 Post subject: WD3200BEVT Wht can I do now? HELP!
PostPosted: September 28th, 2010, 20:02
Hi the story goes like that.
That HDD was in laptop and suddenly PC got switched off. and did not boot any more.
I got the drive out, concocted it via R-Driver cable to USB and under windows recognized mass storage device installed it and it was ready to use.
Unfortunately the drive was not visible under My Computer.
I used
Recover My Files v4
to make a scan and it did found that drive with the proper name under USB device. COOL
I started the scan to recover the files. Somewhere along the line my PC rebooted as I was doing to many things on it in the same time! I am sure that this was not done because of the scan.
I started the scan once again and it was going fine and it did rebooted one more tine. IN the attack of panic I decided to disconnect this HDD and in my endless stupidity I grabbed the drive not be sides but from the top and the plate bended and the drive made horrible noise!!!!!
Now when I try to scan the drive with the same software it stops there no drive H:. I have to unplug the drive and then shows
//phicaldrive3 not readable media.
I have to questions.
What I did with that drive?
Is it possible to fix it?\
Any ideas?
PLZ HELP! I AM DESPERATE!
 Post subject: Re: WD3200BEVT Wht can I do now? HELP!
PostPosted: September 28th, 2010, 21:39
You probably jammed that drive.
Originally you had problems with that drive, plus jamming it made it worse.
I would recommend to seek for professional help now.
www.datarecoveryne.com
PostPosted: September 29th, 2010, 4:36
Yes. agree with harddrivespecialist.
We can probably help in UK.
PostPosted: October 3rd, 2010, 5:35
HI all
THX for advise abut after a lot of praying and swearing I DONE IT!
I left PC to scan in search if drive first for +30min and it worked. HDD was found by the proper mane.
Then I left it for scan it took +24h (300GB) but I manage to recover all files apart from 60% of movies) but all other important files I have.
I do not now how it worked but I am happy now.
THX
PostPosted: October 3rd, 2010, 15:14
Congrats. You're a lucky guy!
Murphy was an optimist
PostPosted: October 3rd, 2010, 15:36
Thanks for sharing the result. You got very lucky this time. Back up everything the next time!!!
GOOD JOB & Congrad on your Recovery!
Users browsing this forum: Google [Bot], pepe and 125 guests
