 Post subject: WD3200BMVS 11F9S0 any help on this please
PostPosted: March 26th, 2010, 20:40
very weird problem the hard drive is seen in the bios
but not at all in windows.
hard drive was dropped by customer but it still worked for them
told us they tried getdata back and it was picking the drive up
but it was failing on the read lba
there is no clicking noise and it sounds fine.
what you think possible wrong with it.
could be heads problem im thinking.
wd p/n WD3200BMVS 11F9S0
320GB
DATA 18 AUG 2008
DCM HBNTJBBB
 Post subject: Re: WD3200BMVS 11F9S0 any help on this please
PostPosted: March 27th, 2010, 9:52
at least firmware have problem already. it's seem got weak head even bad....
data recovery service[/b]
PostPosted: March 27th, 2010, 12:15
yep it looks like its got a weak headstack.
the qeastion is can you do a straight headstack swap
or is the unit special alignment now on these drives.
if so do you think it might be worth a chance swapping the headstack over.???????
cheers m8 :beer:
PostPosted: March 27th, 2010, 12:47
This is a scorpio drive...so alignment is not really an issue =)
check for media damage though.
PostPosted: March 27th, 2010, 12:58
why dont you clone first the good heads and try to see wich data you get.
ZeBong
" Россия еще раз"
PostPosted: March 27th, 2010, 14:49
i would tried clone by heads and maybe u can link´s to MFT and clone this are only until u get the most important data from client
PostPosted: March 27th, 2010, 16:04
there no media damaged at all no scratching or anything like that.
im going to try and clone with the good head and see what i get.
the drive is in the uk and im in canada arghhhhhhhhh
PostPosted: March 29th, 2010, 9:52
well all u can see really is a top platter... Anycase id vote weak/dead head or SA damage.
PostPosted: March 31st, 2010, 23:37
wow these hard drives are hard to come by why is that.????????
i found a company and just bought 3 from them.
they be here in less then a week :)
Users browsing this forum: No registered users and 176 guests
