 Post subject: ST3320813AS No Command Works
PostPosted: March 29th, 2024, 5:33
Here is a ST3320813AS 2D-Brinks [7200.11]
capacity 0 (zero)
Tried Reading Sys File list using Serial, Drive hangs, Giving most of command on terminal gives LED Error.
ASCII Diag mode
F3 T>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
     67610    67610 EC 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
4294967295 99999999        0 FF  FFFFFFFF FFFFFFFF FF FFFFFFFF
4294967295        0        0 FF  FFFFFFFF FFFFFFFF FF FFFFFFFF
4294967295        0 4294967292 FF  FFFFFFFF FFFFFFFF FF FFFFFFFF
        21       22        0 2F  000000 000000 1 00000080 SPN_UP NORMAL
        67       46       22 34  000000 000000 1 00000080 TCC 0
        89       22      248 02  001121 000000 2 C3160080 XFR RD SYS LBA B 00000000 L 00000004 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
       337      248     2399 02  001121 000000 2 43110081 XFR RD SYS LBA B 00000000 L 00000001 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      2736     2399      341 02  001121 000000 2 C3160080 XFR RD SYS LBA B 0002BD2A L 00000004 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      3077      341     2225 02  001121 000000 2 43110081 XFR RD SYS LBA B 0002BD2A L 00000001 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      5312     2235      344 02  001121 000000 2 43110081 XFR RD SYS LBA B 00008A0C L 000000C8 BO 000000 BES 006210C.006850B.006210C
      5656      344     2175 02  001121 000000 2 43110081 XFR RD SYS LBA B 00008A0C L 00000001 BO 000000 BES 006210C.006850B.006210C
      7832     2176      340 02  001121 000000 2 C3160080 XFR RD SYS LBA B 00034736 L 000000C8 BO 000000 BES 006210C.006850B.006210C
      8172      340     2225 02  001121 000000 2 43110081 XFR RD SYS LBA B 00034736 L 00000001 BO 000000 BES 006210C.006850B.006210C
     10397     2225        9 12  001121 000000 1 00000080 TEMP 42 degC
     10406        9       12 02  002421 000000 1 00000080 XFR WR SYS LBA B 000075AA L 00000001 BO 000000 BES 0061B0C.0061B8B.0061B0C
     10418       12        8 02  002421 000000 1 00000080 XFR WR SYS LBA B 000332D4 L 00000001 BO 000000 BES 0061B0C.0061B8B.0061B0C
     19419     9001        0 27  002421 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 0114 00D0
                                                          0114 0000 FFFF C9F1 0020 0000 0000 0000 1576 0000 0000 0000 0000 0000 0000 0000
     19420        1        0 27  002421 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 0114 00D0
     19420        0        1 27  002421 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 7B40 00D0
                                                          7B40 0000 FFFF C9F1 0020 0000 0000 0000 1576 0000 0000 0000 0000 0000 0000 0000
     19421        1     6017 30  000000 000000 1 00000080 SPN_DN NORMAL
     31242    11821     4007 2F  000000 000000 1 00000080 SPN_UP NORMAL
     35250     4008       13 00  002014 000000 1 00000080 SEEK USR TRK CH 000000.0
     44502     9252        0 27  002014 000000 1 00000080 SND_SRV 516F 0000 0000 0000 0000 0000 0000 0000 0001 0184 00D0
                                                          0000 0000 FFFE DB08 0020 0000 0000 0000 1576 0000 0000 0000 0000 0000 0000 0000
     44502        0        1 27  002014 000000 1 00000080 SND_SRV 086F 0000 0000 0000 0000 0000 0000 0000 0001 0073 00D0
     44503        1        1 27  002014 000000 1 00000080 SND_SRV 086F 0000 0000 0000 0000 0000 0000 0000 0001 0073 00D0
     44504        1        1 27  002014 000000 1 00000080 SND_SRV 086F 0000 0000 0000 0000 0000 0000 0000 0001 0073 00D0
     44505        1        0 27  002014 000000 1 00000080 SND_SRV 086F 0800 0000 0000 0000 0000 0000 0000 0001 0001 00D0
     44506        1        0 27  002014 000000 1 00000080 SND_SRV 0501 0090 0000 0000 0000 0000 0000 0000 0001 1C23 00D0
                                                          1C23 0000 FFFE DB08 0020 0000 0000 0000 1576 0000 0000 0000 0000 0000 0000 0000
     44507        1        0 27  002014 000000 1 00000080 SND_SRV 106F 0000 007E 0000 0000 0000 0000 0000 0001 0013 00D0
     44507        0        1 27  002014 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000 0001 D0C9 00D0
     70251    25744        0 27  002014 000000 1 00000080 SND_SRV 516F 0000 0000 0000 0000 0000 0000 0000 0001 D0C9 00D0
ASCII Diag mode
F3 T>
TetonST4 SATA Brinks Gen3.1 (CC) QNC
Product FamilyId: 2D, MemberId: 07
HDA SN: 9SZ630KV, RPM: 7203, Wedges: 108, Heads: 2, Lbas: 2542EAB0, PreampType: 73 01
PCBA SN: 0000C008DU55, Controller: TETONST_4(63A2)(3-0E-4-2), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 13, BufferBytes: 800000
Package Version: BR140D.CCD2.CG120H., Package P/N: 100586848, Package Builder ID: 7L,
Package Build Date: 08/06/2009, Package Build Time: 13:47:53, Package CFW Version: BR14.CCD2.00194383.7L00,
Package SFW1 Version: D0C9, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 08061347, CustomerRel: CC2J, Changelist: 00194383, ProdType: BR14.CCD2, Date: 08/06/2009, Time: 134753, UserId: 00357094
Servo FW Rev: D0C9
RAP FW Implementation Key: 0E, Format Rev: 0200, Contents Rev: 01 0C 00 00
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled
F3 T>/7
F3 7>X
LED:000000CC FAddr:00275E77
 Post subject: Re: ST3320813AS No Command Works
PostPosted: March 29th, 2024, 5:42
https://forum.hddguru.com/viewtopic.php?t=17831&start=
PostPosted: March 29th, 2024, 5:46
nothing can be read from the SA. either weak heads (not very probable that both sys heads are weak) or non-native pcb
HDA SN: 9SZ630KV
check SN on HDA label
PostPosted: March 29th, 2024, 6:01
That's on me , Sorry, I was tweaking with the Rom file by swapping SAP with a donor ROM , incase there is Damage in Rom, But same issue there too .
Here is the Original Output of Terminal with Original ROM and PCB,
HDA SN - matches the LABEL.
F3 T>
ATA  15 Cmds
RW  32 Cmds
  72419520 99999999 1538225992 00  2010016 20800040 44 09200020 SEEK USR
3433828626 3361409106 4083609336 28  40000000 1063228 20 00010800 FIX_RAP
541069312 1402207982 2279739408 C0  10124000 080200 24 02020010
  71827712 3825725696 4291591938 00  42003402 208B4280 0 28001003 SEEK WR PBA B 90004800 L 00800280
554172960 482345248 3875012130 00  8006000 11000800 40 11000622 SEEK
  17039748 3757834084 2164003453 04  8072C809 E100000 0 62309411 SRV_MEM Type 0 Addr 34800201 Cnt 0001
   4718848 4282646396 2419867536 08  94284002 83800080 28 4001000A CAL
   4243968 4294492416 4292296192 40  18028400 10801094 0 00804000 TWK_WR_PWR
420548800 416304832 657391426 00  000000 B0001000 80 00020001 SEEK
537662464 117113664 638938132 01  44008000 411440 4 03004454 XFR_ALT BO 218000 BES 0080800.48010110.16888380
       164 3757304996 134217564 C0  102400D 0A1E80 85 40014080
    212992   212828 3223766176 90  8480C401 3043140 FF F7CFFFFF
2113909759 2113696767 2147503040 FF  FBEFFFE2 7FDDF6FD FF FFFFF9FF
4159700989 2045791230 135258086 F5  FFFFFEBF FFF7F7D7 CF BFFFFF7F
4294966191 135265202      848 F7  FBFFDFFB EFFEFFFD FF FEF7EFFF
4026432511 4026433616 3884024832 DD  DFFFFEFF 7EFFFFFE EF FFFFBFF7
4294964735 268532224 4192205056 EF  FBFDBFFE FFDF63FF 7D FFFFF7FF
4294426493 4294429054 4293910654 FB  7FFDFFFE F7FFFFFF F5 FFFFD5FF
4292868079 4293408882  2099086 FE  FFDFDFFF E7FDAFFE FF FFFFFFFB
        21  2099238        0 2F  000000 000000 1 00000080 SPN_UP NORMAL
        89       22      256 02  001121 000000 2 C3160080 XFR RD SYS LBA B 00000000 L 00000004 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
       346      257     2365 02  001121 000000 2 43110081 XFR RD SYS LBA B 00000000 L 00000001 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      2711     2365      341 02  001121 000000 2 C3160080 XFR RD SYS LBA B 0002BD2A L 00000004 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      3052      341     2225 02  001121 000000 2 43110081 XFR RD SYS LBA B 0002BD2A L 00000001 BO 000000 BES 00DE1F6.00DE3F5.00DE1F6
      5287     2235      336 02  001121 000000 2 43110081 XFR RD SYS LBA B 00008A0C L 000000C8 BO 000000 BES 006210C.006850B.006210C
      5623      336     2175 02  001121 000000 2 43110081 XFR RD SYS LBA B 00008A0C L 00000001 BO 000000 BES 006210C.006850B.006210C
      7799     2176      339 02  001121 000000 2 C3160080 XFR RD SYS LBA B 00034736 L 000000C8 BO 000000 BES 006210C.006850B.006210C
      8138      339     2176 02  001121 000000 2 43110081 XFR RD SYS LBA B 00034736 L 00000001 BO 000000 BES 006210C.006850B.006210C
     10314     2176        8 12  001121 000000 1 00000080 TEMP 38 degC
     10323        9        3 02  002421 000000 1 00000080 XFR WR SYS LBA B 000075AA L 00000001 BO 000000 BES 0061B0C.0061B8B.0061B0C
     10327        4        7 02  002421 000000 1 00000080 XFR WR SYS LBA B 000332D4 L 00000001 BO 000000 BES 0061B0C.0061B8B.0061B0C
ASCII Diag mode
F3 T>
HDA SN: 9SZ6C9ZD, RPM: 7203, Wedges: 108, Heads: 2, Lbas: 2542EAB0, PreampType: 73 21
PCBA SN: 0000C01876SG, Controller: TETONST_4(63A2)(3-0E-4-2), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 13, BufferBytes: 800000
Servo FW Rev: D0C9
Features:
- IOEDC enabled
- IOECC enabled
- LTTC-UDR2 enabled
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
PostPosted: March 29th, 2024, 6:04
Note : Drive Spins completely Normal , No unusual Sound, Just the Ready state takes Time around 10 more seconds than any other similar family drives takes.
Model no : ST3320813AS
Serial : 9SZ6C9ZD
Firmware : CC2J
PostPosted: March 29th, 2024, 6:10
looks like same problem, still not native adaptives?
what's the SN on the HDA label?
PostPosted: March 29th, 2024, 6:17
Serial : 9SZ6C9ZD
Firmware : CC2J
This is what label says ...
PostPosted: March 29th, 2024, 6:19
can you attach the ROM for checking?
PostPosted: March 29th, 2024, 6:23
ROM-2D-CC2J - ORG.zip [227.35 KiB]
Downloaded 408 times
PostPosted: April 2nd, 2024, 7:14
Did you find something in it ?
PostPosted: April 2nd, 2024, 11:52
The serial number in SAP and CAP matches the label, so the ROM appears to be native.
Users browsing this forum: kotel and 75 guests
