 Post subject: Western digital locked HDD disk
PostPosted: December 7th, 2017, 8:56
Hi all,
I have an Asus EEE PC 1005P with a western digital sata disk WD1600BEVT-80A23T0. I never protected the HDD with pass but now it seems it's locked. The bios shows protection by user and master passwd. I tried mhdd and hdparm with the master password publicly available WDCWDC..... But didn't work. hdparm show the disk is locked and security high enabled. I want to unlock the disk without erase data. What do you recommend? I read about dump a bin file to check the passwd but I don't know how. Maybe extract the hdd and connect with usb adapter?
Thank you
 Post subject: Re: Western digital locked HDD disk
PostPosted: December 7th, 2017, 9:24
hello,
remember your password(chek asus bios)
or
you can try with zu, if you have knowledge http://www.hddoracle.com/viewtopic.php?f=95&t=166
or find some pro DR service near you
PostPosted: December 7th, 2017, 10:42
Thanks for the suggestions. ZU seems a very nice tool but I think it only works in IDE hdd and my wd is SATA. I'm right?
PostPosted: December 16th, 2017, 18:24
Remove pw in laptop bios. Then you will be able to access. If you can’t get this far send to dr company.
https://www.mjm.co.uk/
PostPosted: October 14th, 2018, 12:37
Hi, I read all the thread twice and I could not unlock the ata password of a hd wd 1600 evt-22zct0, and test all the tools of the thread. The only thing he could do was extract the 22.bin file. I'll leave it to see if anyone can help me. I've been in this challenge for a week, day and night. I need help and if someone could explain how to decrypt the password from 22.bin.
please excuse my english
PostPosted: October 14th, 2018, 15:25
Spildit wrote:
Or ...
Extract the attached .rar file and you will get "password" file. Use that same file with this method :
http://www.hddoracle.com/viewtopic.php?f=117&t=1072
The attachment password.rar is no longer available
:D
As alternative :
https://www.ebay.com/itm/ATA-Password-U ... 2674077475
:D
Excuse my ignorance Mr. Spildit but I could not enter the password file since victory (use hirens boot cd). I do not know how to use WDC marvel, download the demo version but how do I run it to start it from a USB? I'm a Jr technician, know how to apologize
PostPosted: October 14th, 2018, 16:03
Thank you very much sir, for your help, I was able to realize the password. I still can not unlock the hard drive, I'm sorry because I read the thread several times and use each method. Also use the one I mentioned before but I could not either. I do not have a PC, only 2 laptops to find a solution. I did what you told me and it did not work. I do not want more to do to unblock, I'm not interested in paying, I want to learn a method
Is there no other way to enter the password?
I read in the middle of the thread that there was a form with altgr to be able to decipher it but I can not understand very well
PostPosted: October 14th, 2018, 16:05
I forgot to mention that when I try to use victory to enter the pass that you gave me, this happened ...
PostPosted: October 14th, 2018, 16:06
When I pre-order to scan the PCI ports it does not find, I'm sure it's because I'm from hirens. But then how would he do?
PostPosted: October 14th, 2018, 16:18
Buying a SATA adapter could solve the problem?
PostPosted: October 14th, 2018, 17:37
I will review step by step mentioned. My problem is that when I select the "PIO" mode I do not see the port of the HDD, I will attach a photo to see it. Thank you very much for your help, I know that I can with this challenge
PostPosted: October 14th, 2018, 19:23
I tried again and it did not work. I checked that the BIOS is in "IDE" mode and it did not work either. On several occasions using different methods he always tells me: "The device is not ready" and a DQR error. I will leave attached some images
cron
