problem witch seagate bios chip (Sanyo 25FS406)
January 15th, 2022, 16:47
Hi I am trying to download bios from chip (Sanyo 25FS406), my soft is XGPRO and the chip is no on the list of that program, somebody know is there a simillar chip on the list wchich i can make a download a bios?
Re: problem witch seagate bios chip (Sanyo 25FS406)
January 15th, 2022, 17:18
Just select a 1.8V 4Mbit SPI flash chip with the same pinout:
https://www.reveltronics.com/downloads/datasheet/le25fs406.pdf
January 20th, 2022, 15:41
Few days looking but i can not find (take a hit) similar chip to this one, if somebody know what to select in XGPRO please help
January 20th, 2022, 16:57
Maybe your programmer cannot handle 1.8V chips?
In the following example you need the TL866II Plus version:
http://autoelectric.cn/EN/TL866_main.html
January 22nd, 2022, 7:50
My have 1.8v it is XGecu TL866II Plus, but I can't find simmilar chip in the soft :(
January 22nd, 2022, 8:01
There's nothing special with 25FS406 as long as reading is concerned, you could select any chip with same capacity and supply voltage.
January 22nd, 2022, 13:01
I try so many chips and wan't work, please tell me for exmaple what chip to choice in your opinion?
January 22nd, 2022, 13:15
W25Q40EW (Winbond)
January 22nd, 2022, 14:32
All the time is info "ID Error! Check the chip correctly? whether contact good pin?"
January 22nd, 2022, 14:54
Doesn't your software allow you to forcibly select a particular chip? Is there some kind of configuration file that defines the parameters of the supported ICs?
January 22nd, 2022, 16:41
Does the sw tell you what ID it read from the chip?
January 23rd, 2022, 13:13
Thanks guys for ansewer, thats look like on soft:
January 25th, 2022, 20:07
an ID of 00 00 00 00 is not what you would want. 25FS406 should have ID 0x62, 0x16, 0x13 so either the chip is toast or your soldering is bad.
January 26th, 2022, 4:00
It all depends on whether the programmer checks the MID ID or JEDEC ID
(LE25U40. MID:0x00000000 JEDEC:0x00130662)
Mikippp
January 26th, 2022, 6:17
If you mean cmd 0xAB, it gives nonzero data after 3 dummy bytes and the programmer sw should know that coz it is the same in 25Q40, so i doubt this is the problem.
At this point I would test the method with a known good chip.
January 26th, 2022, 8:10
90h MID ID
9Fh JEDEC ID
The LE25FS406 only supports 9Fh, and therefore the 90h response is all zeros
Mikippp
January 26th, 2022, 17:55
yeah, indeed. But cmd 90 responds with 2 bytes (on 25Q40), while there are 3 00s the util shows, which better corresponds to the response of 9F.
So i would definitely test the setup with a known good chip to clear up these things.
