 Post subject: Fujitsu 2,5" MHS2040AT
PostPosted: September 18th, 2010, 6:25
Hi there
A problem with this disk.
The disk is not detected, not even by doctor, but it says Ready.
I got a donor PCB and changed the ROM. If I try to read the ROM, I get F3M108.
When trying to load from HDD on the bottom I get ERROR. No operations can be made in the Firmware options.
Read SA MAP, get error too.
Is this Heads? Or....
ACELab partner
 Post subject: Re: Fujitsu 2,5" MHS2040AT
PostPosted: September 18th, 2010, 6:59
Listen very carefully when you power up the drive.
Do you actually hear the heads come off the ramp and try to load FW, or does it just spinup but the heads stay put?
Compare it to a good drives' noise.
PostPosted: September 18th, 2010, 7:20
I don't hear any strange noise... That's odd...
It seems to spin up OK.... No BZZZZ ou tick-tick's....
Not even at first, with the original PCB.
The client said that it had an USB power surge, but nothing seems to be toasted...
ACELab partner
PostPosted: September 20th, 2010, 8:08
No more ideas/hints?
ACELab partner
PostPosted: September 20th, 2010, 9:03
preamplifier maybe.
PostPosted: September 20th, 2010, 12:57
If you're experienced you should change heads. If that doesn't work then most likely SA is damaged and that's a brick wall.
PostPosted: September 20th, 2010, 17:54
Hi
Not experiencied yet on changing heads and don't have a donor :shock: :shock:
Gonna outsource it...
ACELab partner
PostPosted: September 21st, 2010, 17:39
Does anyone have a SA map for this model? Or even firmware?
Thank You
ACELab partner
PostPosted: September 22nd, 2010, 5:36
Thank You
May be MHS2020AT could help for you?
Angel Data Recovery
PostPosted: September 22nd, 2010, 16:05
DR-Kiev wrote:
Thank You
Maybe. Do you have it?
ACELab partner
PostPosted: September 24th, 2010, 1:54
pclab wrote:
DR-Kiev wrote:
Thank You
Take.
FUJITSU MHS2020AT-8004-NL42T2C12PE0.ZIP [264.88 KiB]
Downloaded 542 times
Angel Data Recovery
PostPosted: September 24th, 2010, 16:54
Thanks. Let's see then... 8) 8)
ACELab partner
PostPosted: September 26th, 2010, 8:14
Did you solve it?
Free Solutions
PostPosted: September 26th, 2010, 8:27
Not yet.... Just tomorrow I'll check it.
ACELab partner
Users browsing this forum: szlaci_s70, unknown and 145 guests
