 Post subject: salvationdata supported mrt not supported
PostPosted: April 24th, 2018, 16:42
I really did not expect to see old hd doctor support hitachi 5450A7 family but modern mrt professional hd tool not support hitachi 5450A7 family (I tried many models of this family none of them supported by mrt) I checked pc3k and dolphin dfl both support this family so it leaves mrt the only tool probably not supported this.
 Post subject: Re: salvationdata supported mrt not supported
PostPosted: April 24th, 2018, 18:14
Both E380 and E680 not supported also with the "basic access method" I think all XXXXA7 not supported.
PostPosted: April 29th, 2018, 12:43
Div 1
mrt 0
mrt need first to fix there Bugs , then support new families .
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: May 2nd, 2018, 8:28
You mean more families, the disk is from may 2014.
PostPosted: May 2nd, 2018, 15:52
A while back, I was able to show (MRT support) them via a remote session that A9 was not supported either. A healthy drive that I was able to backup the SA and read with no problems (a few bad sectors) on PC3K, but MRT would refuse to read allow for SA access, no matter which utility they tried...and they tried them all. Although there is no A9 series, my guess is that it should read via the universal utility or even the A7, if there weren't a glitch somewhere.
Recovery Force Data Recovery
PostPosted: May 2nd, 2018, 17:55
DE can access lba fine. It is a matter of not accessing the SA on MRT. sorry for the brain fart about intermixing families...thinking non arm families while talking about arm families.
PostPosted: May 2nd, 2018, 20:14
Spildit wrote:
On Select Family : You see correct family in MRT LOG .
I should have mentioned,MRT didn't select the family like he does automatically in A9,I select it manually.
PostPosted: May 6th, 2018, 13:13
Spildit wrote:
Did you try to put a checkmark on that box - Tech-Key detection ?
Yes I tried,no access to SA as well.
PostPosted: May 6th, 2018, 13:48
Did you try to select 5450A7 with Tech-key detection checked?
PostPosted: June 16th, 2018, 18:19
Finally with the new version 2.1.2.3 the hitachi arm XXXXA7 supported if we checked Tech-key detection.
Thank you Mrt
PostPosted: June 17th, 2018, 17:38
I can confirm it worked with a test case friday.
PostPosted: June 18th, 2018, 21:10
Hi, all,
Thanks for your support, we will continue to work hard on your needs.
MRT Sales consultant--Pink
Email: sales@mrtlab.com
Skype: sales@mrtlab.com
QQ:3292109557
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
