MRTLAB
HARD DRIVE REPAIR & DATA RECOVERY DEVICE
64 BIT VERSION (only 4 months old)
2 x SATA PORTS
1 x IDE PORTS
1 x ROM PORT
2 x SATA CABLES
1 x IDE Cable
2 x Power cables
includes Serial & Rom cables and connectors
BUY IT HERE
http://www.ebay.com.au/itm/-/121838553269Online version
Will do full transfer of ownership and all recharge points to successful buyer 11 Payments made out of 23 (active subscription payments are $150 USD)
1 SN
Online recharge 1500 2014-11-27 12:17:17 1900-1-1|2014-12-27 12:17:17|积分1500
2 SN
Online recharge 680 2015-1-7 10:35:43 2014-12-27 12:17:17|2015-2-7 10:35:43|积分680
3 SN
Online recharge 680 2015-2-11 18:14:38 2015-2-7 10:35:43|2015-3-11 18:14:38|积分680
4 SN
Online recharge 680 2015-3-12 9:41:01 2015-3-11 18:14:38|2015-4-12 9:41:01|积分680
5 SN
Online recharge 680 2015-4-13 10:39:24 2015-4-12 9:41:01|2015-5-13 10:39:24|积分680
6 SN
Online recharge 680 2015-5-28 12:13:07 2015-5-13 10:39:24|2015-6-28 12:13:07|积分680
7 SN
Online recharge 680 2015-6-29 11:15:13 2015-6-28 12:13:07|2015-7-29 11:15:13|积分680
8 SN
Online recharge 680 2015-8-3 10:27:11 2015-7-29 11:15:13|2015-9-3 10:27:11|积分680
9 SN
Online recharge 680 2015-9-16 11:40:28 2015-9-3 10:27:11|2015-10-16 11:40:28|积分680
10 SN
Online recharge 680 2015-10-17 11:53:39 2015-10-16 11:40:28|2015-11-17 11:53:39|积分680
11 SN
Online recharge 680 2015-11-21 10:27:51 2015-11-17 11:53:39|2015-12-21 10:27:51|积分680
http://en.mrtlab.com/mrt-proOverview
Created by the innovators at Mrtlab, MRT Pro is a combination of software and hardware that specializes in both HDD repair and data recovery. Comprised of two parts, the hardware aspect has a special MRT SATA controller card equipped with two SATA ports, which allows two HDDs to be repaired simultaneously, as well as some additional accessories. On the software side, MRT Pro has 13 specialized utilities for disk repair and data explore on HDDs from various vendors, architectures and families. Through the advanced hardware and software technology, the repair of HDDs, recovery of firmware can be conducted at factory mode where firmware and microcode is accessible and also user data can be retrieved.
MRT Pro currently supports HDD families of products from various manufacturers including but not limited to Western Digital, Seagate, Hitachi (including the original series and the newer ARM series), Fujitsu, Samsung and Maxtor.
Highlighted Features
PCI-Express 2.0 Interface with two native SATA 2.0 ports and one IDE port
Support of all IDE (CE, CF, ZIF), SATA (MICRO SATA) interface HDDs
Support 1.8 inch, 2.5 inch, and 3.5 HDDs with a capacity of up to 5TB
One-click automatic HDD diagnostic repair module
Efficient USB terminal that can work with Seagate F3 serial HDDs
Support Flash ROM programming unit
Support the recovery of corrupted firmware in HDDs
Support the ability to unlock and reset hard drive password (i.e. decrypt the hard drive)
Support data recovery and HDDs repair due to failed read/write heads
Support virtual head map technology
Support the repair of HDDs with physically-damaged sectors
Support disk imaging, imaging by selective head, file recovery
Support Head map editing in RAM for data recovery
Review defect tables (P-list, G-list, T-list, etc.)
Load service information access program – LDR
Hide found defects of magnetic surface
Provide direct read and write to Seagate SA track
Forward and reverse scan and directly recover data from bad sectors
Provide MFT Scan to recover accidentally deleted files
Data Transfer Rates
Compliant with SATA 2.0 standard with speed up to 150MB/s for SATA ports
Compliant with the UDMA66 standard with speed up to 66MB/s for IDE port
Supported Operating System
Windows 7 64 bit
Software Upgrades
MRT Lab regularly updates its software to fix possible bugs, add functionality, reflect changes in standards and respond to new HDD firmware issues. We are committed to provide first-class user experience with our data recovery tools.
