gtd4242 wrote:
I'll need to find another drive to generate a loader, since I don't want to risk moving these heads back to the donor, generating a loader, and then swapping them back again.
One thing I find odd is, when I have the PSHT and RDMT loaded from a file, refresh the ID and go to sector edit, I can navigate to any sector. I can also just keep hitting "next" and it will go through and read each sector I go to. I can navigate all the way to the final sector. I can see data written to the sectors. However, as soon as I go into Data Extractor, it errors out when trying to read the Drive ID and then I have to reset everything.
You are deselecting the "soft reset" option before progressing through into DE, right?
http://www.pcimage.co.ukNew!! HDD-PCB.COM for all your PCB and donor HDD requirements!
