 Post subject: Help if possible...
PostPosted: April 7th, 2010, 15:36
Hi, i was wondering if any one could help, i have a seagate Barracuda ata iv model ST340016a
serial - 3hs6lwmy
part no - 9t6002-132
firmware 3.75
site code - AMK
the pcb is burnt out and i wanted to do a swap, i found a drive with the same part number same firmware, same site code but when fitted to the drive it just clicks is there any thing i can do to stop this co configure the board to work ?
Thanks for your help in advance
 Post subject: Re: Help if possible...
PostPosted: April 7th, 2010, 16:12
It seems like whatever blew the PCB also blew the preamp inside the drive. DIY had gone as far as it will on this case. I can help in UK, but not for free! :wink:
PostPosted: April 7th, 2010, 16:16
Is this your board?
http://obrazki.elektroda.net/49_1241697480.jpg
If so, which chip is burnt?
PostPosted: April 7th, 2010, 16:41
[IMG=http://img714.imageshack.us/img714/9972/491241697480.jpg][/IMG]
PostPosted: April 7th, 2010, 16:46
http://img714.imageshack.us/img714/9972 ... 697480.jpg
PostPosted: April 7th, 2010, 16:49
http://yfrog.com/ju491241697480j
see here.... almost the same... oppps multi post >.<
PostPosted: April 7th, 2010, 17:18
I don't know about the "two resistors", but the 2P102 IC appears to be part of the negative regulator for the preamp inside the HDA.
FDFS2P102A Integrated P-Channel PowerTrench® MOSFET and Schottky Diode, Fairchild, 20V, 3.3A:
http://sluzhebka.com/DataSheet/FDFS2P102A.pdf
ISTM that expensive professional data recovery may be your only option. :-(
For absolute confirmation, you should use your multimeter to test for shorts at the preamp connector. Locate the preamp pin(s) that connect to pins 1 and 2 of the IC. That will be your negative supply rail. Then measure the resistance between this pin and ground.
PostPosted: April 8th, 2010, 18:23
ok, thanks so much for your help i will have a look at the weekend.
Users browsing this forum: No registered users and 175 guests
