 Post subject: Recover data from DVD player with HD
PostPosted: September 29th, 2010, 13:39
Hi
Today I received this DVD player that can record to HD as well, to recover the films that are inside.
It has a Seagate 160GB, wich is well detected on the PC and tested with the doctor (it's fine).
Tried to recover with R-Studio, but no luck. No kind of partition, nothing.
R-Studio can say that I have 7TB (yeah TB)....But no files found.
Any ideas??
ACELab partner
 Post subject: Re: Recover data from DVD player with HD
PostPosted: September 29th, 2010, 14:16
What's the brand/model?
PostPosted: September 29th, 2010, 14:18
You tried UFS Explorer?
PostPosted: September 29th, 2010, 14:23
What make and model recorder did they drive come out of? I know some PVR's encrypt content.
PostPosted: September 29th, 2010, 14:53
Just tried R-Studio and Ontrack Easy Recovery.
The DVD is a Philips. Don't now the model now...
This recorder is used on a Hospital and there are videos of surgeries inside.
Tomorrow I'll try UFS Explorer.
Can it be encrypted?
ACELab partner
PostPosted: September 29th, 2010, 14:59
Are you sure it is not ATA locked? These new recorders can use some sort of locking mechanism to stop pirating. But with past experiences with Philips.. they like to make their own systems. Use Doctor and view the first sectors of the hard drive and see what is there? Maybe there is a hint in there.
Free Solutions
PostPosted: September 29th, 2010, 15:00
Tomorrow I'll check it. Thanks
ACELab partner
PostPosted: September 29th, 2010, 17:23
Alot of DVR boxes use "odd" file systems that can't be detected by most DR software.
PostPosted: September 29th, 2010, 20:19
Just FYI, here is an analysis of a TFS2 (?) file system:
http://jeroent.com/salora/?cat=4
http://jeroent.com/salora/?cat=6
It is used in a Tevion TDR250HD recorder built around a "DMN-8652 LSI Logic Dimension 8652 HDD/DVD Recorder Processor".
This file system fills the disc starting from the uppermost LBA and working downwards toward LBA 0.
PostPosted: September 30th, 2010, 1:50
Check model, we can recover from Philips but need some details.
PostPosted: September 30th, 2010, 4:06
Hi BlackST
The model is a DVR3450H/58.
ACELab partner
PostPosted: September 30th, 2010, 5:23
If you make an image of the drive you should be able to extract all the files with file carving. Each video is split into many small mpg files that are also encoded in some format. You will have to join all the relevant files and decode them.
PostPosted: September 30th, 2010, 7:44
UFS Explorer could found some Mpeg Files.
Let's see if it's that what I want.
ACELab partner
PostPosted: September 30th, 2010, 15:48
Good luck :-)
PostPosted: October 1st, 2010, 9:45
Any luck?
Free Solutions
PostPosted: October 1st, 2010, 12:41
Yeap. Got 72GB of cirurgy videos :mrgreen: :mrgreen:
ACELab partner
PostPosted: October 1st, 2010, 12:42
ACELab partner
Users browsing this forum: Google [Bot], pepe and 112 guests
