 'X': Rev 0001.0000, Overlay, Copy BIGS files to Serial Flash From Disc, Xfefe Level T 'i': Rev 0011.0003, Overlay, Initialize Defect List, i[DefectListSelect],[SaveListOpt],[ValidKey] Level T 'r': Rev 0001.0000, Overlay, Read File, r[FileId],[VolumeNum],[CopyNum],[ByteOffset],[Length],[OutputFmt] Level T 'q': Rev 0001.0000, Overlay, List Physical Head Table, q Level T 'y': Rev 0003.0002, Overlay, List SIM files, y[Volume], [FileDescriptor], [Option] Level T '[': Rev 0011.0000, Overlay, ASCII Log Control, [[LogFunction],[Log] F3 C>
