 Post subject: samsung hd501lj tried hot-swap bd5 codes
PostPosted: April 22nd, 2010, 17:16
Hi I have a samsung hd501lj
dead board with FW cr100-12
Put on donor board from cr100-13
The terminal gets a bd5 codes - indicating SA problem.
I do a hot swap and get to where I can talk to drive and test heads SA area etc.
My pc3k is a little out of date...
Head test says heads are all good.
SA structure test says SA modules are all good.
But cant read any sectors - gets read errors.
I suspect its got translator problems and it needs to be regenerated.
Is there a terminal command to do that?
The firmware is a little different so I could UL good firmware but my pc3k seems to not like doing that.
My pc3k gets an error reading the rom through the terminal. But I can see that its doing it.
I issue the read rom through terminal command, it times out saying drive is not responding, but if you go to the terminal screen
I can see a bunch of gibberish (rom codes) coming in.
What are the terminal commands to regenerate the translator?
What are the terminal commands to upload and download the rom - maybe I can do it manually.
ps It is a legit pc3k not some china clone.... - I just dont feel like shelling out $1800 + $1800 for 'updates' ..... guess I will have too...
Expert in data recovery, RAID, VMware, Linux, Tape, Forensics, Cleanroom...
http://www.alandatarecovery.com
 Post subject: Re: samsung hd501lj tried hot-swap bd5 codes
PostPosted: April 22nd, 2010, 17:30
1) FW is on ROM + on platters
2) How can you say heads are all good ? Only in a "specific" mode the drive can be tested. (I assume there's something wrong with heads according to the symptoms)
3) There is no command for regenerating translator. It's not Seagate. Samsung work VERY DIFFERENTLY.
4) There are no commands for uploading and downloading ROM in terminal. To up/download the drive MUST enter another "specific" mode , data must be fed in a certain way AND then the drive erase, write and verify the ROM. In your specific case ROM is embedded in the MCU. BTW, another part of the FW must match or the drive will not work.
PostPosted: April 22nd, 2010, 19:40
BTW, is it that sure that the drive has translator problems? Not even started normally because of FW incompatibility...
These drives have been supported by pc3k for ages, so I have some doubts about the origin of your tools anyway.
PostPosted: April 22nd, 2010, 23:21
I have been told it doesnt look like translator -
Te samsung utility is 3.01
Heres the logs
I repowered it below and it gets the bd 005 codes...
<<<<<<<< This is good donor cr100-13 board powering up on its own body >>>>>>>>>>>>
SPW 1.5G LinkOk! ADC: FFFC
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: FFFB
DAC: 7C88
Unlatch Tk: 000183A9
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
0006
0007
0007
0005
0006
0009
0007
0006
0007
0007
0007
000A
0006
0005
0006
0005
0004
00020401_0000_0000 ENG>
<<<<<<<<<< Here is after I hot swapped and tried a read test with patient body >>>>>>>>>>>>>>
SRST -Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-ToutHEr:1301 1301
<<<<< Here is where I repowered the patient with the donor board >>>>>>>>
I read that the LED B5 means SA problems.
But the pc3k will read test all the heads and the service area without errors....
its close... I wonder if its the FW
The patient board doesnt look fried. I swapped and remove some protective diodes on the +5 +12 - same....>>>>>>>>>
SPW 1.5G LinkOk! ADC: FFFD
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: FFFD
DAC: 7E89
Unlatch Tk: 00018787
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
WriteSctLog -- buffer not valid
LED B5 0000
LED B5 0000
LED B5 0000
PostPosted: April 23rd, 2010, 0:00
Update your PC3000. The latest release has ROM upload function.
Jono
http://www.datasaversllc.com
PostPosted: September 9th, 2010, 5:44
Swap Marvel chips if you know how to do it....
Users browsing this forum: szlaci_s70, unknown and 128 guests
cron
