Here's what I discovered after many attempts in the last few nights.
Probably most of pros know this procedure but there are for sure many owners of ES.2 drives locked in BSY state, who can try to repair them at home.
Terminal of my 2 ES.2 drives was locked (drives were in BSY state) - every 3-4 seconds I received from their terminal message LED: 000000CC....
Standard solution which is widely known for 7200.11 series (ST******AS) doesn't work for locked ES.2 series (ST******NS) !!!
But i've found a way to unlock terminal of my ES.2 drives
what allows then to repair hd in a standard way (solution from Yura/Okzo).
1. Disk has to be complete (PCB+rest together), NO isolation between the PCB and the rest
2. In the terminal you will see every few seconds message LED: 000000CC ...
3. between these messages you can unlock the terminal by pushing CTRL+Z. It will show a line: "F3 T>" and it will be Unlocked for about 1 second
4. During that 1 second when you see "F3 T>" message but before you receive next "LED:000000CC..." you must short two points shown in the following image (they are known as "read-channel").
You must hold them short about 20-30 or little more seconds.
If you won't see next "LED:000000CC..." and disk will issue few unpleasant sounds then after some time you'll see in the terminal message "Input Command Eror".
Now the disk's terminal is unlocked!
Still holding those 2 pins short issue command /2 and then Z (they're cAsE sEnSiTiVe!).
When disk's engine will stop you will see message "Spin Down Complete" and now you can release the short between 2 pins.
Next do repair with standard instruction (as for 7200.11) - all below is cAsE sEnSiTiVe!:
F3 2>U
Spin Up Complete
F3 T3>/1
F3 1>N1
F3 1>/
F3 T>m0,2,2,0,0,0,0,22
and wait until you'll get message
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
User Partition Format Successful - Elapsed Time 0 mins 05 secs
Good example (also extended) gave man called aviko on msfn.org forum (post number 529 in topic # 128807)
It is at:
http://www.msfn.org/board/index.php?sho ... ntry832876I am a complete amateur (not DR professional), and of course, give no warranty for the described procedure.
It worked for me and my two ES.2 drives are alive now.
Of course, this procedure or the incorrect use might as well burn your disks and data.
I don't assume responsibility for such cases - everything you do at your own risk.
This procedure of ES.2' terminal unlocking is my own discovery, and I'd like to share this knowledge with other poor owners of bricked (in BSY state) ES.2 disks.
